Old 01-03-2013, 07:36 PM   #46
fetid_swamp
fetid_swamp's Avatar
Oddometer: 745
Originally Posted by wrk2surf View Post
...now upgraded to 17.0... I wanted to add I like how easy it is to go back in and add and subtract points and resave.. .....
Originally Posted by greglewis View Post
OK Great!!
I tried it in Chrome rather than Firefox - worked like a charm. Very fast. I guess my problems were with Firefox.
It's a great program - kudos, five stars!
Greg
i was running at 30fps in the firefox i had (which aparently is OK, did the fix and was running at 60 so thats all fine.
but in firefox i was having huge probs with loading and saving.
as per wrk2surf, updated my v13 to the lasest v17 and not everything is good.
working like a charm.
thanks team.
Standing on the front lawn, shirtless, arguing with meth head neighbours while surrounded by bemused cops with dogs and tasers at the ready, his mullet gently blowing in the breeze.
fetid_swamp is offline   Reply With Quote
Old 01-04-2013, 02:52 AM   #47
Evil Invader
Evil Invader's Avatar
Oddometer: 686
Can´t upload gpx-file? Converted from Garmin gdb via Babelgps to gpx, runs in Chrome. Nothing happens.....
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 01-04-2013, 03:55 AM   #48
fetid_swamp
Oddometer: 745
dont know if conversion is your issue but i use gpstrackmaker for conversion duties with no probs.
never used babel
Old 01-04-2013, 01:46 PM   #49
RenoMoto OP
Rally Navigator
RenoMoto's Avatar
Oddometer: 218
File import
Team:
Improving File import and route saving is the number one issue we are working on right now.
What works fine on our computers isn't working at all on some of software and hardware set ups our Beta testers are using.
In the future, we need to get Rally Navigator less sensitive to these variations.
For now, we are updating our Getting Started content and Welcome email to get new users started:
Optimize Your System for Rally Navigator
Firefox and Google Earth 6.2
Get the New Firefox with IPC Control turned OFF
Speed Test your computer here:
Google Earth plugin API speed test and more info
Modern computer with IPC off should be 40-60 Frames per second
This speed test issues a number of Google Earth plugin API calls for every frame drawn. The number of frames per second is a measure on how fast this is done.
Rally Navigator may make thousands of calls per second to the Google Earth plugin. This is called "Inter Process Communication" IPC for short. If each of those calls takes a tiny amount longer you immediately suffer massive performance penalties. These can be in the order of 5 - 10 times slower that they should be.
Turn off IPC Control to the Google Earth Plug In
Type "about:config" into your address bar, you'll get to a page with a lot of settings. Find the line for "dom.ipc.plugins.enabled =true" and toggle it to "false". Restart your browser and Firefox will run 3-5 times faster!
Get Google Earth 6.2 here
Rally Navigator works best using Google Earth Plugin 6.2
Not the latest GE 7.0 betas.
Get Google Earth Keyboard Shortcuts HERE
LOTS of work left to do.
Thanks for the feedback,
Mike
Mike Shirley
Double Diamond Athletic Club - Reno - Nevada
500 XCW - 990 Adventure R - 690 Duke
Pics - Moto - Dakar Rally - Rally Mongolia - TAT - F1 - Sports Cars - Crap
Rally Navigator - Create, Print & Share Rally Routes with Google Earth.
RenoMoto is offline   Reply With Quote
Old 01-04-2013, 03:04 PM   #50
Mr. DNA
Motorcycling Professor
Mr. DNA's Avatar
Oddometer: 10
Did you do anything to improve loading time? I just loaded a track I started last week and it seemed much quicker than before.
Keep up the good work! I've started planting the idea to my local group to buy 6" roadbook holders.
So far, this is the best deal I've found for a manual holder: $45 USD + shipping
Mr. DNA is offline   Reply With Quote
Old 01-04-2013, 05:30 PM   #51
fetid_swamp
Oddometer: 745
Originally Posted by Mr. DNA;20396030Keep up the good work! I've started planting the idea to my local group to buy 6" roadbook holders.
So far, this is the best deal I've found for a manual holder: [URL="http://www.raiddesigns.com/en/products/products-and-services/rallye-parts/navigation/raid-designs-rb001-manual-roadbook-holder.html"
$45 USD + shipping[/URL]
for a manuel route sheet scroller in aus/nz:
http://www.torpedo7.com.au/products/...e-sheet-holder
$20 +post of $9 almost regardless of order size.
soz, dont know if they do international orders.
Old 01-05-2013, 11:19 PM   #52
RenoMoto OP
Rally Navigator
RenoMoto's Avatar
Oddometer: 218
GPX Import Update - Like relationships, its complicated.
