Old 12-23-2012, 10:20 PM   #1
hansi OP
Teurer Abenteurer
hansi's Avatar
Oddometer: 310
Garmin micro-sd to Mapsource?
Probably a rather stupid question: I have a Mexico City Navigator on Micro-sd card for my 76csx. How do I get it to Mapsource on my PC for routing/trip planning? Can't figure it out.
hansi is offline   Reply With Quote
Old 12-23-2012, 10:47 PM   #2
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
you can't. not back into mapsource atleast where you create routes and such.
i believe with basecamp http://www.garmin.com/en-US/shop/downloads/basecamp you can read the cards maps right of the disc and create routes.
next time buy the dvd with the maps not the preloaded sd card.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 12-23-2012, 10:58 PM   #3
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
if you get nowhere & want a higher quality routable Mexico and CA mapset, check out Bicimaps. Garmin CN for Mexico coverage is not that good.
http://www.bicimapas.com.mx/Mapas_GPS_EN.htm
Alaska
Old 12-24-2012, 04:48 AM   #4
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,313
As noted, you can't load the SC card to Mapsource.
You can install it in the unite and then use Basecamp to view the data.
dunno.....
Old 12-24-2012, 05:00 AM   #5
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,843
Just a warning - with a 76CSx as the unit the sd card/map's installed in, it'll take a long time for Basecamp to read the info from the map. The 76/60 series has a very slow USB connection.
And for this to work, the unit needs to be in mass storage mode.
But aside from those caveats, it should still work.
Times are GMT -7.   It's 04:50 AM.
