Old 12-11-2012, 11:04 AM   #1
hoffa509 OP
Oddometer: 41
Can you identify this tank?
I have this in a pile-o-parts that came with my RD350. I would like to ebay it, but it would be easier if I knew, for sure, what it came from. There is not a real serial # or anything on the tank.
Also, does anyone have good non-destructive ways to bet the cap off without a key. I want to check for rust. Otherwise, I will go through the petcock.
Uploaded with ImageShack.us
Any help would be appreciated.
KLR650, Husky TE 250
Honda TLR200 Reflex http://www.advrider.com/forums/showthread.php?t=642122
hoffa509 is offline   Reply With Quote
Old 12-11-2012, 02:26 PM   #2
Steve G.
Steve G.'s Avatar
Oddometer: 7,135
Early 80's KZ 400??
Steve G. is offline   Reply With Quote
Old 12-11-2012, 04:35 PM   #3
Mobiker
Oddometer: 1,743
I think the KZ400's tank was more rounded without the ridges on top.
I was thinking early eighties KZ550 or 750, but its hard to tell.
You might measure its capacity. That might help narrow it down.
'88 R100GS
'76 xl350
"Don't Panic"
"If I was in a hurry, I'd left earlier."
Mobiker is offline   Reply With Quote
Old 12-11-2012, 04:59 PM   #4
McJamie
STROMINATOR
McJamie's Avatar
Oddometer: 1,389
KZ650 CSR. The one that had the cross-over exhaust.
If you get far enough away, you'll be on your way home.
Piss off, I'm in my Happy place.
McJamie is offline   Reply With Quote
Old 12-11-2012, 05:15 PM   #5
Lee F
Lee F's Avatar
Oddometer: 54
KZ 650 SR or CSR as mentioned above.
Lee
2011 K1300S
Lee F is offline   Reply With Quote
Old 12-11-2012, 06:14 PM   #6
Stubanger
Oddometer: 5
You could drill the cylinder of the lock. Use a small drill bit e.g 1/8 or smaller and gradually work your way up until a screwdriver will turn it.
I dont think you could open it through the petcock without accidently denting the tank or theres risk of ruining the lock by belting it open. Good luck
Stubanger is offline   Reply With Quote
Times are GMT -7.   It's 09:38 AM.
