Old 02-06-2013, 02:49 AM   #106
falcore
Oddometer: 10
Originally Posted by genka View Post
They seem to be very similar to these lights http://www.aliexpress.com/store/prod...734264876.html
ive got the 10w solstice led pod. they look exactly the same tbh.
work has run em for a few years so not sure who copied who. they're not cheap though at $130 each
here for a good time
falcore is offline   Reply With Quote
Old 02-10-2013, 03:15 PM   #107
Unstable Rider
10,000 Lakes
Unstable Rider's Avatar
Oddometer: 2,584
Great original post.
I am the first KLR pilot here?
I went with Sanjoh's ADV Monster lights. The single beam version, I keep em pointed downward slightly.
Could not believe how pale and yellow my stock headlight is in comparison (even on high beam).
When I am watching for deer, wolves or MOOSE in my state, I want all the bonus points I can have access to.
No dimmer, just went with my favorite ten dollar handlebar mounted switch that is GREAT.
Pay the extra for the heavy duty bracket that Sanjoh sells, it's great.
Link to switch below.
On a second gen KLR, there is a sweet spot just inside the lower fairings, right where it comes to sort of a point in the plastic, right INSIDE or behind that area. I took my lowers off and scuffed the area with sandpaper and degreased it. I had lathe access then, and I turned some aluminum "discs" and tapped them 1/4 = 20 (material just under 1/2 inch thick).
I used JB Weld and "stuck" the discs into that sweet spot. I put the bike back together and used a Allen head stainless bolt through Sanjoh's bracket into my aluminum round discs. I had custom ground the bolts so they could not pop out the sides of my lower shrouds.... you could replicate this with some square material as well, as long as it's thick enough to drill and tap. Make sure your bolts ain't too long!
Worked for me. They are tucked out of the way, and it's hard to see how they are mounted . Lots of people ask how I mounted them when they see the bike.
Tusk Universal On/Off HANDLEBAR mounted Switch | ATV | Rocky Mountain ATV/MC
http://www.rockymountainatvmc.com/p/...-Switch/switch
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 02-11-2013, 03:05 PM   #108
SilveradoTX
SilveradoTX's Avatar
Oddometer: 61
This has answered a question I've had for a while, and I have to admit, several of these photos sure make the case for adding aux lighting.
I do have a couple more, though. Do most of you alread have an aux light circuit? If not, where/what are you wiring into?
2007 Buell Lightning XB12Scg
Lunasee. Be seen.
SilveradoTX is offline   Reply With Quote
Old 02-11-2013, 03:09 PM   #109
Unstable Rider
10,000 Lakes
Oddometer: 2,584
I tapped into a known "keyed" wire behind my gauges.
On and off with the key if I forget the switch. It's also fused. On a 2nd gen KLR, it's the infamous "brown wire" behind the gauge pack.
~Butch Cassidy
Old 02-11-2013, 03:54 PM   #110
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 466
I wanted my driving lights to come on with my low beams, and to have the option of turning these off via a switch on the controls. I wanted my spots to come on with the high beams only.
The way to do this is to power a couple of relays from the battery with an inline fuse. The relay is switched with the power from the respective headlamp, but the aux lights are powered directly from the battery via the relay. For my driving lights, I interrupted the power from the headlamp to the relay with a lit rocker switch installed in the left switchgear housing.
I installed two sets of lights that I wanted to control independently, so that's why I used two relays. One set of lights, one relay.
Hope this helps!
ElMartillo is offline   Reply With Quote
Old 02-11-2013, 03:57 PM   #111
Unstable Rider
10,000 Lakes
Oddometer: 2,584
This fellow has some relay harness stuff already wired, for those that need a bit of assistance with the order of things. He has a great reputation.
http://www.easternbeaver.com/Main/main.html
~Butch Cassidy
Old 02-12-2013, 05:17 PM   #112
Joetool
Oddometer: 152
I'm thinking of getting these:
http://www.aliexpress.com/item/Free-...618144116.html
If you search around Aliexpess, you can find all kinds of led's.
search for ' led work lights', or 'led tractor lights' ; serches for led car or truck turned up primarily decorative stuff.
Make sure you click the 'free shipping' box.
