Old 02-24-2013, 03:53 PM   #241
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,929
Wired up my fuzebox.
The plan.
The execution.
Marked.
Hidden location on the R1200GS 05/06.
Jim
JimVonBaden screwed with this post 02-24-2013 at 06:33 PM
Old 02-24-2013, 05:12 PM   #242
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,792
Awesome diagram JV. Where'd you get the fuse block?
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is online now   Reply With Quote
Old 02-24-2013, 06:32 PM   #243
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,929
www.cyclenutz.com
Tony is an inmate here, and good people!
Let me know if you have any special accessories. I can make you a custome wiring diagram. Basic but easy to follow.
Jim
Old 02-26-2013, 12:42 PM   #244
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,792
Originally Posted by JimVonBaden View Post
www.cyclenutz.com
Jim
Thank you very much. Presently I have only a 12v plug outlet for my GPS but plan on adding a set of lights soon.
That is after the install of the new Wilbers front and rear, new Anakee3 tires, FD and oil/filter fluid changes. Thanks for the DVD by the way
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
Old 02-26-2013, 01:03 PM   #245
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,929
My pleasure.
Jim
Old 02-26-2013, 03:06 PM   #246
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,341
www.cyclenutz.com
Jim
Jim, do you prefer that over the Eastern Beaver?
Current Steed: '08 FJR1300
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
EvanADV is offline   Reply With Quote
Old 02-26-2013, 03:14 PM   #247
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,286
(Careful, Jim! Your answer is to "Do you prefer cycle nutz to eastern beaver?" might have repercussions in Jo momma!)
I put the rear wheel back on the Softail. God bless the motorcycle jack! Much easier than trying to hold or wedge up a heavy ass wheel and thread an axle through the swingarm.
HapHazard is offline   Reply With Quote
Old 02-26-2013, 03:37 PM   #248
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,929
It depends. The EB unit has a need for an external relay that takes up more space and adds complexity. For some this is a good thing because they are comfortable with the added wiring, and they need the added capacity. The EB kit is very high quality, and I like a few of its features a bit better, like the basic mount system.
Needs both to used switched power.
However, I think the Fuzeblock is simpler and has plenty of capacity for most users, especially with much of the Aux lighting going to low draw LEDs these days. The FB also has the capability of choosing how many of your circuits have switched or batter power by simply swapping the fuse from one terminal to the other. In the unlikely event of a relay failure the FB allows one to go battery power to all circuits, where the EB unit is limited to two! The other benifit of the FB is that it is simpler for novices to install.
Simple, small and clean.
Hap, Jo momma already has my number, I doubt it could get much worse!
Jim
Old 02-27-2013, 06:12 PM   #249
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,929
36K service, which is all fluids including brakes, valves, alternator belt and throttle body sync.
A little corrosion repair as well.
Jim
Old 03-01-2013, 08:43 PM   #250
kubiak
Oddometer: 4,829
put a supertrapp exhaust on my f650gs today. man that thing sounds mean!
Old 03-03-2013, 02:33 PM   #251
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 11,182
Went for a ride today. Noticed the RH grip warmer was not working. Stopped at gas station and saw wire was damaged to grip. Got home, removed grip then removed heat element. Cut wire back, desoldered from heater and resoldered new larger wires back onto element. Solder new wires to old wires and tidy up wiring.
Back to nice N toasty!
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 03-04-2013, 10:05 AM   #252
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,341
'Nuff said, i'm certainly a novice.
Old 03-04-2013, 02:36 PM   #253
kubiak
Oddometer: 4,829
today im trying a stock yz450f muffler on the dakar.
Old 03-04-2013, 09:51 PM   #254
ShadyRascal
Master of None
ShadyRascal's Avatar
Oddometer: 6,562
I made SteverStoves with a damn dislocated shoulder and fractured humerus. That was pretty fun.
Originally Posted by Javarilla
Evolution, or, natural selection, has nothing to do with better.
It merely weeds out what is no longer suitable for the given context.
Originally Posted by Dragoon
I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle.
ShadyRascal is offline   Reply With Quote
Old 03-04-2013, 10:24 PM   #255
Comrade Art
Working stiff
Comrade Art's Avatar
Oddometer: 549
Removed the carburetor for servicing.
Photo & Video Sharing by SmugMug
Vietnam Adventure
Oregon BDR
"All human beings by nature desire to know" - Aristotle
Comrade Art is offline   Reply With Quote
Times are GMT -7.   It's 09:36 AM.
