Old 12-29-2012, 10:44 AM   #1
Memnok OP
Fly high, go far.
Memnok's Avatar
Oddometer: 357
TRACKSIDE Grip Heaters
I got a pair of these for Christmas, but they don't seem to have any information on them as to the wattage they will draw from the system. Does anyone happen to know how much they will pull? I have 185 watts from the XR650L stator, but I am adding some ADVMonster 60 LED lights too.
Clint >>> 2007 XR650L <<<
Good government is no substitute for self-government. Mahatma Gandhi
That government is best which governs least, because its people discipline themselves. - Thomas Jefferson
Memnok is offline   Reply With Quote
Old 12-29-2012, 11:07 AM   #2
kubiak
Oddometer: 4,829
i have a set on my f650gs and they work great! ran them last season and now this season with no problems so far. i dont think they take much wattage at all, i thought i read somewhere they take around 15 and 25 watts on high? the resistor gets way hot so make sure its not touching anything that can melt. i actually took the resistor off and run them straight on high.
kubiak is online now   Reply With Quote
Old 12-29-2012, 11:16 AM   #3
mbfj40
Oddometer: 168
If you've got an electrical meter handy that you can measure Ohms with it's a snap to do the math for Watts.
Measure the resistance (Ohms) of your new grip heaters across the leads that would attach to the battery. Check both Hi and Low settings if you want both wattages.
The math is Voltage squared, divided by Resistance (Ohms) equals Watts.
So just round off your voltage to 13 volts (a few tenths either way won't be that big of a deal) then square it (13x13=169) now divide that (169) by the Ohms reading on your grips and there ya have it.
mike
mbfj40 is offline   Reply With Quote
Old 12-29-2012, 05:02 PM   #4
duck
duck's Avatar
Oddometer: 10,403
JMHO: Ditch the switch and resistor and spend $4 on one of these. Since it's PWM a lower setting draws less power.
http://www.advrider.com/forums/showthread.php?t=737165
duck is offline   Reply With Quote
Old 12-29-2012, 05:10 PM   #5
kubiak
Oddometer: 4,829
am i ok by just running them through the hi lo switch that came with them? i cut the resistor out and run them straight through the high setting on the toggle. they get pretty hot but feel great in the cold weather. does the hi lo switch have a resistor in it or is it just a two way toggle?
Old 12-29-2012, 06:25 PM   #6
Johnf3
Oddometer: 1,050
Most of these type of grip heaters pull around 45W on high.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 12-29-2012, 07:42 PM   #7
MaestroPNW
Me!
MaestroPNW's Avatar
Oddometer: 93
Easy - just measure the resistance of both together in parallel. Assuming it's "R" Ohms, plugging them into 12V will produce I = 12 / R amps. The consumed power then will be equial to 12 * I = 12 * ( 12 / R ) = 144 / R Watts
MaestroPNW is offline   Reply With Quote
Times are GMT -7.   It's 05:05 PM.
