Old 12-23-2012, 11:50 AM   #1
rudolf35 OP
Warped & Twisted Mind
rudolf35's Avatar
Oddometer: 797
CB/CL 350 stuck oil drain screw
Since my R50/5 project is in the test phase, running up miles, I thought it was time to pay some attention to my CL350. The bike is down tithe frame and I have started to take the motor down. All is going well save the oil drain screw/cap in the bottom of the case.
I tried a 1/2 inch ratchet, 1/2 in with a two foot cheater bar and a 1/2 inch with a cheater bar plus heat: the bloody thing will not move. Any suggestions?
2013 Ural Gear-Up, 2008 Fatbob, 1999 Jeep Sahara, 1982 BMW R65LS, 1973 Honda CL350 K5, 1971 BMW R50/5
rudolf35 is offline   Reply With Quote
Old 12-23-2012, 11:57 AM   #2
MChappy
MChappy's Avatar
Oddometer: 66
Heat the plug then cool it with a wet rag several times. Probably a case of dissimilar metal corrosion
Sent from my DROIDX using Tapatalk 2
MChappy is offline   Reply With Quote
Old 12-23-2012, 01:21 PM   #3
rudolf35 OP
rudolf35's Avatar
Oddometer: 797
No joy
Good idea; tried it and the cap would not budge - four cycles hot/cold.
Also tried just a good tap when hot to break the bond, no joy.
Old 12-23-2012, 02:33 PM   #4
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,413
more info... You say drain screw/cap.. is it an aluminum cap with a large OD? Or a simple steel drain plug?
Old 12-23-2012, 02:38 PM   #5
copper.mason
Oddometer: 24
try to remove as much oil as possible for safety reasons and than weld a big nut on to it. Worked on my xl250 when it was stuck
copper.mason is offline   Reply With Quote
Old 12-24-2012, 04:16 AM   #6
rudolf35 OP
rudolf35's Avatar
Oddometer: 797
The cap
It is a 2" disk with a 19mm faced tip, steel. It is a known issue with older Honda motors. The 19mm faces are in good shape so a slipping wrench is not a issue. As you mentioned earlier, dissimilar metal corrosion.
I might have to go with a old "fix", take the case down and clamp the 19mm in a vice and try to spin the lower case. Will be a mess but I do not want to blow the threads in the pan.
Old 12-24-2012, 05:16 AM   #7
rufusswan
rufusswan's Avatar
Oddometer: 962
Or you could just tap it for a smaller drain plug.
1971 BMW R75/5 Toaster LWB
1974 Honda CL200
http://zenhuckfinn.wordpress.com/
rufusswan is offline   Reply With Quote
Old 12-24-2012, 11:55 AM   #8
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,413
While a helper holds as much torque on it as you dare, (with a nice 6 point socket of course) take a sharp center punch held at a 60 degree angle out near the perimeter and whack it sharply with a 24oz hammer. Works every time. The small divot will be easily filed/blended smooth. I do it regularly.
Old 12-26-2012, 03:45 PM   #9
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,353
If the drain plug is steel, heat the aluminum engine areas around the plug with a heat gun and try to remove it while things are nice and toasty. The aluminum expands faster than the steel and might (?) give up it's grasp on the steel plug. That's worked for me a few times.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 12-27-2012, 08:21 AM   #10
rudolf35 OP
rudolf35's Avatar
Oddometer: 797
Good one
That is what I have in mind; that is after I have the case split. I drained the oil out via the left and right side, also the open top - messy but it drained the oil. Once I have the case split I will try heating the alloy locally, with the plug clamped in a vice, the try to twist it loose. If that fails, I will just drill out the center of the plug until I can crush it on itself; will replace it anyway.
Old 12-27-2012, 08:07 PM   #11
ArtCuisin
Oddometer: 35
I had the same problem when I was 16 (about 36 years ago)
on my 1972 CL350.
Laid it on its side, cold, hit with hammer sqare-on.
Worked for me.
But that was a long time ago.
Maybe that experience is why I've pretty much drilled
and safety-wired drain plugs on everything I've owned
for the last 25 years. (I don't feel the need to tighten so hard.)
(Aside: I think it is funny how thinking about buying one of
those these many years later makes me shudder.)
ArtCuisin is offline   Reply With Quote
Old 12-27-2012, 09:44 PM   #12
Harry94025
Oddometer: 287
I've owned a couple of CB350's. I always would hit the drain plug on the top (bottom when the bike it upright) of the hex with a good sized hammer before attempting to loosen the drain plug. Then, a 1/2" breaker bar would do the trick...
Harry
Harry94025 is offline   Reply With Quote
Old 12-28-2012, 05:48 AM   #13
electroken
Oddometer: 219
I have one of those drain plugs sitting here in front of me, and I don't see that crush thing happening. My money is on a LARGE air impact wrench and a good 6-point socket.
electroken is offline   Reply With Quote
Old 12-28-2012, 06:00 AM   #14
MODNROD
Perpetual ponderer
MODNROD's Avatar
Oddometer: 2,117
Wlak past it every morning and night for a week, and hit it with Loctite "Freeze and Release" for a few seconds each time.
Then just before you walk away, kick it.
The last bit especially, is important.
Who the hell would drag race a Ducati?!?!?!?!
http://www.dragtimes.com/Ducati-Mons...lip-10329.html
MODNROD is offline   Reply With Quote
Old 02-09-2013, 05:21 AM   #15
rudolf35 OP
rudolf35's Avatar
Oddometer: 797
#^^},> oil drain plug
OK, tried heating the lower case (400F in oven) and freezing plug - no joy.
Tried freezing plug - no joy
All the while using a impact to jarr the plug lose, this thing has become a part of the case. Any other ideas? Matter of fact, the cylinder studs and inner oil splash shield fasteners are just as frozen.
I need some sage advice!
Times are GMT -7.   It's 04:53 PM.
