Old 12-22-2012, 04:00 AM   #1
gefr OP
Life is a trip
gefr's Avatar
Oddometer: 3,915
KTM 990 injection fuel pump reasonably priced.
This fuel pump originally made for cars is made in China. Chosen from a big manufacturer is undergone surgery. It ends up a nice fit in place of the original fuel pump. Rated at 3,5 bar at 90lit/h, pressure and quantity is adequate at all times while it costs 45€, shipment is free.
The elastic base which holds the fuel pump from turning when it starts and stops. The lower side of the fuel pump needs to fit in the rubber cavities. So some surgery was needed.
Original fuel pump (lower photo) compared to my version Chinese fuel pump (upper photo) after modifications.
Upper side of the pump had some extra plastic around the connections that needed removing. Here it is after surgery.
The shape of the original fuel pump differs slightly from the imitation so the smaller supporting cage is not functional. The outer larger cage needs some spacers in order to reach the aluminum pump nest, so longer bolts and nuts rectify that imperfection (included).
The bronze little pipe falls short now so an aluminum spacer flange is included to sit in the pipe's nest and keep it from bottoming. This way the pipe seals properly to both its ends.
So a complete set includes 2 longer bolts 1.5cm M5, one flange spacer in aluminum, 2 nuts and an o-ring 60X3 made of viton, sealing the fuel pump assembly, shown in the above picture since it usually gets damaged.
I also include a small o-ring at the intake of the pump to ensure sealing at intake.
Delivery time can take up to 22 days.
Payment is through paypal.
Cheers
gefr screwed with this post 09-16-2014 at 06:26 AM
Old 04-10-2013, 11:54 PM   #2
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,145
Awesome !!
Thanks for singlehandedly delivering a one-to-one replacement for the FI pump + filters which cost a total of 500$+ from KTM
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 04-12-2013, 05:46 AM   #3
gefr OP
Life is a trip
gefr's Avatar
Oddometer: 3,915
We need to solve our problems by ourselves.
Cheers.
Old 05-04-2013, 05:51 AM   #4
Gimme 2
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,031
great job
Gimme 2 is offline   Reply With Quote
Old 05-04-2013, 05:45 PM   #5
gefr OP
Life is a trip
gefr's Avatar
Oddometer: 3,915
That was OC community work reached fruition.
Cheers.
Old 05-23-2013, 05:42 PM   #6
RocketRex1
Team Old
Oddometer: 2
Thumb Chinese fuel pump
Man that is an awesome fuel pump. What kind of Kilo's do you have on it and what currency is the $ 40 in?
RocketRex1 is offline   Reply With Quote
Old 05-23-2013, 08:26 PM   #7
gefr OP
Life is a trip
gefr's Avatar
Oddometer: 3,915
Hi there,
My milliage is 7k kms on this pump, since last March. Still going strong.
The price is 40€, you can check currency conversion here:
http://www.onlineconversion.com/currency_conversion.htm
Cheers.
gefr screwed with this post 10-28-2013 at 12:29 AM
Old 05-24-2013, 08:08 AM   #8
DirtJack
DirtJack's Avatar
Oddometer: 1,518
Do you make the modifications to the fuel pump before shipping, or is that something the buyer has to do? Are the second and third photos of your original post interchanged?
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 05-24-2013, 10:01 AM   #9
gefr OP
Life is a trip
gefr's Avatar
Oddometer: 3,915
Thanks for heads up.
The modifications are made in order to make the aftermarket pump as plug and play as possible. I corrected the explanations under the pictures.
Cheers.
Old 10-23-2013, 08:17 AM   #10
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
bump for the man with a plan...
SA
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 11-19-2013, 08:32 AM   #11
KaytM
Just a fella.
KaytM's Avatar
Oddometer: 202
Are you proposing to sell a modified pump thats good to go or a pump that I buy from you and modify myself??
EDIT**
D'oh! Yeah I get ya!!
PM sent!
2006.5 990 ADVENTURE.
KaytM is offline   Reply With Quote
Old 01-18-2014, 01:28 AM   #12
EatinDirt
WannaB Thumpin
Oddometer: 19
G
Whats the current draw on this new pump do you know?
Thx
EatinDirt is offline   Reply With Quote
Old 01-18-2014, 03:48 AM   #13
gefr OP
Life is a trip
gefr's Avatar
Oddometer: 3,915
You mean amperage?
I think it is around 6Amps.
Old 03-25-2014, 10:24 PM   #14
RTODAHL01
RTODAHL01's Avatar
Oddometer: 77
Way cool.
Found a 2010 990 with 3000 mi on it.
I don't think it will need a new pump but I like to look ahead.
RTODAHL01 is offline   Reply With Quote
Old 03-26-2014, 01:00 AM   #15
gefr OP
Life is a trip
gefr's Avatar
Oddometer: 3,915
It could be more usefull to replace fuel filters at that stage.
If the bike has been standing for a long time, fuel filters could be clogged, irrespective of miliage.
Cheers.
Times are GMT -7.   It's 07:57 PM.
