Old 12-29-2012, 11:25 AM   #1
unaweep OP
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 20,104
Where does this heat shield go?
2010 990R
I found it in my skid plate. The pen is included to give it a size reference.
I'm trying to get 2 990Rs and a Super Enduro prepped for a Baja trip- basically, pulling the tanks and stuff off, checking connections, changing oil- all the stuff you'd normally do for a couple thousand mile trip in Mex.
Thanks for any help.
I don't have to be right to argue.
NICO
unaweep is offline   Reply With Quote
Old 12-29-2012, 11:34 AM   #2
Leodis41
I wanna Orange one!!
Leodis41's Avatar
Oddometer: 65
It looks like the piece that goes in the cut out of the tank.
The exhaust curls between the engine and the tank from the the front cylinder. You will have to pull your right hand tank to check.
Leodis41 is offline   Reply With Quote
Old 12-29-2012, 11:50 AM   #3
unaweep OP
unaweep's Avatar
Oddometer: 20,104
That's exactly where it came from. Thanks!
NICO
Old 12-29-2012, 02:34 PM   #4
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,710
You can use the foil covered foam insulation tape from Home Depot to craft a replacement, if necessary.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 12-29-2012, 03:13 PM   #5
unaweep OP
unaweep's Avatar
Oddometer: 20,104
Good idea! Thanks. I ended up cleaning the tank and the shield real well then coated the shield with RTV and pasted it on. Should hold up, I hope. Cheers!
NICO
Old 12-31-2012, 08:08 AM   #6
dfmalh
dfmalh's Avatar
Oddometer: 6
Exhaust - Carbon cover
Hi, sure if this is the right place to post my question, but it is heat insulation/cover related...
I have damaged (burned) the bottom part of my rally pants that covers my boot on the exhaust cover that sits above the clutch/engine pod (above the rear brake pedal) on the right of the bike.
Does anybody know if there is any additional protection e.g. additional carbon cover that can go on top of the existing cover?
Thanks for the help.
dfmalh is offline   Reply With Quote
Old 12-31-2012, 09:42 AM   #7
unaweep OP
unaweep's Avatar
Oddometer: 20,104
I have damaged (burned) the bottom end of my rally pants, the part that covers my boot, on the exhaust cover that sits above the clutch/engine pod (above the rear brake pedal) on the right of the bike.
Check CJRacer's posts for his web site. I saw he has some really nice looking carbon fiber exhaust shields for sale. Good luck.
NICO
Old 01-02-2013, 06:25 AM   #8
dfmalh
dfmalh's Avatar
Oddometer: 6
Thank you, I will go and have a look on the website.
Times are GMT -7.   It's 05:52 AM.
