Old 12-11-2012, 11:07 AM   #1
muscly OP
muscly's Avatar
Oddometer: 74
950SM wheels on 950SE ??
I got my hands on a set 17" whels from a 950 SM, I have not tryed it on my SuperEnduro yet.
Is it possible to make them work, have anyone tryed this combination? Tips?
https://www.facebook.com/home.php?re...type=1&theater
Why I love Offroad bikes?
Because 99,999% of the earth,
are not pavement.
muscly is offline   Reply With Quote
Old 12-11-2012, 11:19 AM   #2
River6822
Fat kid on a 950 SE
River6822's Avatar
Oddometer: 361
Easier said than done
Check these out
http://www.advrider.com/forums/showthread.php?t=656675
http://www.advrider.com/forums/showthread.php?t=306699
info on the 17" 17" combo
http://www.advrider.com/forums/showthread.php?t=632492
2013 KTM 1190 Adventure
2007 KTM 950 SE
2004 KTM 450 EXC
1979 Suzuki GS850
1993 Harley Café Project
River6822 is offline   Reply With Quote
Old 12-11-2012, 12:19 PM   #3
SpeedyR
SE in the SE
Oddometer: 854
contact CJDesigns/dual Sport warehouse. He/they make a spacer/rotor adapter for the front wheel. Haven't figured out what you need for the rear, maybe it bolts right up?
from the reading I've done it sounds like you use the stock 300mm rotor on the SE on the SD wheels (with his adapter), so no need for a caliper relocation bracket and such. stock caliper, etc.
I am going to start looking into a 17"/17" setup in the very near future as I plan to take my SE on the track in the southeast soon (I sometimes help instruct the novice group with a local track day org). I understand all about the 17 vs 19" front but for my use (track and mountains) I want the 17" front because of better sport rubber that only comes in 17" sizes.
I have a few wheels around (17", 18", 19" inch rear and 20", 21" fronts) for my 450 so might just throw a few things on the SE one of these days and see what fits. I have a 320mm rotor and relocation bracket for the 450 as well would be curious to see the difference in bolt patterns and spacing as well..
anyway keep us posted on what you find and the costs to mount the SD wheels on the SE. enquiring minds want to know...
SpeedyR is offline   Reply With Quote
Old 12-11-2012, 12:45 PM   #4
River6822
Fat kid on a 950 SE
River6822's Avatar
Oddometer: 361
450 Front
I'm almost 100% positive that the front wheel from my 05 450 exc will direct fit on the SE with the SE spacers and axle.
2007 KTM 950 SE
2004 KTM 450 EXC
1979 Suzuki GS850
Old 12-11-2012, 03:29 PM   #5
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,114
The rear SM will bolt right up with no changes, other than chain length.
Front is a CJ designs rotor mount and spacer kit, as mentioned above.
snowhawk jockey is offline   Reply With Quote
Old 12-11-2012, 03:38 PM   #6
Peanuts
Peanuts's Avatar
Oddometer: 1,576
Rear straight in, so long as you have the SM disc and sprocket carrier.
Front needs SE spacers modifying and fitting to the SM wheel, SM disc reversing and a bit of work on the speedo sensor. All DIY stuff :)
Peanuts is offline   Reply With Quote
Old 12-11-2012, 08:11 PM   #7
jsantos58
jsantos58
jsantos58's Avatar
Oddometer: 235
That looks SWEEEET
How does it ride?
js
Joe
Present - 2012 R1200 GSA
Past - 2007 KTM 990a,2001 R1100s, 2004 R1150GSA, 2000 R1100s, 2007 R1200GSA, 1999 HD FXWG, 1985 HD FXWG
jsantos58 is offline   Reply With Quote
Old 12-11-2012, 08:16 PM   #8
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,750
I have a complete 17in rear from an SM if anyone is interested.
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
KTMSER is online now   Reply With Quote
Old 12-12-2012, 04:26 PM   #9
Peanuts
Peanuts's Avatar
Oddometer: 1,576
Handles great, turns in really good. But front brake is not as good as it should be for a road bike.
Old 12-14-2012, 04:51 AM   #10
muscly OP
muscly's Avatar
Oddometer: 74
Great info. so I can use the original spacer rear, and then buy spacer front to align the brake disc from CJDesigns.
Should I go for better front brakes? The original is 300mm, cant see a 320mm will make a huge different. a stronger caliper maybe? How about gearing? 17-38 will this be okay on the SE?
are not pavement.
Old 12-14-2012, 06:56 AM   #11
LukasM
Oddometer: 5,388
Better caliper with a bigger disc will make a big difference. Several options, the easiest bolt-ons are Beringer 4 or 6 piston axial with 310mm disc (they make a really nice cast iron one), Motomaster 4 piston with 320mm disc, or the best budget option is the gold Brembo 4 piston and 320mm disc with the adapter bracket that Mr. Peanuts above makes for a very fair price. I've got one and it's nice! You can also change to a radial caliper with a QTMI bracket, although they are not cheap and most radial calipers are pretty wide so you have to watch spoke clearances.
Old 12-14-2012, 12:04 PM   #12
Peanuts
Peanuts's Avatar
Oddometer: 1,576
Personally If I was going canyon carving I would fit a hardparts/Braking 320mm disc and a 4 piston Brembo with one of my brackets.
Normal road use is fine, just remember you are on a heavy, fast bike with a slightly too small brake. Good quality fresh brake fluid is a must.
Times are GMT -7.   It's 03:08 PM.
