Old 12-31-2012, 09:59 AM   #16
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Originally Posted by toowheels View Post
Yes lower fronts to passenger peg area (or frame if none) centre velcro/straps section across saddle/top rack/fender (whichever) and then the proto has two straps with a few different anchoring points you can run from the top to the top rack (as in pic above) or from the inside sides (again with a few different anchoring points) to the top rack or whatever. I was also suggesting as an alternative (maybe a little confusing) you could run the straps side to side between the two panniers across tail light section if needed on a more rearward position, no top rack or anchor point or "shorter" bike if you get what I mean. Is that any less confusing?
Dave
Thanks for clearing this up Dave
modeselector is offline   Reply With Quote
Times are GMT -7.   It's 10:06 AM.
