Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 12-16-2012, 12:48 AM   #16
trustme OP
trustme's Avatar
Oddometer: 981
Yup , new 5th. The old set were through the hardening. A new AP caliper is on the way for the second disc. I'm not great on brakes either but it used to get pretty squirrely [ is that a word ] when hard on the brakes into the hairpin at HD. A fork brace is in order as well so I'll chase up your BFTP engineer mate. Tim at British Spares tells me there is a kiwi bloke developing new internals for Trump forks, adjustable comp damping on one side rebound on the other, still a few months away.
Twin discs, I'll have brakes for Africa . There will be no stopping me now
trustme screwed with this post 12-16-2012 at 01:00 AM
trustme is offline   Reply With Quote
Old 12-16-2012, 11:46 AM   #17
trustme OP
trustme's Avatar
Oddometer: 981
The last time Winston will look like this, & no clip ons are not coming
In we go
Cross hatching still visible
Running a bit rich especially on the left , look closely at the valves
Oh Oh. Valves have been having a secret rendezvous with pistons
I don't think the valves are too bad, filled the ports up with Kero & they did not leak
Primary drive
Avert your eyes, this is ugly
Winston had developed a serious oil leak. something even a Triumph would be proud of. Finally found it after the BS weekend at HD. The swing arm boss had cracked on the frame spine tube so there was a constant weep. The welder had a crack at it but it was too awkward with the motor in . I applied plastic metal, radiator metal stuff, silicone & black paint to cover my sins, worked well enough for Manfield
Off it comes , sorry crap photo
Old 12-16-2012, 01:02 PM   #18
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,655
Could you not ditch the Oil in Frame tank and fit a separate one where the battery lives? Interesting thats its running rich, thats apparently reduces power...... runs cooler though....
You'll need to break out the solder for doing a piston/valve check on assembly..... won't it be more kissy with your new pistons?
Voltaire is offline   Reply With Quote
Old 12-16-2012, 01:15 PM   #19
trustme OP
trustme's Avatar
Oddometer: 981
If you have a careful look at the pistons in the bores you will see they are like a cock in a sock. Pistons measured 76.35mm & barrels 76.7mm. .Clearance of 0.35mm when it should be 0.127 , could that piston be flailing around in there so clearance goes out the window. Buggered if I know. The head man is checking his settings.
Old 12-16-2012, 10:33 PM   #20
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,569
With 3 keyway camgears you could retard the inlet timing a tad...later closing could give some more top end. Do you still run the breather into the primary case ? I guess the plastic belt must be able to handle the oil....
motu is online now   Reply With Quote
Old 12-16-2012, 10:54 PM   #21
innathyzit
AKA Woodman
innathyzit's Avatar
Oddometer: 1,159
Cut out some emery paper the same diameter of your valves and superglue it to the top of the valve head.
Install barrell and pistons and bring the pistons up to TDC.
Slip valves into guides with the sandpaer on them, but do not fit springs.
Install head and slightly tighten down.
Get electric or air drill and put the protruding valve stem in the chuck and and slowly bear down on top of the piston with drill on a slowish speed to cut valve reliefs on pistons.
Be careful it works surprisingly well and you don't wanna take too much out of the piston.
innathyzit is offline   Reply With Quote
Old 12-17-2012, 12:19 AM   #22
Mark_S
Fair Weather Faggot
Mark_S's Avatar
Oddometer: 1,948
wouldnt just be caused by slightly soft valve springs would it?
These are the best days
Mark_S is offline   Reply With Quote
Old 12-17-2012, 12:53 AM   #23
trustme OP
trustme's Avatar
Oddometer: 981
Thumb
Hi Motu Hi Inathzzz
Thanks a lot for your input & I'm sure I will need more advice but the plot thickens so maybe we will wait a bit before deciding what to do.
BUDGET WOT BUDGET or how a simple low cost mod turns into a minefield
I figured that I would buy a set of hi comp pistons to suit the existing bore, There was bugger all wear , hone marks still there , easy peasy.
The bore size did not make sense , it sat somewhere between 20 & 40'. Tim at british spares had nothing to suit so he suggested I try MAP Cycles
[ www.mapcycle.com ] in the US. Marino , my new second best friend could make no sense of it either. Upshot of all this
1/ Rebore to 40 thou , max oversize, risk of distorted barrels, have to make a torque plate before reboring to stop distortion, barrels not strong very
2/ Resleeve the barrels to std , spendy but problem solved.
