Old 01-22-2013, 07:58 AM   #91
mcma111
mcma111's Avatar
Oddometer: 12,390
I put some grease on the collar and place it in the pump.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-22-2013, 08:01 AM   #92
brucifer
brucifer's Avatar
Oddometer: 2,473
^^^What Steve said.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-2001 Yamaha WR250F-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 01-22-2013, 08:03 AM   #93
mcma111
mcma111's Avatar
Oddometer: 12,390
Have you seen my engine build? Although it's a XR650l the engines are basically the same. Cylinder and head torque's are different.
http://www.advrider.com/forums/showthread.php?t=713831
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-22-2013, 08:24 AM   #94
crobox OP
crobox's Avatar
Oddometer: 324
I spent yesterday doing the other attachment arms between the pannier racks and the bike frame. You can see them in this picture...
Within the last few days I have also applied the Honda decals to the tank and put on a few coats of protective clear coat. So the tank is basically done.
I have also been working out the pannier-to-rack attachment system. I will be using lockable draw latches, McMaster Carr part number 1406A57. The goal is for them to be super easy to use, easy on and off, and lockable to the bike.
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox is offline   Reply With Quote
Old 01-22-2013, 08:25 AM   #95
crobox OP
crobox's Avatar
Oddometer: 324
Thanks Steve... No I have not read your thread... but will do so today.
Old 01-22-2013, 11:31 AM   #96
davek181
davek181's Avatar
Oddometer: 904
I put it in the pump assembly and carefully put the cover on. I have cocked that sleeve too in the past juggling around the kickstarter and oil tube and whatever else is in the way. Might try gluing it into place with grease for assembly.
davek181 is offline   Reply With Quote
Old 01-22-2013, 01:16 PM   #97
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,092
Looking good so far. Word of advise on the Wiesco piston. I put one in my stock engine with stock exhaust and it pinged like crazy, even with race gas. Ran much better with the supertrapp so once that motor is together don't try using a stock muffler.
Carter Pewterschmidt is offline   Reply With Quote
Old 01-22-2013, 07:50 PM   #98
crobox OP
crobox's Avatar
Oddometer: 324
Thanks Carter. How many discs in your Supertrapp?
Old 01-22-2013, 07:58 PM   #99
Oddometer: 1,092
I run it with an open end cap. It's loud but the muffler hasn't been repacked yet. I'm doing a few upgrades to the bike in spring and I'll repack the muffler then. I'll post up a sound clip for everyone.
Old 01-22-2013, 08:00 PM   #100
crobox OP
crobox's Avatar
Oddometer: 324
Making a new oil-tube, AKA dowel.
Turning it from a piece of 1" aluminum on my new little South Bend lathe.
Here is the new tube next to the old one. 10mm OD x 8mm ID x 7mm long
I also made new locator dowels for the cylinder head, as those were mysteriously absent. Made those from stainless. No pictures.
Old 01-22-2013, 08:00 PM   #101
crobox OP
crobox's Avatar
Oddometer: 324
Like... no end on it at all?
Old 01-22-2013, 08:18 PM   #102
crobox OP
crobox's Avatar
Oddometer: 324
A few nights ago I worked out the basics of the design for the pannier attachment system. Here is the current state of the drawing:
This is the view from the back, or wheel side, of the right-side case. The orange outer lines are the Pelican case itself. The black is the rack, which lives on the bike. And the green is the various parts that will bolt to the case and "clip," or attach, to the rack. I will have to make adjustments to the placement of the latches to accommodate the exhaust, but I will wait until I have the latches and cases in hand to fine tune that stuff.
I already ordered two Pelican 1500 cases in silver. I might paint them... not sure. I have photoshop experiments with different paint jobs, but I think there are enough photoshop images of different colored Pelican cases in this thread already!
Old 01-23-2013, 05:13 AM   #103
davek181
davek181's Avatar
Oddometer: 904
I run 12 discs. A number derived after many high speed runs up a long 7% grade on my commute home.
Old 01-23-2013, 06:24 AM   #104
Oddometer: 1,092
One of these guys
As I stated it makes some noise, but I live in Harley country so it's tame in comparison. I still do hope the re pack tones it down quite a bit. After I put this thing on I don't run out the gears as frequently as I used to in an effort of good social manners.
Old 01-24-2013, 09:48 AM   #105
crobox OP
crobox's Avatar
Oddometer: 324
Sorry for calling you Dave, Steve. No one likes that sort of thing. My apologies.
Times are GMT -7.   It's 09:05 PM.
