Old 12-30-2012, 10:55 PM   #1
Cobain OP
night owl
Cobain's Avatar
Oddometer: 132
Hitch carrier for motorbikes
Im looking to put 2 motorcycle carriers in the hitch of the front and back of my dads RV to carry our DR650s. I am either going to buy a couple STEEL ones, or make my own. I have bought a cheap aluminum one in the past but you could see it flex with the DR on it. Also i was thinking of using a hitch extender that would make the carriers stick out and up further for clarence. Have you guys bought or made anything like this? Heard bad things about these?
Cobain is offline   Reply With Quote
Old 12-31-2012, 03:16 AM   #2
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,713
I made my own from square stock and channel. I should have made the channel from aluminum structural channel instead of steel it's way overkill. Assuming you are welding in receivers to the chassis, weld in a second one both front and back and make your carrier have two tongues so that the carrier can't rock. Or make guy lines from steel cable thats what I did on my fj and I machined up a special eye bolt to screw into my spare tire
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 12-31-2012, 07:56 AM   #3
74C5
74C5's Avatar
Oddometer: 990
Ultimate MX Hauler http://www.ultimatemxhauler.com/
Makes loading a snap. Not cheap but, works quite well. Does it move? Yes a bit but, that is inherent in the design and isn't a concern.
R1200RT (R1100RT gone)
KLR650 - gone
Don't be the guy who needs to pee on the fence to figure out that it's electrified.
74C5 is offline   Reply With Quote
Old 12-31-2012, 01:42 PM   #4
Cobain OP
night owl
Cobain's Avatar
Oddometer: 132
I was thinking 2 of these, $85 with free shipping. I could brace them together to make stronger. their rated at 500lbs. The RVs already got hitches front and back. Thank you for the reply's.
Times are GMT -7.   It's 02:18 AM.