Inmates:
Here is some info regarding GPX import from our developer, Paul van Dinther at Planet in Action
Hi Mike, I had a close look at the various GPX files. Some indeed won't import properly. This is due to the fact that the "trk" (track) section is missing in the file.
It appears that some GPX exporters choose to describe the track using the "route" section in the GPX file and some of the files you gave me contain many routes.
It is clear different applications write GPX data in different ways. They are all compliant to GPX but it is such an elaborate scheme that the same information can be described in many different ways. I found three different formats of route data in the sample GPX files.
Right now, only "trk" is implemented.
Rally Navigator will currently only import GPX files that were saved with route data in the "trk" (Track) section of the file, not with route data in the "Route" fields
It is possible to convert Route GPX files to "Track" oriented using GPSBabel
Here is a screen shot of the GPSBabel track converter with the proper windows open to set the conversion from "routes" to "tracks"
I would appreciate if a few of our testers will try this and report back.
Obviously this could be more user friendly, but does give us an immediate answer to the failed loading some of you were experiencing.
We are exploring the capability to import GPX files that are also in "Route" format.
For those of you with extra time and brain cells, here is more info regarding GPX file types and conversion:
GPSBabel - FREE file conversion program
GPSBabel - GPX file type info
GPX: the GPS Exchange Format
Thanks,
Mike
Mike Shirley
RenoMoto screwed with this post 01-06-2013 at 05:17 PM
Old 01-07-2013, 06:52 PM   #53
KTMforget
KTMforget's Avatar
Oddometer: 826
Sweet
This is exactly what I have been looking for to put together the routes for our annual Selkirks Rally. Let me know if you need more testers!
Kurt
Kurt - Black Dog Cycle Works
Check out our new website: BLACK DOG CYCLE WORKS
We specialize in the best parts for BMW and KTM Adventure bikes. WE TEST WHAT WE SELL!! Not just MADE in the U.S.A., made BETTER!
KTMforget is offline   Reply With Quote
Old 01-07-2013, 10:39 PM   #54
Dingaan
Oddometer: 7
Another tester?
Hey Mike! If you can accept another tester, I've sent you a email!
RB Editor is just not doing it for me anymore, and the only apple I have, I'm eating now!
Amageza Cross-Country Rallye, South Africa: "Tough enough to impress A.S.O!"
Dingaan is offline   Reply With Quote
Old 01-08-2013, 05:14 AM   #55
oossie
oossie's Avatar
Oddometer: 118
i'm in the middle of creating a roadbook and reported already several issues. Most important "Km" vs "Miles" or even "Meter" option for non US regions would be great for global use.
But the project is great and love how it works. Also did reating roadbooks in MS-Word, later in MS-Visio (with VBA code on the backend) still wasn't satisfied turned occasionally to TT Roadbook Editor.
But now with RallyNavigator finally a piece of work that can stand my heat...
Visit dirttrack.nl for all your testimonials
dirttrack.nl
: Rally - Offroad - Allroad e-zine
owner of tha beast KTM 660 Rally
oossie is offline   Reply With Quote
Old 01-08-2013, 06:37 AM   #56
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,441
I wouldn't mind testing it you need another. I am not 100% sure my home computer will run it but worth a shot.
Email sent.
Seth S
Seth S is offline   Reply With Quote
Old 01-08-2013, 12:55 PM   #57
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,606
Seth if mine does yours will !
wrk2surf is online now   Reply With Quote
Old 01-08-2013, 01:00 PM   #58
Seth S
Seth S's Avatar
Oddometer: 4,441
mine is slow by modern standards and a rocket for 2001
Seth S
Old 01-08-2013, 02:22 PM   #59
Seth S
Seth S's Avatar
Oddometer: 4,441
Running it on my non home PC right now which is an HP Z400 workstation with 4 processors and 4 gigs of ram running windows XP and it is a 64 bit system. Running GE 6.2 and Google Chrome browser and so far my 700 point GPX file loaded nicely into the application and I am off and editing without issue.
Seth S
Seth S screwed with this post 01-08-2013 at 03:30 PM
Old 01-14-2013, 01:56 PM   #60
RenoMoto OP
Rally Navigator
RenoMoto's Avatar
Oddometer: 218
New Features; Support for Kilometers, Improved GPX import, show/hide GPS Coordinates
Beta Team:
Recent upgrades to Rally Navigator:
  • Improved GPX import - GPX files created from Tracks and Routes
  • Improved Saving function - Status bar confirms "Project Saved"
  • Progress reporting for import - Displays points as they are imported
  • Support for Kilometers/Miles (much requested!)
  • Ability to show/hide GPS Coordinates in Roadbook
Lots of other improvements in the works in the next couple of weeks.
We are ready to add more Beta Testers - any other folks interested? Please email me.
Mike Shirley
Times are GMT -7.   It's 09:04 PM.
