Old 02-22-2013, 09:25 AM   #106
leafman60 OP
Oddometer: 1,807
Oh well.
Escher is in good ole Deutschland. Anyplace in US experienced with this ? I doubt it since so few NuFalcs here.
If I were going to have this work done, Id rather someone do it that has done it before.
Lord lord.
Tell me about the oil pump, Hubert.
leafman60 is online now   Reply With Quote
Old 02-22-2013, 11:23 AM   #107
huub
Oddometer: 139
Originally Posted by leafman60 View Post
Oh well.
Lord lord.
the oil pump from a twin is pretty similar,
the good thing is the gears are 2 mm wider , resulting in 15% more capacity.
i use aftermarket pumps with 4 mm wider gears ( 16 mm instead of 12 mm wide , resulting in 30% more capacity
the t3 pump has a proper needle bearing , due to the lack of bearing the falcone pump tends to wear out early.
as you can see on the pic the mounting holes on the falcone pump on the right are smaller than the T3 pump on the left
i made a plugs to press into the t3 pump mounting holes, and redrilled the holes, using the falcone pump as a guide.
the other difference is the end of the oil pump shaft,
on the falcone pump it is a taper , on the T3 pump a straight shaft
i weld up the hole in the falcone gear , and turn up a nice straight hole in the lathe, if you dont want to weld your precious gear you might get away with using a tapered bush.
i enjoy using the lathe....
huub is offline   Reply With Quote
Old 02-22-2013, 06:10 PM   #108
leafman60 OP
Oddometer: 1,807
What aftermarket pumps? I saw something like that on german ebay, I think.
Old 02-23-2013, 01:51 AM   #109
huub
Oddometer: 139
that is extactly the ones i have been using
http://www.ebay.de/itm/MOTO-GUZZI-Ol...-/160865867818
Old 02-23-2013, 03:14 AM   #110
leafman60 OP
Oddometer: 1,807
Quote from Huub on another site-
...any proper machine shop should be able to fit a couple of valves .
i ended up with home made guides, fiat ( truck) valves, enfield bullet
valve springs, retainers and collets , and ducati lash caps.
or you can buy the complete set from escher.
How about a link to the recommended valves, guides and retainers? I can't find them on the Escher site. Looks like they are selling a 7mm valve stem set-up?
leafman60 screwed with this post 02-23-2013 at 03:21 AM
Old 02-23-2013, 09:04 AM   #111
huub
Oddometer: 139
escher doesnt list them on their website but does the conversion,
the ad on ebay is from MTR ricambi, another german firm,
http://www.mts-ricambi.de/html/nuovo_falcone.html
sending a head over is a bit unpractical , but i think they can be persuaded to sell you just the parts. so you can have them fitted locally.
i see they have a 7 mm and a 8 mm setup.
i have not seen the 7 mm setup yet.
7 mm would have the advantage you can get away with even softer springs.
Old 02-24-2013, 06:12 PM   #112
leafman60 OP
Oddometer: 1,807
Hubert's advice cross-posted from google
______________
i didn't bother changing the seats , they seem to last pretty well.
you might get away with the old oil pump if it still is in good shape.
______________
______________
on my falcone it was just the valve head snapping off.
the damaged piston is the result of valve head rattling around in the
combustion chamber.
nothing wrong with the seat , i didnt need to change it, and it is
still in there 40.000 km after the blowup.
apparently the valve issue is lack of lubrication of the camshaft , so
the opening ramp wears away
as a result the valve is violently slammed open.
due to the vertical valve guide the exhaust valve guide hardly gets
any lubrication and wears out , causing the valve to slam on the seat
while it is not properly centered , causing a bending force on the
valve.
the guide was pretty worn when i had the valve snap.
all this together with heavy valves and way too strong valve springs,
something has to give.
( i am not making this up myself ,a couple of guys from the german
falcone club found all this out , i consider them the experts.
looking at what happened to my falcone , i think they might be right)
the valve seat issue is a different issue
some heads are soft , and deform under the head studs .
those are prone to have loose valve seats.
i have one of those heads too, it took ages to get it off the engine ,
the casting around the head stud had deformed to the point it closed
up on the threads.
now the biggest question, is your bike likely to have valve problems?
who knows?
personally, after having one of my engines blow up 200 km from home i
prefer to be cautious.
i enjoy riding my classics as much as i can , i have no use for a bike
wich i cant rely on.
i change valves and - springs on every falcone i work on.
if i end up throwing away 150 euro of perfectly good parts i consider
it a small price to pay for my peace of mind.
after the mods i consider the engine bulletproof , i dont hesitate to
ride it as fast as it will go.
cheers,
hubert
___________________
Old 03-02-2013, 09:52 AM   #113
Hippodan
Hippodan
Oddometer: 9
Nuovo Falcone in Ontario
Hi Leafman,
I am the owner of the blue Nuovo in St. Catharines, Ontario. We exchanged emails way back when I had mine on eBay. It didn't reach reserve, although a fellow from Australia was very interested and almost bought it. The problem with eBay is that it doesn't give you a chance to wheel and deal with the interested parties off eBay. In response to someone's comment: yes, it is the bike that was at Blue Moon Cycles some time ago.
