Old 02-09-2013, 08:22 AM   #16
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Still at this??? A hammer and a sharp chisel works every time. Just replace the bolt. Ugly solution but 100% effective.
buls4evr is offline   Reply With Quote
Old 02-09-2013, 10:42 AM   #17
rudolf35 OP
Warped & Twisted Mind
rudolf35's Avatar
Oddometer: 797
To Haydes with the bolt
The bolt is a writeoff, just wanted a more elegent way of removing the frozen plug.
2013 Ural Gear-Up, 2008 Fatbob, 1999 Jeep Sahara, 1982 BMW R65LS, 1973 Honda CL350 K5, 1971 BMW R50/5
rudolf35 is offline   Reply With Quote
Old 02-09-2013, 12:35 PM   #18
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,629
The first thing I would try is putting some kroil on the plug and give that a couple or three of days to work. Internet lore describes ATF mixed with acetone is better, but I haven't gone through that experiment. The next thing I would try is drilling out the plug to get the oil from the crankcase. Once the oil is drained, heat can be applied to the aluminum and the plug cooled. All the while keeping kroil applied to help penetrate the threads. The last thing would be to heat the plug and case together - being careful to not heat melt the case. Then let them cool and repeat that cycle a few times. If none of that worked, an impact wrench on plug would be used. Good luck!
Edit: I see in the saga that the oil is out of the crankcase. Drilling a hole in the plug will still help after applying penetrating oil. Also, heating the case with a torch to ~300 deg F and with a cold wrench from the freezer, see if the plug can be removed with the wrench and a few blows from a hammer.
Stan_R80/7 screwed with this post 02-09-2013 at 12:42 PM
Stan_R80/7 is offline   Reply With Quote
Times are GMT -7.   It's 02:02 AM.
