Old 12-29-2012, 09:16 AM   #16
P B G
Oddometer: 10,001
If the roof didn't look so nice and brand spanking new I would be thinking about pulling it, insulating outside and reapplying roof!
Old 12-29-2012, 11:29 AM   #17
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,318
Originally Posted by trailrider383 View Post
Which one did you use? That link shows about four different types.
Originally Posted by LI LT Owner View Post
Forgive my ignorance, do you use this in place of insulation or in conjunction with it?
In the garage, I used the foil/bubble bubble/foil stapled to the studs and bottom of the roof trusses with no other insulation. In the addition, I used the same wrap stapled on the studs and bottom of the roof joists over fiberglass batt insulation that I slashed the kraft paper (so as not to have 2 vapor barriers.
I also used the foil/bubble bubble/white poly under the concrete slab. It seems to work at least as well as the 2" of blue foam under the slab in the rest of the house.
HapHazard is offline   Reply With Quote
Old 12-29-2012, 12:36 PM   #18
trailrider383 OP
867-5309
trailrider383's Avatar
Oddometer: 3,332
Thanks for the info. You wouldn't consider posting up a pic of what it looks like on the ceiling would you?
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 12-29-2012, 02:42 PM   #19
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 5,639
I just came from Homedepot and a 4x50ft roll is 130 bucks. They only had 1 kind but different sizes. It could be pretty expensive,. They also had 4x8 sheets of Styrofoam stuff with foil on one side for 12 bucks a sheet. I think I'd rather use the hard sheets vice the roll, or the best option would be spray foam, depending on cost.
Let us know what you decide.
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is offline   Reply With Quote
Old 12-30-2012, 06:31 PM   #20
RTCHIEF
Oddometer: 323
How is your roof ventilated?
RTCHIEF is offline   Reply With Quote
Old 12-30-2012, 06:52 PM   #21
trailrider383 OP
867-5309
Oddometer: 3,332
By the breeze when I open the doors and windows.
But seriously, it's not an enclosed attic like a house, so at this point it's open to the rest of the space so no extra ventilation needed. That's what I am worried about by adding insulation then you seal in the moisture and would need some kind of ventilation.
Old 12-30-2012, 07:45 PM   #22
walkingbear
walkingbear's Avatar
Oddometer: 3,603
my build
I had a choice of spray foam or rolled fiberglass.
I choose fiberglass with paper back .. wired to the ceiling.
The cost is lower with the fiberglass
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 01-01-2013, 07:51 PM   #23
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,318
I'll try. Here goes...
Old 01-01-2013, 08:08 PM   #24
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Our roof was higher than yours,
But I put up a dropped ceiling sorta.
Ran 2x4's and laid 3/4" 4x8 foam sheets across it.
Once in a while I have an issue with wind lifting them, but for the most part not.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 01-01-2013, 08:18 PM   #25
Jnich77
Jnich77's Avatar
Oddometer: 731
Originally Posted by troidus View Post
I still think spray foam is your best bet. It's self-supporting and rot-proof, as long as you keep UV light away. If you're going to weld in there, you might need a portable barrier around your project.
X2
It also deadens the sound of rain and helps the acoustics in the building.
Jnich77 is offline   Reply With Quote
Old 01-01-2013, 08:33 PM   #26
darmst6829
Oddometer: 378
Winter is finally here and I need a project to relieve the boredom. I have a 30 x 40 pole barn with nothing on the ceiling for insulation. I need help on figuring out the proper way to insulate it.
I would vent the heck out of it and put in a drop ceiling.
Dave
darmst6829 is offline   Reply With Quote
Old 01-01-2013, 08:41 PM   #27
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,308
Having an effective moisture barrier between the roof and interior space is important to the life of your roof. The roof on a building some friends and I bought rotted out along the purlins after about 30 years due to moisture buildup under the roof. The original insulation was vinyl faced fiberglas rolls.
Basically, the seams between the insulation were not sealed and moisture worked its way in and condensed on the underside of the metal roof. Also, birds got into the building and destroyed areas of insulation under the roof when they nested. The moisture attacked imperfections in the metal coating, and around the nail holes. It was amazing how the roof just rusted out in big straight lines under the purlins, while the spaces in between were largely intact.
For the replacement roof, the installer put down accordion panels of thin vinyl faced foam, taped the seams, then installed the new roof. Hopefully this will keep the moisture away from the metal and extend the life of the new material.
Our building is taller than yours, about 14' at the eaves, but I would think the moisture issue would be the same if you don't prevent it from reaching the metal.
dunno.....
Old 01-01-2013, 10:00 PM   #28
trailrider383 OP
867-5309
Oddometer: 3,332
Thank you very much! Did you tape the seams? If you did tape, what did you use?
Old 01-02-2013, 03:20 AM   #29
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,278
i did a drop ceiling with foam panels. the tape i used for seams for silver backed foam is henkel ul181b-fx - no sign of movement or loosening up for last 5 years. sticks and installs easier than you would think.
current bikes
stainlesscycle is offline   Reply With Quote
Old 01-02-2013, 12:24 PM   #30
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,318
You're very welcome - and thank YOU for not commenting on my embarrassing mess.
I taped the corners (wall to wall and wall to ceiling) with TekFoil Joining tape:
http://www.teksupply.com/contractor/...;pgdh8004.html
$12 for 150 feet of 2.5" wide tape. I've seen similar foil tape locally, but the TekFoil stuff is really sticky.
Times are GMT -7.   It's 10:28 PM.
