Old 12-12-2012, 02:18 PM   #1
TimothyCaseTimothy OP
Oddometer: 500
Another Audi Allroad Question
Oh, the battery in my 2002 Audi Allroad seems to not have much cold cranking capability...went to look for the manufacture date of the battery and all I found were some numbers...I understand that there's a format for figuring out the date, but I can't quite figure it out...
Would love to just pull the battery out and take a better look, but it seems as though I have to remove the windshield wiper in order to get it out (of course)...
Here's what I found on the top and whaddy'all think?
ST00978573
000915105AH (think that's the part number)
VA00402092237
00975631
Thanks, as always!
Tim
TimothyCaseTimothy is offline   Reply With Quote
Old 12-12-2012, 02:49 PM   #2
terry.mc
Stop ruining my vacation
terry.mc's Avatar
Oddometer: 5,714
ST00978573
VA00402092237
00975631
Thanks, as always!
Tim
You might be able to just throw it on a charger and re-evaluate on the next cold morning. Manufacture date might not matter if it can't pull the amps when it's cold.
Terry Mc
2010 KTM 530 Six Days
terry.mc is offline   Reply With Quote
Old 12-12-2012, 02:51 PM   #3
Oddometer: 500
I've put it on a battery tender and it definitely starts better with that...fine voltage at speed, just a sluggish cold start if it hasn't been plugged in...
Took it to Malmart and the cold cranking amps were about 1/3 of what they should have been (this was before I had put it on a tender)...
Old 12-12-2012, 04:16 PM   #4
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,807
Drive it for an hour so you know the battery is as charged as it'll get then have it load tested.
I just replaced my Benz battery - the cold weather (0*f) last weekend finally killed it. Replaced a battery for a client yesterday. A friend had to replace her battery on Monday. 'Tis the season, and I'll bet you're due as well.
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 12-12-2012, 04:47 PM   #5
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,219
My policy is that if there's any doubt whatsoever about a vehicle battery, replace it ASAP and PDQ.
Go price that gold-plated German über-alternator for your Audi, and then ponder the added strain placed on an alternator by trying to stuff electrons back into a dead battery.
There's also the unknown cost and inconvenience -- where will you be when it fails completely?
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 12-12-2012, 05:07 PM   #6
rdwalker
Oddometer: 2,542
... in my 2002 Audi Allroad ...
Now, your question was generic enough for here.
But: you do know there is http://www.audiforums.com/forum/ , don't you? Much more on topic.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker is offline   Reply With Quote
Old 12-12-2012, 05:13 PM   #7
Red J
C'mon, spring!
Red J's Avatar
Oddometer: 781
If this is the result of a load test, then replace the battery.
It is only a matter of time.
01 VFR | 05 950 | 08 FJR
Red J is offline   Reply With Quote
Old 12-12-2012, 05:29 PM   #8
Oddometer: 500
I just drove it over there and they slapped that measuring device on there...not sure if that's a load test or what it was...yeah, I'm a cheap bastard (who owns 3 German vehicles )...time for a new battery!
Old 12-13-2012, 06:02 AM   #9
PMC
riding rider
PMC's Avatar
Oddometer: 873
^^THIS^^
No reason to add extra stress to your expensive charging system which is exactly what your battery is doing now.
Saying that it sounds like you've already taken care of it
PMC is offline   Reply With Quote
Old 12-13-2012, 06:10 AM   #10
A-Bone
Indubitably
A-Bone's Avatar
Oddometer: 12,766
I knew when you were asking about wheel center caps as though this were the first issue you've had with your car that you must have just picked it up and you had only just dipped your toe in the firely pools of hell that is owning an Allroad.... Didn't take as long as I expected...
http://www.advrider.com/forums/showthread.php?t=847981
Hope it works out for you... Audis are great when they are running 100%
A-Bone is offline   Reply With Quote
Old 12-13-2012, 06:46 AM   #11
Oddometer: 500
Haha...so far, so good...fingers crossed...
I've had it for about a year...
Old 12-13-2012, 07:42 AM   #12
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,175
Replace any leaking air suspension struts as soon as you can. Leaks cause the compressor to run all the time and it will quit and cause more expense. There is a secret 40 amp fuse for the compressor under the drivers side of the dash if the compressor quits. Check it first.
Check all the rubber bushings in the suspension for cracks. I replace those on the higher mileage Allroads fairly frequently when they are around 100,000 miles.
I really like the Allroad. I prefer the V8 power delivery but the twin turbo in fun when the turbos spool up.
Oh yeah, to change the drivers side engine mount on the V-6 requires removing the engine.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 12-13-2012, 08:10 AM   #13
Oddometer: 500
Seems like the passenger rear bag was super low on the first very cold morning out here...haven't had any other problems with it...
Old 12-13-2012, 09:33 AM   #14
BCC
I know better
BCC's Avatar
Oddometer: 8,476
I can offer no help at all as I never did any work to my '02 allroad.....but I can say it was an incredibly great car for the 36,000 miles I leased it!
Great car in the snow. Even better going really fast.
Living the fullest life means leaving a history of goodness behind you for others to remember.
Cherish the memories------Ken OBSC
BCC is offline   Reply With Quote
Old 12-13-2012, 04:36 PM   #15
terry.mc
terry.mc's Avatar
Oddometer: 5,714
Audi forums in general suck*. Pretty quick answers here from mostly adult~ish owners that are audi owners. I don't blame the OP at all for posting here instead of there. There are plenty of discussions that are not ADV MC specific here.
*at least that's my experience
Terry Mc
Thread Tools
Times are GMT -7.   It's 12:32 AM.
