Old 01-09-2013, 04:36 AM   #61
jskene
jskene's Avatar
Oddometer: 192
Originally Posted by JimVonBaden View Post
Hey Jerry, would you controller work with any LEDs, or are there requirements?
Jim
Our IQ-170 intelligent lighting controller works with all LED (and incandescent) auxiliary lamps. It cannot be used with HID lamps, though, as there is no way to dim these.
________________________________________________________________________________
Visibility Lights - P3 Lights and Photon Blaster High Intensity Motorcycle Visibility Lighting Systems: Be Smart - Be Seen
jskene is offline   Reply With Quote
Old 01-09-2013, 05:29 AM   #62
raypitter
Oddometer: 21
Thanx jskene! I am really happy with your controller works. That was unbelievably great.
raypitter is offline   Reply With Quote
Old 01-09-2013, 05:38 AM   #63
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,806
Thanks Jerry!
Jim
Old 01-09-2013, 11:53 AM   #64
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Location: Western NY, further from NYC than 6 entire states
Oddometer: 2,819
Originally Posted by beemerphile View Post
Rigid Industries Duallys or Dually D2's if you are flush.
Just picked up a set from Amazon for $155, they sound like they were an "open package" type return so they knocked $35 off them..SWEET!
PFFOG is offline   Reply With Quote
Old 01-09-2013, 01:28 PM   #65
Urbandrag
KLiM Beotch!
Urbandrag's Avatar
Oddometer: 142
Originally Posted by pffog View Post
just picked up a set from amazon for $155, they sound like they were an "open package" type return so they knocked $35 off them..sweet!
deal of the year!
Diego, a proud 650GS single rida...
Urbandrag is offline   Reply With Quote
Old 01-14-2013, 04:47 PM   #66
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,468
I had pretty bad luck with the advmonster lights, going through about 5 of them on my Dakar and TDM900 till the warranty support ended after about 10 months. Some lasted less than a week, others a few months but in the end they all stopped working.
Since then I switched to Piaa LP530 leds and have had zero issues. They are also backed by a 2 year warranty, if it breaks Piaa will replace it. Besides reliability, the other nice thing about these that the leds are aimed backward into the multidirectional reflector, producing a precisely focused beam that can be aimed so it doesn't dazzle oncoming traffic, unlike most LED lights. $209 complete with a Piaa harness at Amazon. http://www.amazon.com/PIAA-5372-530-...sim_sbs_auto_2
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 01-14-2013, 07:38 PM   #67
JimVonBaden OP
"Cool" Aid!
Oddometer: 53,806
What happened to them? I have a set I just mounted, and am now a bit concerned.
Jim
Old 01-15-2013, 03:37 AM   #68
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,468
Jim
I'm not sure what exactly caused them to die because I was never told what they replaced when I sent them in for repair. I had them wired through quality (Hella and Piaa, respectively) harnesses to go on with the high beam on both my TDM900 and my Dakar. Despite being used infrequently (I live in an urban area), they would suddenly just die without warning. The leds are wired in seriesl, so if one stops working they all go out. My friend with an FJR had a similar problem, and managed to fix one light by harvesting an LED off a dead light that I gave him once my warranty suddenly vanished.
Others might have better luck with them, but based on my experience I've decided to stick with well known name brand led lights, which surprisingly turned out to be in the same ballpark price-wise and are backed by solid warranties. In addition to the aforementioned Piaas, Rigid Industry Duallys sell for $190 a pair with a wiring harness, http://www.amazon.com/Rigid-Industri...eywords=dually.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider screwed with this post 01-15-2013 at 03:41 PM
Old 01-15-2013, 07:38 AM   #69
worwig
Oddometer: 1,277
The leds are wired in parallel, so if one stops working they all go out.
What?
Hog mountain Weather
worwig is offline   Reply With Quote
Old 01-15-2013, 07:40 AM   #70
worwig
Oddometer: 1,277
$209 for just 6 watt lights isn't in the "reasonable price" category IMHO.
Old 01-15-2013, 07:46 AM   #71
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,892
You mean they're wired in sequence.
Parallel means each individual bulb is wired separately to the power source and if one goes out, it doesn't affect the others.
That sucks if they're wired in sequence. A string of Christmas tree lights aren't even wired that way anymore.
Every saint has a past and every sinner has a future.
If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl.
Xeraux is offline   Reply With Quote
Old 01-15-2013, 08:50 AM   #72
duck
duck's Avatar
Oddometer: 10,403
Originally Posted by Xeraux View Post
You mean they're wired in series.
/Klay
duck is offline   Reply With Quote
Old 01-15-2013, 09:05 AM   #73
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,265
I emailed you what was replaced on the lights. An led cluster on one and a driver board on another.
I think you meant to say series? The design has changed, the leds are in parallel now.
The lights JimVonBaden bought where $108 for a pair, not really in the same price range as the other lights.
The lights you purchased and all of our current designs are of a much improved design than our older 24 watt lights (what twinrider had). The lights are backed up by our 1 year warranty.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 01-15-2013, 09:29 AM   #74
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,892
Originally Posted by duck View Post
/Klay
Nope. That wasn't a misspelling. While it may not be the industry standard term, it may be technically correct.
Old 01-15-2013, 10:46 AM   #75
mwood7800
Oddometer: 611
I bought my lights here 4 months ago. Still happy. 170 for a pair https://www.teslaleds.com/default.aspx
mwood7800 is offline   Reply With Quote
Times are GMT -7.   It's 11:16 PM.
