Old 01-04-2013, 11:10 AM   #16
bluesurf
en dos ruedas
bluesurf's Avatar
Oddometer: 1,000
If additional adapter plates are needed, consider using "mending plates". They are available in several widths and thicknesses & sold at HD in the same section as gate locks/door hardware.
I used two of these to mount an E250 to a generic KTM Adv plate, and it has held up fine for 15K+ miles.
Ride Travel Explore Live
bluesurf is offline   Reply With Quote
Old 01-05-2013, 03:33 PM   #17
jules083 OP
jules083's Avatar
Oddometer: 3,574
Originally Posted by High Country Herb View Post
I think the problem is the metal rack only lines up with the Givi rack enough to give 2 mounting points, with the plastic about 50% cantilevered. An adaptor plate can be made to cover the whole base of the plastic.
I posted my pics to another site that can host them. Here is my home made adaptor plate:
That's the exact issue. I'm going to do what you did. Looks heavy but strong, should never have an issue.
1/4" plate? I should have some here, if not ill go get some.
All typos and misspellings blamed on my phone.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Old 01-05-2013, 06:03 PM   #18
Armydad
Prov. 3:5-6
Armydad's Avatar
Oddometer: 78
Why dont you just locate new holes in the plastic plate where they need to be, and counter sink them with flat head screws? I did this to mine and its rock solid.
No extra hardware, and you can position the box where you want it- back or up, then just drill the correct size hole into your rack and nut it from the underside.
Dont be afraid to drill into the Givi plate. It's a very stable, plastic injected product that's hard to crack. Just dull the edge of your drill bit a little, and it will not grab breaking thru the other side. I used 1/4 inch flat, socket head stainless steel screws from Home Cheapo with lock nuts on my GS and it's been on for a year and half with about 5k miles with no movement at all. Good luck
06 R1200GS
83 Honda Nighthawk 650
2010 KTM 990 Adv
07 FJR 1300
05 HD 883 Sporty
Armydad screwed with this post 01-05-2013 at 06:15 PM
Armydad is offline   Reply With Quote
Old 01-05-2013, 06:21 PM   #19
Armydad
Prov. 3:5-6
Armydad's Avatar
Oddometer: 78
From the bottom, where it needs to mount:
As mounted how it should sit:
This is how u can have it - clamp it into position, drill right thru both the rack and the Givi plate. Just make sure u clear the web gussets in the Givi plate, then counter sink from the top side. You're done.
06 R1200GS
2010 KTM 990 Adv
07 FJR 1300
05 HD 883 Sporty
Old 01-06-2013, 07:46 AM   #20
kantuckid
Oddometer: 2,935
The alu bar stock/2 piece solution already mentioned is the quickest/easiest and will be stronger than the weight capacity of Givi case in 1st place which is not that much. 1/4 plate is overkill.
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Old 01-12-2013, 08:13 AM   #21
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 8,320
I agree. 3/16 plate would be fine. I only used the thick stuff because it was free.
High Country Herb is offline   Reply With Quote
Times are GMT -7.   It's 12:13 PM.
