Old 12-16-2012, 11:31 PM   #1
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 1,103
Steering head bearings.
Looked every where but cant find an alternative bearing part number. Dont want to pay for genuine if possible, So, any one got a SKF or similar bearing number ?
Cheers !
rossguzzi is offline   Reply With Quote
Old 12-17-2012, 09:58 AM   #2
HellsAlien
a has-been that never-was
HellsAlien's Avatar
Location: Baja Sur winter. PDX summer (that's like 6 wks!)
Oddometer: 2,444
Go to the mooseracing.com website. They sell a kit for reasonable price. Possibly CJdesigns too, but not sure, can't remember. Big on line houses should have access to the mooseracing part numbers too.
In my experience these can be hard to find over the counter at bearing houses because of a non-std ID or OD, can't remember now (tequila will do that), but its not you and your searching! Edit: oh i see you are in OZ, no wonder you are having a problema.
"Hells AL is right."Zuber "Bad roads, good people. Good roads, bad people." Mama Espinoza
“Ride first, tart second. Sorry bro but that’s the way it has to be.” Cbrit, 2008
“You gas it where I brake!” trackday passenger, Thunderhill, 2005 "Especially since he's one of the fastest riders on the planet, on any surface!" Earwig, 2014
HellsAlien is offline   Reply With Quote
Old 12-17-2012, 10:17 AM   #3
buzybraza
buzybraza's Avatar
Oddometer: 381
e-bay
There is always the e-bay choice.....
http://www.ebay.com/itm/KTM-950-Adve...7575bf&vxp=mtr
buzybraza is offline   Reply With Quote
Old 12-17-2012, 02:17 PM   #4
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,845
+1 on the Moose. My local KTM dealer stocks these.
If yours doesn't they are in the dealer's aftermarket catalogs.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 12-17-2012, 02:34 PM   #5
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,543
I don't like tequila, so I found them readily available at the local bearing house.
https://www.google.com/search?q=L454...w=1680&bih=918
http://www.garagenight.tv/tag/change...head-bearings/
Edit: I should mention that these two numbers L45449/L45410 make up one bearing.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle screwed with this post 12-17-2012 at 02:43 PM
MortimerSickle is online now   Reply With Quote
Old 12-17-2012, 04:30 PM   #6
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 746
Those guys are a menace, some of their episodes make me cringe!
HeatXfer is offline   Reply With Quote
Old 12-17-2012, 04:47 PM   #7
MortimerSickle
Semi-Adventurer
Oddometer: 12,543
I have watched only the steering head video, and I found it to be informative and well presented.
I don't know about anything else they have done.
G.H.W.S. 1878-1962
Old 12-17-2012, 05:37 PM   #8
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 1,103
I eventually found the info I was after. Those guys are a little rough !
Thanks for your input.
Cheers.
Old 12-17-2012, 08:01 PM   #9
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,180
KTM only has one bearing for all models. It should be easy to find a kit.
"Son, you can't do both"
Old 12-19-2012, 05:01 AM   #10
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,893
Cheers.
Do you have a stock # for SKF? Id like to visit them shortly for the same thing..
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 12-19-2012, 06:42 AM   #11
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 1,103
Timkin L45449
Cheers.
Old 12-20-2012, 11:16 AM   #12
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,178
Welldone.
Great info, good to know. Thnx.
Old 02-04-2013, 11:43 AM   #13
benzine
adv
benzine's Avatar
Oddometer: 188
Removed my steering head bearings for maintenance and found a rubber o-ring on top of the top bearing, it was like broken and sliced. After a quick look at it and the bearing I was asking myself; why does somebody placces a o-ring on that spot, does it suppose to be there.
I'm asking this because the edges of the bearing are to sharp for a o-ring to be there.
Can some-one tell me the contents for only the top steering head bearing?
Cheers
Todo es possible, para nada es seguro!
mooi spul ... hé!
www.lc8.nl
benzine is offline   Reply With Quote
Old 02-04-2013, 05:11 PM   #14
go2cnavy
Dont Worry Be Brappy
go2cnavy's Avatar
Oddometer: 575
Dennis Kirk has the Moose bearings. I just installed some in my 250. It was very easy. https://www.denniskirk.com/moose/ste...prd/505750.sku
Here's a better video. http://advrider.com/forums/showthread.php?t=363572
In the video, the guys reuse the old race to seat the new lower bearing. Instead, I used a large nut with a 1 1/4 inside diameter that slide over the stem to seat the new lower bearing. It was my first time doing a set of steering bearings and it was a piece of cake.
go2cnavy is offline   Reply With Quote
Old 02-05-2013, 04:39 AM   #15
Hipster
Hipster's Avatar
Oddometer: 1,815
The top seal isn't a standard o-ring, it's a special seal, and yes there is a slit in it most likely to help it compress and seal better when the steering head nut it tightened.
If you buy an aftermarket steering head bearing kit both the top and bottom seals are included.
Cheers
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Times are GMT -7.   It's 01:18 PM.
