Old 12-30-2012, 08:56 PM   #1
folknride OP
Old Adventurer
folknride's Avatar
Oddometer: 682
Headed for California with a problem!
As I loaded up my KTM 990 to head for 2 months in Palm Desert, I spotted a nice puddle of oil on the swing arm - presumably from a leaking rear shock seal. I loaded up anyway and now will arrive with a busted bike. Any advice from KTM savvy members would be helpful. I've had some previous dealings with the local dealer, and not sure I would let them at the bike - but could be wrong.
A rebuild is beyond my wrenching abilities and I have no place to work anyway. I could remove it if sending it off is a good idea.
Arrgh
folknride is offline   Reply With Quote
Old 12-30-2012, 09:12 PM   #2
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 856
PM sent!
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 12-30-2012, 09:13 PM   #3
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 997
I would wash it clean, do a short ride to confirm that is where the oil is coming from first. I guess if it is the shock you will have no other option than remove it and send it to someone who can do a rebuild.
Bummer !
rossguzzi is offline   Reply With Quote
Old 12-30-2012, 09:19 PM   #4
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,862
Precision Concepts is local to the area, you might call them (if the PM you got doesnt help out) and tell them your situation, might be able to pull ,repair and put back on at their shop.
Good luck.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 12-30-2012, 09:30 PM   #5
folknride OP
Old Adventurer
folknride's Avatar
Oddometer: 682
Thanks for the local connection and other suggestions. Yes, diagnosis is my first step. It was too rushed, cold and snowy at home. It could be (hope springs eternal) slopped oil from the valve adjust and oil change I just completed. I ran the bike for 15 minutes after the job to check for leaks - none showed up.
Old 12-30-2012, 09:45 PM   #6
K9SAR499
I can make that!
K9SAR499's Avatar
Oddometer: 104
Inside line moto I trust and they know ktooms
Kelly
01 KTM 640
Surly Krampus
K9SAR499 is offline   Reply With Quote
Old 12-30-2012, 10:47 PM   #7
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 997
My guess then is its a valve cover gasket not seated correctly. Happens often on Aprilia`s too. Dont ask.
Old 01-11-2013, 06:42 PM   #8
folknride OP
Old Adventurer
folknride's Avatar
Oddometer: 682
Thumb Thanks to Get Dirty Dirt Bikes
Got my bike with rebuilt shock today from Get Dirty Dirt Bikes (Morongo Valley), and can't say enough about Dave's help and attitude. What a great guy! Because of complications it took a while, but they went way over the top to get it done right!
Then even helped me out with my "stupidity problem" - The right gas line was un-attached - culprit was your truly - and when I filled up (luckily right next door), gas peed all over the place. It was such fun reconnecting it - thanks again Dave!
(now if it would just stop snowing so we could ride )
Old 01-12-2013, 11:22 PM   #9
GoNOW
Oddometer: 1,588
Good luck.
Precision Concepts worked with KTM to develop the suspension on the big KTM. Nobody knows it better.
GoNOW is offline   Reply With Quote
Times are GMT -7.   It's 01:29 AM.
