12-10-2012, 03:50 PM
#1 |
Oddometer: 251
Leading leg ideas/pix?
Looking to build some leading legs for my soon to be joined up VL1500/Dnepr combo. No replies to my previous VL1500/Dnepr thread so I'm trying to be more specific.
I'm a small fella (not in the first flush of youth either!) and I just know the thing will have heavy steering. The bike alone is 300kg. My theory is that ditching all the chrome covers- there's even one on the brake caliper, why would you do that???- should save a few kg at least. I'll cut down the mudguards and generally go for a retro look. I live up a dirt road so I'll try for a paint scheme which matches the colour of the dust....desert sand I think. Ural owners might talk to me, I could pass it off as the 2013 Dnepr revival model? I'm doing all this in a very rural part of Portugal so it'll all be my own work. The nearest machine shop is 50 miles away. I'm a bit concerned that the lowers only have caliper lugs I can use on one side- my thinking is a robust hoop over the top which picks up on the fairly beefy mudguard mounts as well. The brakes are minimal already, so I'm planning to run two calipers on the disc. I know heat build up is a consideration but I'm not planning serious Alpine pass storming. I'll be using a sidecar brake and looking for the much better rear caliper from a later bike. Any thoughts? Any subframe examples gratefully received as well. Again under all the tinsel the frame looks well adapted to a fairly small subframe and is certainly strong enough. And the best thing? No matter how badly the thing is set up it can't possibly go round corners any worse than it did as a solo! |
12-12-2012, 08:22 AM
#2 |
Oddometer: 4,139
RR's Catnip Hill to Peoria ___Loopin' Seattle to WestFest It started with some beers __1500 miles to the Dentist Skeedaddle to Seattle______ A 30 year old on a Three Flags Run |
12-12-2012, 10:24 AM
#3 |
Oddometer: 251
Neat and it won't break will it?! Thanks.
Can't quite see how it joins to the U-shaped brace but I get the general idea. 3/8 steel is heavy- what about dural or similar? I used to live near a scrapyard with a titanium bin- we had aerospace companies nearby. That, I guess would be the answer! The suspension is crude enough in reality on the VL1500 that a bit more unsprung weight probably doesn't matter. |
12-12-2012, 11:19 AM
#4 |
Oddometer: 4,139
I don't think it does connect to the fork brace.
As far as being heavy , yeah it is, but as Dave put it don't build anything structual from aluminum, use steel.
12-13-2012, 05:39 AM
#5 |
Oddometer: 251
Looking at it again I can see that it's not joined and doesn't need to be.
Steel it is! I guess the best way to connect it to the fork bottom would be to cut up a spare wheel spindle and thread both parts accordingly. I can save some weight by mounting my dual caliper assembly on a subsidiary alloy plate- all loads should be in the strongest dimension. |
12-16-2012, 01:50 PM
#6 | |
On the wrong planet
Oddometer: 118
Not as good an idea as it sounds. Titanium hasn't got the density of steel. To do this kind of job you'd need it to be close to an inch thick to ensure it wouldn't fracture in use. Titanium isn't as durable in flex tests as as steel. Just thought it should be mentioned. Val.
The land you visit may be a beautiful place with extraordinary views and heavenly skyes, but it's the people of the land that make it truly worthwhile returning time and time again. Ay! and the roads need to be bloody good too |
12-17-2012, 10:53 AM
#7 |
Oddometer: 251
Thanks Val. It's not a wonder material after all!
I based my thinking on seeing quite thin walled titanium shelled blocks on racing yachts handle some astonishing loads (I'm a marine surveyor). But it has to be said steel is easy to work, welds reliably and I've got lumps (mild and stainless 316) lying around in the shed. Choice made then! |
