Old 12-16-2012, 11:42 PM   #1
Konflict Motorsports OP
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 855
F800GS Suspension Solution
Fork Solution:
Konflict Motorsports is proud to announce after over a year of testing we have fully developed a reasonably priced fork solution for the pre 2013 BMW F800GS. As you are aware the BMW F800GS has a limited front fork with a sealed cartridge, small cartridge rod diameter and lacks compression and rebound adjustment. With this somewhat outdated technology making improvements with the stock components are next to impossible other than swapping the springs to a different rate, or playing with different oil viscosities and air gaps.
Well we have a solution for you!
What we offer is known as the "Shiver Fork Conversion" which adds a modern style cartridge along with adjustable compression and rebound adjusters. We custom tailor this package to your weight, riding locations and terrain, riding ability by completing a revalve and installing the proper spring rates.
We have completed close to 2000 miles of testing in various terrains including forest service roads (parts of the Washington Back Country Discovery Route), single-track, sand dunes, desert, highways, freeways, city streets and even rode on a outdoor motocross track with very promising results. To complete our testing we currently have three F800GS completing around the word trips with our fork upgrade and currently have logged over 50,000 trouble free miles at this point and time.
Feature Summary:
Adjustable Compression and Rebound Adjustment
Increases cartridge rod diameter which creates more oil flow
Machining of the lower fork lugs to accept compression adjustment
Custom re-valve to fit your weight, riding style, locations, & ability
Installation of proper spring rate for your weight and luggage
Pricing: $1500.00
Stock Cartridge on the left, updated fork lug and cartridge on the right.
The complete package includes the following items:
Complete cartridges (Cartridge Rod, Cartridge, Spring Guide)
Adjustable Compression & Rebound Adjusters (Fork Caps)
High Quality SKF Fork Seals & Wipers
Updated Fork Bushings
Machining of Lower Fork Lugs
Custom Spring's (Polished)
Custom Re-Valve
Polishing of the Fork Lowers and Internals
Turn around time is about two weeks with an appointment.
Please PM or email Alex@konflictmotorsports.com
You can also visit out website www.konflictmotorsports.com
Shock Solution:
As for the shock of the F800GS, it is set up from the factory to carry a rider weight of 170 lbs. plus 15 lbs of luggage. Most riders rarely fall into this range therefore replacing the shock unit is very common. We have sold and serviced every shock manufactured for the F800GS and now offer the Touratech Suspension product range.
These units are the only purpose built ADV shocks on the market today! Touratech spent a considerable amount of time working with Tractive Suspension to achieve the best performing shocks in our opinion.
There are currently five options available with different features and pricing.
Extreme with PDS: $1795.00
Expedition without PDS: $1495.00
Explore HP: $1095.00
Explore HPe: $1695.00
Explore: $795.00
Feature Summary:
Remote Reservoir, made from high-strength aluminum, keeps the fluid cool and ensures pressure stability in the shock which results in better performance. The reservoir also increases fluid volume by 50% extending the life of your shock.
Available on Expedition, and Extreme.
Adjustable Shock Length, allows 8mm (-4mm to +4mm) of length adjustment to fine tune the ride height of your bike.
Available on Extreme.
Adjustable high-speed and low-speed compression dampening allows absolute control of shock tuning to give you the precise handling characteristics you want in any conditions.
Adjustable Rebound Dampening allows you to fine-tune the ride characteristics to meet your preferences.
Available on Explorer, Explore HP, Explorer HPe, Expedition, and Extreme.
50% more preload adjustment than other shocks on the market. A generous 15mm of adjustment allows proper spring pre-load set-up. Most shocks have 8-10mm which is not enough to accommodate the varying quantities of long-distance luggage or even a passenger.
Available on Explore HPe, Explorer HP Expedition & Extreme.
Hydraulic Spring Preload Adjustment allows quick changes to be made to the preload by twisting the knob with your hand.
Available on Explore HPe, Explorer HP, Expedition & Extreme.
A floating piston separates the air and the oil to prevent oil foaming also known as cavitation. This technology ensures that your shock will have smooth and consistent performance even in punishing environments.
Available on Extreme, Expedition, Explore HP, Explore HPe, Explore.
Cold forged 6082 T6 aluminum shock body machined to exacting standards offers high-strength and maximum heat dissipation.
High-strength stainless steel bushings ensure the mounting points of the shock will go the distance.
Low-friction seal with integrated Teflon back-up ring maximizes performance and extends the life of the shock.
Oversized 16mm high-strength shaft made of chrome-moly steelfor maximum strength and durability.
Available in a range of spring rates to match the rider weight requirements.
Dampening (Valving) set up for fully-loaded F800GS right out-of-the-box.
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports screwed with this post 12-18-2012 at 08:01 PM
Konflict Motorsports is offline   Reply With Quote
Times are GMT -7.   It's 04:03 PM.