3/ Buy new barrels, over $ 1000 when you include new pistons
4/ Do a long rod conversion
New alloy nikasil barrel
forged pistons 10.5 / 1
billet rods longer than standard for more punch out of corners
longer push rods
new push rod tubes
alloy tappet nuts
alloy clutch plate\
You know what I did . I was in too far so I figured I might as well do it once & do it right. I did baulk at the billet crank
The bits are ordered , hopefully the rods ,pistons arrive first so I can get it dynamically balanced to 76% then put the bottom end back together prior to the barrels arriving in 4 weeks. HD on the 7th Feb will be a close run thing
Mean time back at the ranch
The welder & I spent quite some time pressurising the frame & splashing soapy water around looking for bubbles before we were satisfied we had all the leaks. The factory welding was not brilliant
Before
After
I'll do a better a better paint job later ! Yeah right
Twin discs fitted
I will clean up the over spray, no really , I will
Old 12-17-2012, 01:07 AM   #24
trustme OP
trustme's Avatar
Oddometer: 981
Flash brand new Kibblewhite valve springs so I think that is unlikely. we'll check
All the valves , springs , guides & seats are new & pretty good stuff.
Old 12-17-2012, 11:39 AM   #25
Padmei
enamoured
Oddometer: 3,718
Interesting stuff trusty. Wish I could offer up some advice but i'm still sulking since the war
Padmei is offline   Reply With Quote
Old 01-09-2013, 11:48 PM   #26
trustme OP
trustme's Avatar
Oddometer: 981
Hurry up & wait
Bugger all progress, the wheels are back on , the new RH fork leg is fitted but I am still waiting for the new caliper supposed to be here any day
The motor is a whole different can of worms. Mr MAP sent an email just after xmas, the pistons he had for me were sold by one of his staff so new pistons are 3/4 weeks away, barrel is at the nikasil man . There was an alternative but it would require a bit of machining & the motor would be good for little but racing, with all the shagging around it was probably not going to be much quicker than waiting for the replacement pistons
I've asked them to send everything they can so I can make a start, hopefully stuff will arrive in the next week or so.
Can't see me getting to the festival of speed, can't see the point in putting it back together to pull it down again, it was going to be tight but doable , not very likely now.
Very frustrating
Old 02-10-2013, 12:30 AM   #27
trustme OP
trustme's Avatar
Oddometer: 981
The day before racing & finally the first instalment of bling arrives, not much really but at least I can do a bit now.
Breather kit
I can now drill the front of the crank case & tap for the fitting . I could use the timing plug at the rear of the crankcase & save drilling but the crank rotation kicks oil up the breather pipe, not ideal
Spoofy Alloy Pressure Plate
I can now shorten the clutch push rod & reharden
Bearings
Cam , mains & big ends, athough only 1 x main, I'll source the other locally.
Stuff
Including alloy tappet lock nuts, lighter , more revs doncha know.
Pushrods
I had just put in a set of 750 rods but they are too short for the new barrel, rats !!
Catch bottle
I scoured the camping stores for the right one , in the end my better half found some thing close in a book shop. I have no idea why I did not think of that, Rubbed the blue coating off , drilled holes & coated with POR15 clear coat. You do dumb stuff like that when waiting for parts.
Still no caliper that would be here by Xmas, Barrels are being coated, pistons are being machined , rods, had too upgrade, Some numpty in the US had a problem with the original rods I ordered, they are sure it is operator error but were reluctant to send them until it was all checked out, so they talked me into a new flasher more up spec version,. More money of course but I am getting a good deal on them
It aint much but it is progress
Old 02-10-2013, 02:16 AM   #28
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,569
Wow,nice stuff - I could've bought a nice car with what you spent there. I converted the R65 to open breather today. What do you want the reed valve for ? Triumph got rid of the timed breather in the early '70's and used the chaincase as a breathing chamber. Oh yeah, duh - belt drive primary. The BMW has a reed valve, I'm just using a road tube...I don't like my engines to consume their own waste products.
Old 02-10-2013, 09:29 PM   #29
trustme OP
trustme's Avatar
Oddometer: 981
You are right , costs have got out of hand. I could bugger about & be frustrated with progress or I can spend some pingers up front & build a nice strong reliable motor , still not super powerful but with an ounce of luck it will hold together.
Old 02-10-2013, 10:49 PM   #30
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,655
The two Englander bikes I did battle with at the back of the grid were 650 Triumphs.....you can see one that Bender put up with smoke coming from it.....is it normal mit der English bikes to take the gearbox apart at a race meet?
Looks like yours will be a strong one when its back together.
The Kapiti lads had a good day but they went down on a oil slick ( not mine as I confessed as was in the clear)...
They got it going with begged bits.
Times are GMT -7.   It's 03:48 AM.
