Old 12-28-2012, 02:19 PM   #1
MotoTex OP
Miles of Smiles
MotoTex's Avatar
Oddometer: 678
Oil Pressure Switch cross ref
Knowing that the OEM sending unit is something with a reputation for developing leaks, and, because I'm about to change mine for that very reason, I have a couple of questions for the forum . . .
One thread I read about swapping the OEM sender to mechanical sender so they could have a gauge in the dash, rather than the light showed photos of some of these installations using a hose to remote-mount their mechanical sender.
Considering the heat and vibration on the back of the front cylinder may contribute to the failure of the OEM, I was curious if anyone had used a hose to re-mount the OEM sender to somewhere less hostile, and, easier to get to?
Also, anyone know of any cross for this switch for an automotive application that might be at the local auto parts store? (would love to get this back up an running without waiting on parts)
13 TRIUMPH TIGER 800XC . . the new kitty in the litterbox
04
KTM 950 Adventure . . . .
Farkelization Completed - soon to be up for adoption
00 SUZUKI DRZ-400E. . . . . . DS Plated
MotoTex screwed with this post 12-29-2012 at 11:02 AM Reason: change title
MotoTex is offline   Reply With Quote
Old 12-28-2012, 10:42 PM   #2
TcRulz
Oddometer: 273
Hi, I have a mechanical gauge fitted to my 03 950A. Used an OEM oil pressure gauge adapter (part no 60029006000) to connect a hose to a 'Marshell' oil pressure gauge. Looking at this gives you options. http://www.advrider.com/forums/showthread.php?t=324319
My sender unit leaked as well. Replaced with one from a Landrover Discovery. Check this out. http://www.advrider.com/forums/showthread.php?t=748123
This, I hope will go along way to sorting some problems. Cheers from Oz, Glenn.
TcRulz is offline   Reply With Quote
Old 12-29-2012, 01:55 AM   #3
MotoTex OP
Miles of Smiles
MotoTex's Avatar
Oddometer: 678
Thanks for the references.
After a little more digging based on the info I have found this for the U.S. folks:
AutoZone carries a Duralast PS177 (by Wells Vehicle Electronics)
M10x1,
N/C,
3-8.3 PSI
$6.99
Looks like it is a stock item at my local store.
04
Old 12-29-2012, 07:10 AM   #4
Killer Whale KTM
Life is the adventure!
Killer Whale KTM's Avatar
Oddometer: 697
MotoTex,
I bought the first 950 that I could find, when they came to the USA. There was a little puddle of oil on the showroom floor, under the sending unit, when I bought it and when I sold it. I tried every sealer and technique that I knew of to no avail.Since moving up to the 990........no leaks . So maybe changing it to something else IS the best course of action.
Good Luck,
Killer Whale KTM
Friend:"That ain't no dirt bike,it's a damn whale!" Me: " It may be a whale, but if it is, it's a KILLER WHALE !! "
Killer Whale KTM is offline   Reply With Quote
Old 12-29-2012, 10:59 AM   #5
MotoTex OP
Miles of Smiles
MotoTex's Avatar
Oddometer: 678
Mine has been doing a Harley imitation, but very creatively, for the nearly two years I've had it.
Each time it has been something new.
Oil Filter O-ring
Oil Tank seal at the filter
Gear Switch O-ring
Oil Tank Dipstick O-ring (MIA)
Oil Pressure Switch
Find it, fix it, wait. Aw shit, now what's leaking?! . . .
Fortunately, there is the HOW and this forum, so when these things have come along I either already had read about them, or, have easily found the cheat notes after a diligent search.
I am hoping that I'm down to the last expected failure point for a while. I'm getting tired of having oil coating all the bottom surfaces for what seems like most of the last 30K miles.
Shifter seal and Counter Shaft seal would be the most obvious things to expect next in the battle.
I'll keep my fingers crossed after this is patched up. AutoZone didn't have the part on the shelf after all, but it will be here in a day or two. Then I can get the beast back in the wind.
As it is a different design, similar to the more recent KTM replacement, I'm guessing it won't give me any grief beyond the remove and replace fiasco. I actually have managed to get it loose using a box end wrench through the hole in the motor mount, but have decided that I really will need to pull the carbs and airbox to do this job right.
Is it weird how eventually it seems perfectly normal to have to remove twenty or thirty screws, multiple body panels, tanks, etc. every time I go to do some "little" item of work on it?
Just wish I could win the lottery and get a shiny new 1190 next year, for the maintenance access aspect alone.
04
Old 01-02-2013, 08:06 AM   #6
Martynho
ChileGringo
Oddometer: 310
Not leaking, but seems to be failing
Anyone here had this unit fail rather than leak. I have just had the oil warning light come on intermittently over the last 200 kms,now on pretty much permanently. As soon as it started i checked the oil level and there was no clacking from the cam chain tensioners, or overheating so I am assuming the oil sensor has gone belly up.
No spare here so waiting on US shipment, in the meantime Dakar is coming up and I have a 3000 km ride ahead of me. Oil, filters and water pump recently freshened up. Is there anything else I should check before I ride out?
Martynho is offline   Reply With Quote
Old 01-02-2013, 12:07 PM   #7
Boatman
Ride more, BS less!
Boatman's Avatar
Oddometer: 8,452
Mine was doing that for a while and then started leaking.
08 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 01-02-2013, 06:03 PM   #8
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 959
Send a message via Skype™ to ciedema
Dont buy a KTM one - an automotive one (like one listed above will work just fine).
Stories from the Seat Facebook My Photos Cannonball Charity Ride
No Four Wheel Drives, No Fixers and No Fricken Whingers
Personal Attacks - the last refuge of the intellectually impaired.
ciedema is online now   Reply With Quote
Old 01-04-2013, 06:35 AM   #9
charlie264
charlie264's Avatar
Oddometer: 5,202
Thought I’d found the perfect solution, phone UK distributor and Koso don’t even make it yet if ever ??????
Old 01-04-2013, 12:57 PM   #10
99sleepyhollow
JOEY DUNLOP 26 TT WINS
99sleepyhollow's Avatar
Oddometer: 243
I just change the oil pressure switch every 9000 miles when I'm doin the valves
99sleepyhollow is offline   Reply With Quote
Old 01-04-2013, 01:32 PM   #11
charlie264
charlie264's Avatar
Oddometer: 5,202
Its a letronic pressure gauge sleepy...so you can see if it drops rather than the on or off sensor.
Old 01-04-2013, 03:32 PM   #12
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 959
For the cost of after market ones that is probably not a bad idea.
Old 01-06-2013, 06:21 PM   #13
MotoTex OP
Miles of Smiles
MotoTex's Avatar
Oddometer: 678
Swapped the pressure switch today. Here's a few notes:
The Duralast PS177 will require a 27mm socket, instead of the 21mm for the OEM.
You will need to back out the long screw on the starter for the socket to fit.
When you go to town to get the socket you may have to bring back doughnuts.
If you notice the sleeves on the Flex-Jets have melted into a mysterious goo, you might pick up a couple of feet of thin-walled fuel line to replace the sleeves after cleaning all the semi-liquid, semi-crispy sleeve from the adjusters.
Gonna ride it to work tomorrow, hope to be lubing only the internal parts for a while.
04
MotoTex screwed with this post 01-07-2013 at 05:55 AM
Times are GMT -7.   It's 10:19 PM.
