Old 12-19-2012, 05:52 PM   #1
foxtrapper OP
Oddometer: 278
Road King Adventure Tire Recommendations
Bought a 2004 Road King recently, and it's going to be needing a new rear tire come spring.
I've got very little saddle time on this bike, but in general, I have a habit of going into places I shouldn't go.
So what sort of tire would you guys recommend for traveling down dirt and gravel roads, as well pavement. Interstate slogging isn't a big concern for me. I'll be riding slower, gawking at the world, as I tend to do. I want a tire that will handle dirt and gravel roads better than those Dunlops would. I'm used to those tires, and other Dunlops very similar, they dance and slither in dirt, though without actually losing it. I'd like better.
And if any of you have actually dark sided an earlier Road King, with the narrower rim, I'd love to hear it. There's a few rather vague listings on the darkside page, but I'm rather dubious of what is said with regards to the narrow rimmed Road King.
foxtrapper is offline   Reply With Quote
Old 12-20-2012, 06:46 AM   #2
sturgeon
sturgeon's Avatar
Oddometer: 744
Tourances or Anakees if you can find the sizes you need.
Dyslexics Untie!
sturgeon is offline   Reply With Quote
Old 12-20-2012, 07:28 AM   #3
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 29,134
BF Goodrich All Terrain. I don't think you'll find a tire with any sort of "adventure" design that will have the load rating your bike requires. Maybe you could cut a more aggressive tread in one of the recommended tires?
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 12-20-2012, 07:38 AM   #4
Grainbelt
marginal adventurer
Grainbelt's Avatar
Oddometer: 25,021
Pack an air compressor & tire gauge, and just air down whatever you've been running when you're in the dirt.
You said you're in no hurry.
Grainbelt is offline   Reply With Quote
Old 12-20-2012, 07:38 AM   #5
motorat
nOOb
motorat's Avatar
Oddometer: 543
i am guessing you have a 16" wheel so that limits what is available.
what i found are:
http://www.motorcycle-superstore.com...Rear-Tire.aspx
the duro is a 130 where as the bridge stone is a 120.
there were a couple others but they were more knobby and under the weight of a road king you would probubly only get about 2k miles out of them.
Joe
08 Vstrom 650 abs
motorat is online now   Reply With Quote
Old 12-20-2012, 08:09 AM   #6
foxtrapper OP
Oddometer: 278
I should have posted size. Stock is 130/90-16. That limits me. And I'm not looking to make the Road King into a dirt bike.
The Duro and Bridgestone were the only things I found as well. I even found a thread where some Sportster guys were building offroad versions of their bikes, and several were running the Bridgestones. They had to do some further engineering to deal with the high speed wobbles they were getting from the offroad type tires. That's not something I want to get into with the Road King.
Really, I'm looking for something roughly in between a generic street touring tire and something like the Duro and Bridgestone. Arguably, the oem type Dunlops might be the best I can find. I've used them before and they do work. Enough tread lip to work on a dirt road, they just aren't particularly good at it.
One other I found that I'm wondering about is the Conti Milestone. Tread looks like it might be able to dig in a little on a dirt or gravel road. Should also be good in the rain (hate having rain drama).
Old 12-20-2012, 10:24 AM   #7
sturgeon
sturgeon's Avatar
Oddometer: 744
Try a street tire on the rear and something a little "knobbier" on the front. Greatly improves handling on gravel.
Sent from my Nexus 7 using Tapatalk 2
Dyslexics Untie!
Old 12-20-2012, 01:03 PM   #8
Clint Taurus
Clint Taurus's Avatar
Oddometer: 657
Show the King some respect would ya! run that 800+pound behemoth up shits creek a couple times and pull it out by yourself and you'll stop taking it where it has no business being.
They didn't name it Road King cause it's such a great gravel and fire roader.
Don't be a panty-waste
Clint Taurus is offline   Reply With Quote
Old 12-20-2012, 04:06 PM   #9
sturgeon
sturgeon's Avatar
Oddometer: 744
But very few squids will blow by ya on blind curves on gravel roads.
Dyslexics Untie!
Old 12-20-2012, 05:08 PM   #10
foxtrapper OP
Oddometer: 278
Mmm. To each, by their own abilities.
http://www.advrider.com/forums/showthread.php?t=603979
Not that I ever said I wanted to do that. Just that I wanted tires that work better than typical tires on dirt and gravel roads.
Old 12-20-2012, 05:39 PM   #11
Clint Taurus
Oddometer: 657
True enough home skillet.
I would never subject my RK to a river run, a gravel road if necessary, but not a river.
good luck in your tire search, post up a pic when you find the right tire
Old 12-20-2012, 05:59 PM   #12
FR700
Heckler™©®
FR700's Avatar
Oddometer: 3,459
... it's just a motor bike
OP , I went with Metzeler 880's . A 140/90 on the back as they have a higher load rating and last longer , it just cleared the wide belt used on my '02 glide. After I went chain there's plenty of clearance. Going wider would have meant changing out the rear guard too. The front I found that a 130/90 and sitting on the back of the tank to load the front works well. Let the back of the bike do what it wants on fast gravel ~ 60+ mph , it'll never completely step out on you.
I'm diagonally parked in a parallel universe .
FR700 is offline   Reply With Quote
Old 12-20-2012, 06:15 PM   #13
Ben99r1
Ben99r1's Avatar
Oddometer: 2,800
I have a 06 road king. I bought a dunlop 402 rear tire when I needed one. Ill tell you this I won't get another one ever again. It does not to be pushed hard in the corners. It very slippery under hard braking. Only thing it has going in it favor is it works good in the rain. I live in California so that doesn't matter much. I am trying the Metzeler 880 next.
Ben99r1 is offline   Reply With Quote
Old 12-20-2012, 06:54 PM   #14
Butters
Butters's Avatar
Oddometer: 2,069
I would just get road tires. I really don't think tires are going to hold you back more than the 800+ pounds and lack of suspension travel. Moreover, I don't notice a huge difference between tires on gravel. Just take it easy, which shouldn't be a problem on a cruiser.
Now if you expect to encounter mud, maybe it's worth a more aggressive tire. But if you end up down a muddy road on a roadking, you will certainly find adventure.
Marc
07 XChallenge
99 VFR
Butters is offline   Reply With Quote
Old 12-20-2012, 07:03 PM   #15
Murf2
Oddometer: 716
I run a lot of gravel roads on my RK. Dunlop Elite3's aired down to around 25 lbs will get you farther than you need to go.
Have fun,
Murf
Murf2 is offline   Reply With Quote
Times are GMT -7.   It's 06:35 PM.
