Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 12-21-2012, 12:47 PM   #1
BKMLWR OP
Wondering around...
Oddometer: 4,687
wpt file for gps
anyone ever dealt with a gps file with a .wpt extension?
am going to give gpsbabel a try but some background info might be interesting....all I know is it is a file for a canoe trip...
Sometimes I get off the bike before it has come to a complete stop....
Another Proud Small Scale Faker......
Praise You In This Storm
LifeSong
BKMLWR is offline   Reply With Quote
Old 12-21-2012, 04:48 PM   #2
mcnut
Oddometer: 1,383
I think in the old days some of the 3rd party data software (OziExplorer, GPSUtillity, WP+) may have divided up the data into separate files, waypoint (.wpt), track and routes. If I'm correct I think a .wpt file will be a text file of waypoints. Fairly sure GPSBabel would do the conversion if you had a better idea what software was used originally.
Also if you can open the file in a text editor you may be able to copy the data without the header and paste into a text file created by other software. I believe that most GPS data files are just text files with unique headers and formatting depending on the software used to create them.
Bruce
mcnut screwed with this post 12-21-2012 at 04:59 PM
mcnut is offline   Reply With Quote
Old 12-21-2012, 06:34 PM   #3
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,996
You should find the WPT extension under the OZexplorer in GPSBabel. That point file can be converted to GPX which is a more useful file type.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 12-22-2012, 10:26 AM   #4
BKMLWR OP
Wondering around...
Oddometer: 4,687
here is part of the contents of the file as viewed in Notepad...it is a garmin file of some sort...
The F3WPT is probably the key to understanding.....
F3WPT--.-- . # 01 Where the route starts, on a bogan on McKay Brook. Garmin\Garmin\08198.bmp MS Sans Serif,255,8,0 Xd|G@dnrP c ي-@     t 31 Garmin\Garmin\08198.bmp MS Sans Serif,255,8,0 ߨG@M"rP c !92@     15 Where the route crosses the Spurline Road. (An old railway bed.) Garmin\Garmin\08198.bmp MS Sans Serif,255,8,0 Y" G@FDUqrP c 3g2@     t 03 Garmin\Garmin\08198.bmp MS Sans Serif,255,8,0 b0G@ urP c z#2@     06 Where the route crosses a very small stream. This small stream flows into McKay Brook. Garmin\Garmin\08198.bmp MS Sans Serif,255,8,0 3G@mrP c Ȱ2@     t 09 Garmin\Garmin\08198.bmp MS Sans Serif,255,8,0 2 {G@0FhrP c &2@     t 10 Garmin\Garmin\08198.bmp MS Sans Serif,255,8,0 C:G@,7\rP c El-2@     11 On the old partially grown in horse road. Garmin\Garmin\08198.bmp MS Sans Serif,255,8,0
YG@,{XrP c J52@     t 12 Garmin\Garmin\08198.bmp MS Sans Serif,255,8,0 AϦG@N\rP c x=2@     t 13 Garmin\Garmin\08198.bmp MS Sans Serif,255,8,0 Y} G@⮀grP c aדG2@     14 Where the route leaves the old partially grown in horse road.
LifeSong
Old 12-22-2012, 11:03 AM   #5
mcnut
Oddometer: 1,383
OK skip what I said. Did you try the OziExplorer format in GPSBabel as DRTBYK sugested?
Bruce
Old 12-22-2012, 12:12 PM   #6
DRTBYK
DRTBYK's Avatar
Oddometer: 5,996
Your WPT file could also be DeLorme file. But GPSBabel can handle them all.
Cheers,
Cheers,
Dan
All Things GPS
Old 12-22-2012, 05:02 PM   #7
BKMLWR OP
Wondering around...
Oddometer: 4,687
Bruce
yes....from what I see in the notepad printout it is a garmin file so I'm just trying garmin at this point.
LifeSong
Old 12-22-2012, 05:13 PM   #8
DRTBYK
DRTBYK's Avatar
Oddometer: 5,996
It's not a Garmin file. It's only referencing a Garmin Symbol bitmap image.
Cheers,
Cheers,
Dan
All Things GPS
Old 12-22-2012, 05:53 PM   #9
BKMLWR OP
Wondering around...
Oddometer: 4,687
that might be good to know..in searching for info on the sequence "F3WPT" it might be garmin PCX5 file from the mid 90s...which used a .wpt file for waypoints, rte file for routes etc...
http://filext.com/file-extension/WPT
LifeSong
Old 12-23-2012, 09:27 AM   #10
mcnut
Oddometer: 1,383
Good luck. Maybe the poster of the file knows otherwise I would just start working through the more popular formats in GPSBabel.
In the early days every new program seemed to have it's own unique format which is why the standardized .gpx was needed and thus adopted.
Bruce
Old 12-23-2012, 11:43 AM   #11
BKMLWR OP
Wondering around...
Oddometer: 4,687
problem solved....
I was able to open the file with a demo version of Fugawi Global Navigator 4.5......I got the hint from the website of file extensions where Fugawi was mentioned.
looks like in interesting program which might be more capable than mapsource, maybe of more use in marine or aviation applications
turns out the file was a series of waypoints to portage between 2 brooks deep in the woods of New Brunswick...
LifeSong
Times are GMT -7.   It's 02:24 PM.
