Old 01-21-2013, 07:23 PM   #151
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,941
I used some of the material given to me to do this:
Raw stock from a generous Kirk!
Going to replace this crap rack and fit this space.
Some of the WORST welds I have ever seen, but they should hold for my
application.
Jim
Old 01-21-2013, 07:39 PM   #152
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,645
Is that aluminum or galvanized C channel??
I sure hope it wasn't galvanized. Zinc doesn't weld worth a shit!
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 01-21-2013, 07:43 PM   #153
JimVonBaden OP
"Cool" Aid!
Oddometer: 53,941
Galvanized. Don't worry, I ground off the galvanized parts I welded, plus welded outside in a breeze and did not inhale the fumes.
Jim
Old 01-22-2013, 05:47 PM   #154
Island Rider
solo adventurer
Island Rider's Avatar
Oddometer: 123
A little welding
New headlight mount to allow aux fuel. 4130 thin walled tubing. Very light.
Island Rider is offline   Reply With Quote
Old 01-23-2013, 08:36 PM   #155
chacha
CAT Herder
chacha's Avatar
Oddometer: 2,750
I made my patio table levitate.
Actually this was the test lift of the hoist I made. I used a boat trailer winch and strap and mounted it in the garage attic. The final plan involves the table being lifted upside down with 4 legs holes cut in the ceiling so that the table sits up and out of the way.
Ducati Hyper 796
chacha is offline   Reply With Quote
Old 01-24-2013, 07:09 AM   #156
kubiak
Oddometer: 4,829
repainted my gs plastics yesterday.
kubiak is online now   Reply With Quote
Old 01-25-2013, 04:48 PM   #157
D.T.
D.T.'s Avatar
Oddometer: 11,645
I left my dome light on last night.
Was going to leave a bit early to get some tax forms and the truck was dead. Check battery voltage, zero. Put charger on battery for about 5 minutes, just clicky clicky. Damn. Tried my SV battery too, no dice. Neighbor comes by and said he seen it on at 4 am this morning and he didn't want to wake me.
Ended up pushing truck back in neutral into the street and the neighbor gave me a jump start. Made it to work. Seems like just getting to work nowadays seems to be a big PITA.
Anywho, just went out and the truck started up, so I hope I didn't fry the battery.
Old 01-25-2013, 08:40 PM   #158
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,280
finished the bottom end of an 1973 mx250 i'm rebuilding. took cylinder to my bore guy and decided to rebore - it's just at the edge of wear limit. just waiting on piston now.
finished the top end of a maico 400 motor that's been on the bench FOREVER while i waited for a con rod to show up. and mounted motor in a roller. have to work on the compression release and rework the chain tensioner tomorrow. maybe fire it up sunday/monday..
dicked around with a seized linkage bolt in a 1996 yz250. got frustrated with it - letting it sit for a day or 2 then tearing the back end apart to get a better look at it.
oh and did some bolty town stuff.
current bikes
stainlesscycle is offline   Reply With Quote
Old 01-26-2013, 08:18 AM   #159
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,628
Originally Posted by chacha View Post
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 01-26-2013, 07:32 PM   #160
Disco Stu
I'm Barry F'n Gibb!!
Disco Stu's Avatar
Oddometer: 5,413
pulled the flywheel out of my K1200RS to get that leaking rear main seal out. replacement parts should be here on wednesday.
Disco Stu is offline   Reply With Quote
Old 01-26-2013, 09:10 PM   #161
JimVonBaden OP
"Cool" Aid!
Oddometer: 53,941
A little more on my rack.
I also helped a friend mod his HF tire changer to work on his HF lift like mine.
Jim
Old 01-26-2013, 09:39 PM   #162
kioti
Cruzinonline
Oddometer: 193
Couldn't get to sleep earlier so I went back out to the shop and mounted a oversize tank and installed a LED tail light on a friends XR .
Drinking beer now.
kioti is offline   Reply With Quote
Old 01-27-2013, 12:20 PM   #163
JimVonBaden OP
"Cool" Aid!
Oddometer: 53,941
Finished up my corner rack:
And all loaded up:
Jim
Old 01-27-2013, 06:22 PM   #164
Bart
Constant Lurker
Bart's Avatar
Oddometer: 2,962
Changed an upstream o2 sensor kn the Expedition and swapped some coils around. Still has the damn miss. so I guess it is an intake manifold gasket now! :angry
Originally Posted by Gravity's Dog
"I came to the site for the bikes, and stayed for Jo Momma. I am constantly amazed, revolted, and in love with the ideas I see here. An extreme reflection of the human experience."
Bart is offline   Reply With Quote
Old 01-27-2013, 06:43 PM   #165
Reverend12
Well there it is..
Reverend12's Avatar
Oddometer: 1,465
Washed my Bikes..
Reverend12 is offline   Reply With Quote
Times are GMT -7.   It's 10:12 AM.
