Old 11-05-2012, 07:07 PM   #1
OldDog OP
Smelly Adventurer type
OldDog's Avatar
Oddometer: 4,652
How do you get a replacement compliance plate?
Afternoon All, I have an old (1981) KTM i'm going to restore but the hardest part to fiind for it is probably going to be a replacement compliance plate. The original is still there but largely unreadable as the headlight rear shroud has rubbed most of it away. I'm going to just put it on vintage bike rego but I'll need a readable plate. Does anyone know who I should contact to get this started?
Cheers
OD
Your time is limited, so don't waste it living someone else's life. - Steve Jobs
Yesterday afternoon I was planning to ride Dakar, this morning I was planning to throw up in my helmet - Boris Mihailovich
Objects in the rear view mirror.....appear to be losing - Me
OldDog is offline   Reply With Quote
Old 11-05-2012, 08:12 PM   #2
DRjoe
DRjoe's Avatar
Oddometer: 5,115
I think a ktm dealer should be able to help you out.
Old 11-05-2012, 08:33 PM   #3
podge NT
Podge NT
podge NT's Avatar
Oddometer: 2,287
Cheers
OD
There is only one compliance plate issued for any vehicle if it gets lost or destroyed, too bad they cannot be replaced.
http://share.findmespot.com/shared/f...1IWs2Hg87TZcsW
Plan, what plan, there is no plan
podge NT is offline   Reply With Quote
Old 11-05-2012, 08:37 PM   #4
Oldfatbeerman
Enroute to a PUB
Oldfatbeerman's Avatar
Oddometer: 3,799
Cheers
OD
I had a similar issue with my old hilux ute , the plate fell off as the rivets had fatigued over the 20 or so years and 1/2 a milion k's it had done , I had to go through the local Toyota dealer who had to inspect the vehicle , check all the numbers were correct and then fill out a number of forms to submit to the manufacturers representatives here in the Aussie republic and the NSW Gumbymint where upopn I was presented with a letter of ADR compliance for that vehicle that had to be with the vehicle at all times when in motion . Dunno how this will be achieved with a vehicle that is not currently registered though , talk to the guys at Dubbo KTM Bill , they might have some knowledge on the subject , good luck , you'll wear out at least one pair of boots running around after it I am sure of that .
KTM 950 SE
Yamaha WR 450 F ( + Rally spec )
Oldfatbeerman is offline   Reply With Quote
Old 11-05-2012, 08:55 PM   #5
philth
philth
philth's Avatar
Oddometer: 6,230
unless you ride a postie
i must not post hairy buttocks
philth is offline   Reply With Quote
Old 11-05-2012, 09:42 PM   #6
LeglessOne
Baiter of OldDog
LeglessOne's Avatar
Oddometer: 2,468
Cheers
OD
Get off ya arse and join the GVMC then Im fairly certain it only needs to pass a road worthy and have the club fill out some paper work to get it registered.Or some crap like that.
Here are some links ya lazy sod.
http://www.councilofmotorclubs.org.a...d=15&Itemid=16
http://www.google.com.au/url?sa=t&rc...t0B4lHfK1gfEUg
http://www.gulgongmotorcycleclub.com/
I never find a place where I can stay
I'd rather be a thousand miles away.
LeglessOne is offline   Reply With Quote
Old 11-05-2012, 10:57 PM   #7
podge NT
Podge NT
podge NT's Avatar
Oddometer: 2,287
Swapping is not replacing
Old 11-05-2012, 11:07 PM   #8
Uncle Crumpet
Uncle Crumpet's Avatar
Oddometer: 615
Yes it is, you just replace it with another one!
there is no mechanical problem so bad, that with a little more fixing, cant be made worse.
Uncle Crumpet is offline   Reply With Quote
Old 11-05-2012, 11:13 PM   #9
Gadget678
Gadget678's Avatar
Oddometer: 1,196
I would've started here:
Just contact your states registration authority and ask them: "What do I do?..."
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 11-05-2012, 11:13 PM   #10
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,410
being a fan of the honda z50 monkeybike scene .. honda have now stopped isueing lost or damaged compilence plates .....they used to do it .... but now they dont
as for other manufacture's i dont know
Sean-0 is offline   Reply With Quote
Old 11-05-2012, 11:14 PM   #11
Uncle Crumpet
Oddometer: 615
I had an issue with my mz when I went to register it, QT had no record of the engine or frame no. But the bike had a compliance plate. As far as I was concerned and I pointed this out to them, the bike had been complianced in Oz, their record keeping was not my problem. So as long as you have the plate readable or not, you shouldn't have a drama. They never found the details of the bike but I supplied the numbers and they registered it. Ringadingding !
Old 11-05-2012, 11:24 PM   #12
troy safari carpente
Team f5ool
troy safari carpente's Avatar
Location: "Pearl of the sound" - f5ederation of scandwegia
Oddometer: 20,133
Cheers
OD
oooooh '81 KaToom... eh?
Vas is das modelteilnummer... ja?
WATCH THIS SPACE...
troy safari carpente is offline   Reply With Quote
Old 11-05-2012, 11:30 PM   #13
saintell
Monarchs #30
saintell's Avatar
Oddometer: 379
I don't think your vehicle would have a compliance plate anyway some early KTM's were not compliant,certainly no VIN which they normally want,I would think the engine number alone should suffice ,any numbers stamped on it are usually stamped on the frame,if you are still in trouble find another bike and copy the compliance numbers off it,alternatively take the plate off and look at it with a very strong magnifying glass,red plate reg is very understanding not as strict as full reg,join a club in Vic that does their own scrutiny not a RWC,cheers Nev
saintell is online now   Reply With Quote
Old 11-06-2012, 12:10 AM   #14
OldDog OP
OldDog's Avatar
Oddometer: 4,652
Shane....mate why don't you just tell me what you think instead of beating about the bush like thatI'll check those links but, and I am joining the CVMC I have the registration to hand in on Sunday at the swap meet...are you goin?
Troy, yeah mate she's a '81 250GS 2 smoke . Horvaths are about to get a good size order from me
Saintell, yeah this one has a compliance plate, it's probably one the rare ones that Floody decided to comply It even has blinkers!
Phil, sorry mate but Posties are strictly for the elite, I don't think i could handle the outrageous power of one of those suckers.
Old 11-06-2012, 12:56 AM   #15
LeglessOne
Baiter of OldDog
LeglessOne's Avatar
Oddometer: 2,468
I read through those links ages ago and i'm pretty sure if your in the club and get the road worthy etc it doesnt even matter about the plate/vin/eng number.
See Don at main street auto he's a supporter of the club and he'll definetly know what you need.He'll probably be at the swap meet.
Dunno about the swap meet I'm over the valley on friday and dunno if i'll be back.
Sent from my iPad using Tapatalk HD
Times are GMT -7.   It's 08:20 PM.