You can get the lights like ElMartillo has at: http://www.superbrightleds.com/cat/s...od-worklights/
searching Aliexpress I found 20-60-120 patterns for the same lights...
and these look like sanjhs or whatever 's lights: http://www.aliexpress.com/item/DHL-F...748682490.html
Joetool screwed with this post 02-12-2013 at 05:28 PM
Joetool is offline   Reply With Quote
Old 02-13-2013, 03:36 AM   #113
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,892
Yeah. I have a feeling there's probably only a couple of different manufacturers of these lights and the same lights are being sold by a dozen different vendors.
Every saint has a past and every sinner has a future.
If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl.
Xeraux is offline   Reply With Quote
Old 02-13-2013, 06:01 AM   #114
worwig
Oddometer: 1,254
They claim 16 watts from 4 LEDs. 4 watts each. Then near the bottom, they claim 3 watt LEDs. I suspect the system is closer to 12 watt total.
$69 for about 12 watts. And they are hopefully running them a bit conservatively at closer to 10 watts. 8 degree pattern. Mediocre IMHO.
Or you can get this:
http://www.ebay.com/itm/310568041747...84.m1439.l2649
$23 for 15 watts (I found that they are actually closer to 10 watts). 10 degree pattern. Good light. Not built real well. You should spend time sealing this housing around the mounting screw and wire entry point. But I'll bet this light output is very close to the one you point out.
Or for serious light, this:
http://www.amazon.com/gp/product/B00...ls_o03_s00_i00
$25, 27 watts (I found to be closer to 21 watts). 30 degree pattern. A bit wide, but I prefer that to too narrow. Awesome amount of light from these. I can see dark objects ahead at night about 21 seconds at 45 MPH. These are built very well. For less than half the $69, you get a LOT more light.
Hog mountain Weather
worwig screwed with this post 02-13-2013 at 07:01 AM
worwig is online now   Reply With Quote
Old 02-13-2013, 01:26 PM   #115
Joetool
Oddometer: 152
Although it says 3 watts, it also says 4 watt crees. The bottom text was on a lot of similar lights. Chinglish. If the're driving 4 watt crees at 80-90% efficiency, that would put them close to 2000 (combined) lumens which is plenty for me...
Old 02-13-2013, 09:09 PM   #116
andrewhtf
andrewhtf's Avatar
Oddometer: 127
Sharing my lights. I believe it is the same ones from this Sanjoh guy all of you are talking about, although i bought it from another seller in eBay. Came across these lights after reading farklemyride blog.
With low beam. Can only see about 5-6 meters ahead
With high beam. Further throw.
Low beam with led lights on.
High beam with led lights on.
High beams.
A comparison with Rigid Industries's Dually that i had for a short while few months ago.
andrewhtf screwed with this post 02-14-2013 at 11:18 PM Reason: Resize photos, last 2 images can be clicked for original resolution
andrewhtf is offline   Reply With Quote
Old 02-13-2013, 10:01 PM   #117
Joetool
Oddometer: 152
HOLY GIANT PHOTOS BATMAN!!
Old 02-14-2013, 08:28 AM   #118
andrewhtf
andrewhtf's Avatar
Oddometer: 127
My bad, must've left out resizing 'em since i was posting using ipad. Will rectify it once i get meself a pc.
Old 02-14-2013, 10:26 AM   #119
genka
SUV hater
genka's Avatar
Oddometer: 1,626
ElMartillo, did you lights come with 3 different lenses or you had to pick one at the time of the purchase? I agree that buying form a local source often makes sense taking into account potential warranty issues. If anything bought in China fails, the only option would be to trash it. Although my lights work fine for almost 2 years in any kind of weather.
I should've keep quiet and ride. A pair or LEDs on one of my lights went out. Fortunately the other 5 are still OK.
Форум мотоциклистов в США http://www.xytopok.net/mvnforum/listthreads?forum=31
genka is offline   Reply With Quote
Old 02-14-2013, 10:31 AM   #120
genka
SUV hater
genka's Avatar
Oddometer: 1,626
I really wanted to quote your post with all supersized pictures
Thanks for shaping. Did you manually set you camera to the same values of exposure, aperture and ISO when shooting output of both lights?
Times are GMT -7.   It's 07:30 PM.
