Old 04-17-2013, 11:03 AM   #331
Boojum
I Miss the PartyBoss
Boojum's Avatar
Oddometer: 5,967
In the middle of a front end swap on my XR650L.............. Pulled off the old.....
.......and will be mounting these on it next, off a CRF 450 Revalved and Sprung, and ready to go......
Boojum
"I aint no ruff guy, aint no tuff guy. Don't get out much, and don't dress up fly".......
Boojum is offline   Reply With Quote
Old 04-17-2013, 04:51 PM   #332
Aanarchy
Aanarchy's Avatar
Oddometer: 1,142
Very nice. And that is a seriously clean looking bike.
Boojum
Maybe it was Utah. - H.I. McDunnough
Aanarchy is offline   Reply With Quote
Old 04-17-2013, 06:07 PM   #333
MCCOYBOY
Oddometer: 99
Carb cleaning
Cleaned a few KTM carbs that arrived in the mail.
Before
After
Before
After
MCCOYBOY is offline   Reply With Quote
Old 04-18-2013, 04:56 AM   #334
mcma111
mcma111's Avatar
Oddometer: 12,928
Originally Posted by MCCOYBOY View Post
What did you use to get the carb so squeaky clean??
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-18-2013, 05:13 AM   #335
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,576
Finished my Tire Pressure Monitoring System for my GS.
Broke down the wheels and tires and added the new sensors. They double as valve stems.
I like that you get instant pressure and temps of each tire.
Jim
Old 04-18-2013, 07:00 AM   #336
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 2,054
If only the Orange system was about 25% of its size.
I love the idea, but don't need a display so huge.
Looks good though!
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 04-18-2013, 10:45 AM   #337
JimVonBaden OP
"Cool" Aid!
Oddometer: 54,576
Looks good though!
I would like it about half that. Too small and it would be hard to read. I had a different one on my other GS (Smartire), but it was not as user friendly.
You could put the screen down below the cluster. Less obtrusive, but a bit harder to see.
I do like the OEM style sensors though. Nice easy install.
Jim
Old 04-18-2013, 07:13 PM   #338
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,360
Originally Posted by JimVonBaden View Post
I had to look twice, Jim. I thought you had a keyboard installed on your tank under the radio shack.
(A blank line or two wouldn't hurt a bit).
HapHazard is offline   Reply With Quote
Old 04-18-2013, 07:40 PM   #339
MCCOYBOY
Oddometer: 99
Ultrasonic cleaner with pinesol at 50/50 mix at 165 degrees.
Old 04-18-2013, 08:31 PM   #340
JimVonBaden OP
"Cool" Aid!
Oddometer: 54,576
I'll keep that in mind!
Jim
Old 04-18-2013, 08:32 PM   #341
JimVonBaden OP
"Cool" Aid!
Oddometer: 54,576
I completed a 36K service on my friend's R1200GS Adventure following the clutch swap.
It included the oil, trans oil, final drive oil, clutch flush, brake flush, alternator belt, spark plugs, air cleaner and valve adjust. Now to hook up the computer, reset the service reminder, adjust the throttle bodies, and put on a few pieces of trim.
If the dealer had done this the guy would have paid around $2800. It cost him $325.
Jim
Old 04-18-2013, 09:52 PM   #342
victor441
victor441's Avatar
Oddometer: 1,042
auto wheel alignment...
Did a DIY wheel alignment check, found lots of good info on the web...one especially helpful idea was to use EMT conduit (very cheap) for crossbars at both ends of the car and drill holes through it for the string perimeter used to establish a rectangle for reference, worked great. The Hot Rod article w/ the conduit idea and much other alignment info is at http://www.hotrod.com/techarticles/c...e/viewall.html
victor441 screwed with this post 04-19-2013 at 01:38 PM
victor441 is offline   Reply With Quote
Old 04-19-2013, 04:47 PM   #343
JimVonBaden OP
"Cool" Aid!
Oddometer: 54,576
Replaced the seal on my friend's bike:
Washed it and set it aside for him to come pick up.
Cleaned the garage in prep for the tech day next weekend.
Jim
Old 04-19-2013, 06:32 PM   #344
MCCOYBOY
Oddometer: 99
Fuel Injectors
Got a few Ducati fuel injectors in the mail today and cleaned and tested them.
Old 04-19-2013, 06:44 PM   #345
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,828
Not in the garage per se, but since its out in front AND I'm tickled:
Gummee! 1
Mouse 0
Finally got the little SOB that's been living in my engine compartment. Needed to look up the OEM part # for the engine wiring harness and finally saw where its been living.
Set a trap, then went for a bicycle ride. 3hrs later I get back to a whacked mouse in my trap.
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Times are GMT -7.   It's 12:17 AM.
