Old 12-30-2012, 11:17 PM   #1
Stretch67 OP
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,439
XR400 Thread Index
If you are investigating a certain topic, write down the Post Numbers listed here for that topic. Then click on 'Hayduke's XR400 Thread' below and scroll through the pages until you find the correct Post Numbers (in the upper-right corner).
Click: Hayduke's XR400 Thread
Enjoy!
1996-2004 Honda XR400R Pros & Cons
78, 108, 391-98, 623, 859-62, 1536, 1541, 1592-93, 1810-14, 2241-42, 2825, 3148-49, 3178, 3242-48, 4187-88, 4777, 5086, 5194, 5297
XR400 Frequently Asked Questions & General Information
Link, Link, 1654, 2012-13, 2084, 2424, 2432, 3125, 3597-3600, 4076-77, 4092, 4103, 4400-4405, 4413, 4554, 4627, 4658-59, (4679-80, 4683), 4750, 5025-27, 5129
AIR FILTERS
280-86, 623, 1295, 2326-27, 2333, 2717, 3199, 3653-58, 4350, 4353-54
BEARINGS
6716, 7564
BRAKES
2415-18, 3316-17, 3551-55, 3795, 4736-39
Rear Brake Parts Interchangeability
547-8
CARBURETOR
Stock
1109-10, 1199, 1207-17, 1305-06, 1320, 1543, 1787-88, 1810, 1837, 2244, 2296-98, 2325, 2420, 2536, 2539, 2850-51, 2860, 2875, 2886-87, 3038-40, 3104-06, 3130, 3190, 3268, 3478, 3514, 3639, 3691, 3693-95, 3706, 3808, 4270-74, 4526, 4715, 5035, (5102-06, 5108, 5110), 5174-81, 6592-6600
Idle Screw Mod
2213, 2236, 2308-09, 3158-62, 8085
Choke Plate Issues
2426-28, 2431, 2434, (3305, 3310-13), 3318, 3320-21, 3328, 3330, 3340-43, 3351, 4985-87
Removal Tip
8603-5
Float Level Adjustment
Link
Jetting
Link, 36, 234, 252-4, 279, 455-7, 485-6, 489, 596-99, 662, 877-8, 982-4, 993, 996, 1069, 1376-77, 1379, 1380, 1382-3, 2059-67, 2070, 2322, 2325-26, 2510, 2774-75, 2777-79, 2781, 2850, 2871, 2875, 2878, 2902, 3041, 3104-06, 3225, 3264-65, 3268, 3463-68, 3472, 3489-90, 3492-93, 3495, 4112, 4337-38, 4619, 4661-62, (4734-35, 4738), (4764-68, 4770, 4780), 4968, Link
Carb, Pumper
Link, Link, 225, 317, 369-70, 559-567, 657, 1069, 1071-74, 1076-77, 1135-36, 1149, 1265, 1279, 1282, 1284, 1287, 1293-95, 1302-04, 1318, 1660, (1899, 1906-09), 2515-16, 2549-57, 2632, 2634, 2837-38, 3062, 3153, 3155, 3260, 4096-70, 4078, 4097-4100, 4108, 8300
CENTERSTAND
2015-27, 2030
CHECKING OIL PROCEDURE
Link, 256-263, 1037-39, 5398-5411
CLUTCH
2583-86, 2627, 2879 & 81, 2895-97, 3521-23, 4593-97, 4600
Auto Clutch
3207-08, 3444-47, 3488
Clutch Plates, Indexing
5515
DE-COMPRESSOR
378-80, 871-2, 879, 887-8, 2080, 2096-2101, 2107, 2117, 2539, 2678-79, (2793-95, 2799), 3014, 3237, 4693, 4696, 6563
DUAL-SPORTING (Converting an XR4 to Street-Legal)
Link
ELECTRICAL
Converting to 12 Volts DC
8367-69
ELECTRIC START CONVERSIONS
Link, 155, 165, 181, 190, 709, 714, 2460, 2590-91, 2602, 2694, (2859, 2862, 2883), 3046, 3064-98, 3070, 3073-74, 3077, 3252, 3519, 3659-67, 3674, 4019, 4257, 4880, 4883, 5270-71, 5275-79, 5393-95, 6168, 6796, 8241
ELECTRICAL TROUBLESHOOTING
2179, 4817
ELECTRICAL WIRING SCHEMATIC
2643, 3024
ENGINE START PROCEDURE
27, 36, 224, 226, 399-402, 478, 937, 1110, 1524, 1534, 1538
Difficult To Start
70, 147, 150, 155-8, 171-2, 852-4, 912-19, 924-28, 937, 1270, 1272, 2907-13, 3038-42, 3044-45, 3047, 3104-06, 3128, 3146, 3156-58, 3164-65, 3168, 3258, 3261, 3358-64, 3370, 3452-61, 3471, 3472, 4061-66, 4980-82, 6217, 6247
ENGINE WORK
621, 1082-84, (2462-63, 2471), 2519, 2524, 2539-41, 2569, 2598, 2640, 2666-67, (2732, 2737, 2743), 2988, 2992, 3282-84, 3536-42, 3545, 3590-92, 3728, 3917 & 3920, 3954-65, 4021, 4373, 4500, 4751, 4918, 5129, (5136, 5138), 5331-40, 5343-50
Big-Bore Cylinder & Piston
191, 305-6, 571-3, 588-91, 1784, 1789-1803, 2149-50, 2592-94, 2597, 2855-57, 2863, 2865-66, 3570, (3920-21 & 3926-35), 3987-94, 4185, 4831 & 36, 4923-31, 4983, 5393-95
Camshaft (Timing) Chain
Link, 2293-94, 2393, 2414, 2609-13, 2624-25, 2828, 2930-32, 3378, 3586, 3588, 3678-79, 4875, 4933-34, 5002, 5302, 7141-7153
Cam Chain Adjuster Mod
7058
Camshaft Bearings
2752-61
Case Repair
3071
Piston & Cylinder, OEM
8320
Sump Screen
Link, Link
Valve Adjustment
480, Link, 941-5, 3373-76 & 78, 3380, 3505, 3509, 3873, 3878-80 & 83, 4215, 4262-67, 4477
EXHAUST
986-7, 1021-23, 1040-43, 1048, 1050, 1052-3, 1065, 1287, 1289, 1292, 1295, 1304, 1309, 1736, 1978, 2005-07, 2044-45, 2049-50, 2052-57, 2153, 2450-51, 2510, 3096-3100, 3112 & 3117, 3119, 3601-05 & 16, 3906-14, 4025, 4233, 4249, 4812
FOOTPEGS Feetpegs?