I remember seeing your bike on eBay last year when you bought it. I'm glad it worked out good for you. Did you fix the scratch on the tank yet? I see you use a tankbag that hides it anyway, that's a great idea.
Back then I was surprised to see a different muffler than what I got on mine... didn't know they came that way from the factory.
Mine is still for sale, $6,500, if anyone is interested, but I'm not in a hurry, it's a great bike to ride around locally. I got too many bikes, I'm getting old, insurance is terribly expensive in the Great White North.
As you said in your report, and I fully concur, it's very relaxing and fun. The picture someone posted of the bike was in Buena Vista, VA, at the National Guzzi rally last year. It was great riding it around the Parkway. I also had my Convert there, but it was in the de-bugging stage, and left me stranded just outside the town, on the highway, at noon, in 103F. Had to get AAA to bring me back to the park. It was a loose crimp connection at the battery post... I have since soldered all the crimp connectors on the bike!
Cheers,
Dan
Hippodan is offline   Reply With Quote
Old 03-02-2013, 10:11 AM   #114
leafman60 OP
Oddometer: 1,807
Hey Dan. Hang in there. Takes time to sell things sometimes.
Yes, I've enjoyed mine so far. Havent done much to it. It is all-original paint etc so I hate to mess with it too much.
Regarding the different mufflers (and the tank), I'm sure you know that mine is the Civile (Civilian) model for '74 that came with those items.
Why dont you just hang on to that thing, man ? They are so rare, you will have a helluva time finding another one in North America.
Are you coming down for Daytona Bike Week? Gonna bring it ??
leafman60 screwed with this post 03-02-2013 at 02:53 PM
Old 03-03-2013, 05:39 AM   #115
Hippodan
Hippodan
Oddometer: 9
I am in no hurry to sell, really like this machine, and you are right, I'll never find another one. But I'm getting long on the tooth, and I'm getting tired of the upkeep of so many bikes and cages.
I thought about Daytona, it's been 3 years since the last time, but maybe it will be next year. I'm getting ready to head down to Arizona beginning of April for two weeks riding down there on a GW. I think it's going to be great.
Where abouts are you located?
Old 03-04-2013, 05:29 AM   #116
leafman60 OP
Oddometer: 1,807
A Gold Wing ?????? Boy, that's a helluva contrast with the NFalcone
Im on the gulf coast just outside Pcola FL but in AL
Old 03-05-2013, 10:04 AM   #117
Hippodan
Hippodan
Oddometer: 9
Too bad you are not closer to Phoenix, where we'll be based out of. It's a rental, not mine. I have an 84 Aspencade, at home, which I seldom use anymore. Mostly ride or trailer my 76 convert to MG rallies, they have the nicest people around. Just got it to the point of being mechanically solidly reliable, but cosmetics need lots of work/money, so that will wait, if ever. I don't mind looks, as long as my bikes take me there and bring me back.
The wife doesn't like the NF, the pillion seat is not very comfy.
The front seat is amazingly comfortable, very similar if not identical to the police solo seats on the Ambo and Eldo.
Cheers,
Dan
Old 03-06-2013, 12:36 PM   #118
Andy-Gadget
Any bike can go anywere
Andy-Gadget's Avatar
Oddometer: 1,351
Better photos of the zero kilometer NF that is now fully paided for
The red points cover is already changed for a standard alloy cover, came standard with the civilian air filter, very happy with the bike.
"If a man empties his purse into his head, no man can take it away from him.
An investment in knowledge always pays the best interest"
Benjamin Franklin.
'95 Sport 1100 Guzzi,'84 Cali 2 Guzzi, '95 Guzzi mille, '84 R65LS, '84 R100, '82 R100RS, '05 DL650, '72 Bultaco Sherpa T 350, '78 Montessa 348, "00 XR650R
Andy-Gadget is offline   Reply With Quote
Old 03-06-2013, 01:11 PM   #119
huub
Oddometer: 139
interesting bike , a police bike with dual seat and no rear footrests,
civilian air filter and no pinstriping in mudguards and tank.
never seen one of those
Old 03-06-2013, 07:35 PM   #120
leafman60 OP
Oddometer: 1,807
Awesome bike !
Looks to me like it may have been re-painted ex-factory ?
The red points cover and the decals don't strike me as something done at the factory. Also, the paint looks almost like clear-coated. Not knocking it. Just wondering.
Could this have been a custom paint job done for/by the fire department? Never heard of or seen a factory-made fire department bike.
Also, those turn signals. I wonder if they were an add-on.
leafman60 screwed with this post 03-08-2013 at 06:08 AM
Times are GMT -7.   It's 06:35 AM.
