Old 12-11-2012, 11:36 AM   #1
folknride OP
Old Adventurer
folknride's Avatar
Oddometer: 667
Help - Valve specs and temperature
I'm doing a 30,000km valve check on my 2010 990 S here in my chilly garage in chilly Alberta. Specs are for 20C (room temp) and it's probably more like 5C in my garage. All valves are at the low end of spec except one exhaust that is about .03 mm tight. My question is does colder temps reduce or increase gap?
Should I change shims or leave it 'til next time?
Thanks for any advice from you good physics guys.
folknride is offline   Reply With Quote
Old 12-11-2012, 11:44 AM   #2
Black Hills
Oddometer: 1,138
Clearance increases at colder temps (the metal contracts). But I have no idea how much.
Black Hills is online now   Reply With Quote
Old 12-11-2012, 11:46 AM   #3
dmn0507
dmn0507's Avatar
Oddometer: 351
I think the most affected part is the valve stem (since is pretty long)
With lower temps the gap should be increased, since the stem gets shorter, but i guess the difference it's not that big (let's wait for somebody who wants to do some math )
dmn0507 is offline   Reply With Quote
Old 12-11-2012, 11:54 AM   #4
folknride OP
Old Adventurer
folknride's Avatar
Oddometer: 667
Thanks - kinda what I thought - but my brain sometimes "malfunctions". I'll pull the shims and shoot for the high end of spec.
Old 12-11-2012, 11:55 AM   #5
markjenn
Oddometer: 10,395
Hard to say. I think the big thing with setting a valve "cold" is for the engine not to be recently run - beyond this, the actual temp is probably not a big factor.
Whether you could let this valve ride is up to you. Nothing bad usually happens when you let one that is slightly out of spec go till the next adjustment. But I don't think you can assume it will be in spec if your garage was 15-deg warmer.
Personally, I wouldn't make extra work for yourself doing extra valves, shooting for the high end of spec. For one, the shims typically don't come in that fine an increment where you can nudge the clearance precisely to the top end of spec, and second, you may end up overshooting or causing some other issue. Further, valves don't necessarily tighten with wear as everyone thinks - sometimes they can go the other way so moving towards one extreme of spec may just be increasing the risk you're going to have to do it again the next adjustment. Not to mention the extra work and expense, especially if you end up messing around with a head you wouldn't have messed with otherwise. If you just have one valve out, I'd just shim that one.
- Mark
markjenn screwed with this post 12-11-2012 at 12:01 PM
Old 12-11-2012, 12:26 PM   #6
folknride OP
Old Adventurer
folknride's Avatar
Oddometer: 667
Thanks Mark - now I'm kind of torn. Harley shims come in .025 intervals and I could move close to looser end of spec on all valves. KTM - I could just do the one tight exhaust. Folks always say loose valves (within spec of course) are happy valves, and once i've pulled the cams .... Hmmmm?
Anyone else with advice?
Old 12-11-2012, 12:30 PM   #7
gozirra
Spam?
Oddometer: 160
I know this may sound strange, but if you are elbow deep in the job and it is a huge issue, why not heat the garage (I know a waste and time and $$$) just to get the check done within spec.
gozirra is offline   Reply With Quote
Old 12-11-2012, 12:32 PM   #8
Qwik
Adrenaline Addict
Oddometer: 6,547
Well, You are already there.....
Speed bumps never seem to make me go any faster
Qwik is offline   Reply With Quote
Old 12-11-2012, 12:39 PM   #9
uraberg
whosaberg?
uraberg's Avatar
Oddometer: 689
I'm going to say that the temperature difference between room temp, and operating temp makes the 15 degrees difference in your garage insignificant.
uraberg is offline   Reply With Quote
Old 12-11-2012, 12:47 PM   #10
gozirra
Spam?
Oddometer: 160
68 vs 41 degree fahrenheit, i think he listed celsius.
Old 12-11-2012, 01:05 PM   #11
RadoR6
Oddometer: 58
If you're not sure how about to put a heater into your garage?Wondering anyway how someone can do servicing in a cold garage with frozen fingers?
RadoR6 is offline   Reply With Quote
Old 12-11-2012, 01:06 PM   #12
folknride OP
Old Adventurer
folknride's Avatar
Oddometer: 667
Thanks guys - I'm just going to do them all - now I'm in it - and the Harley dealer has lots of stock.
(except I can't get the freaking spark plug tube to move - swearing profusely as indicated)
Old 12-11-2012, 01:09 PM   #13
folknride OP
Old Adventurer
folknride's Avatar
Oddometer: 667
Why am I doing this - because I'm a world class procrastinator and need to get ready to leave for sunny Kali!
Got my longies on and a space heater - and hey - I'm Canadian eh?
Old 12-11-2012, 01:14 PM   #14
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 895
Boy, it looks like KTM is coming out with their new 1190 StarCruiser at just the right time.
Sporting Wood is offline   Reply With Quote
Old 12-11-2012, 03:25 PM   #15
Hipster
Hipster's Avatar
Oddometer: 1,775
Forknride,
I your local KTM or HD dealer doesn't have the shims you need on hand, shim kits can be had for about $65 http://www.rockymountainatvmc.com/p/...Valve-Shim-Kit
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Times are GMT -7.   It's 11:39 AM.