1249, 1448, 1566, Link
Brake Pedal & Shift Lever
1228, 1230, 4425, 4428-29, 5063 & 5065, 5249, 5261
GASKETS vs. SILICONE
Link
GEARING
353, 450-53, 524, 644, 792, 801, 1126, 1132, 1143, (1341 & 1343), 1387, 1415-20, 1424, 1439-41, 1450-51, 1456, 1549, 1729-33, 1874, 2199, 2224, 2281-82, 2317-19, 2805-15, 3272-73, 3275, 3733-34, 4047, 4053-55, 4644-51, 4697-4704, 7891-7900
GORDON’S MODS
Link, 1319
HANDLEBARS, RISERS, & CABLES
112-117, 1371, 1566, 1572, 2093-95, 2348, 2367, 2391, 2764-66 & 68, 3108, 3569 & 71, 5161, 5390
Heated Grips & Gear
866, 4675
Instruments
703-5, 1236, 1239, 1246, 1347-56, 1360-62, 1870-72, 1943, 1947-50, 2104, 2338, 2352, 2448, 2455-56, 2571-72 & 74, 2758, 2921, 3115, 3118, 3136-38, 3154, 3413-14, 3617-24, 3756, 3922-23, 4075, 4490, 4639-41, 4965-66, 5141-43, 5148, 5154, 5207, 5236
KICKSTAND BREAKAGE
1357-59, 1713, 1717, 1789, 2214-17, 4955-56, 4958, 5215, 5223
LIGHTING
34-36, 224-26, 331, 334-6, 344-5, 354, 358-9, 399-402, 414, 421-6, 478, 679-89, 742, 770-3, 775-9, 814-15, 848, 961, 1018-19, 1344, 1755-65, 1893-5, 2081, 2127-28, 2174, 2258, 2260, 2262, 2276 & 78, 2285, 2330-32, 2380-83, 2645-47, 2654, 2656, 2669, 2675, 2803, 2925-26, 3018-19, 3048, 3353-55, 3365-69, (3849, 3852-55, 3862), (4036-38, 4041), 4089, 4141-46, 4148, 4154-58, 4189-90, 4223-23, (4251, 4253, 4255-56, 4258), 4345-47 & 4351-52, 4385-94, 4460, 4520-23, 4548-49, 4604, 4633, 4638, 4668, 4859, 4909-10, 4942, 5021, 5028, 5058-59, 5065, 5067-69, (5301, 5311-12)
Quick-Disconnect Turn Signals (Way Cool)
2803-04
OIL CHANGE PROCEDURE
Link
OIL, DEBATES OVER WHICH IS BEST
Oh, hell no. Don't even think about it.
OIL TEMPERATURE
1312-13, 1825, 1941-43, 2380-83, 2759, 2770-71, 2895, 2897, 4451, 4453-54 & 4456, 4706
PANNIERS & RACKS
132, 342, 433, 759, 1179, 1195, 1232, 1454, 1584-86, 2197-98, 2101, 3298, 3354, 3510-11, 3726, 3779, 4026-27, 4035, 4059, 4639, 4853 & 55, (5157, 5163-64), 5204, 5471
PLASTIC
850, 857-8, 894, 1346, 2115-16, 2120-22, 2186-88, 2200, 2261 & 67, 2357, 2391, 2436, 2478-80 & 89, 2505, 2507, 3738-43, 3393, 5020
Big Fuel Tanks
24, 38-41, 68, 401-5, 408-9, 527, 550-52, 554, 690, 694-5, 804-5, 834-47, 1403-04, 1407, 1594-08, 1608, 1631, (2086-2092), 2329, 2335, 2372, 2378, 2391, 3001-03, 3051, 3218-21, 3681-89, 4340, 4369-70, 4586, 4625, 4665, 4676-77, 5048-50, 5790, 8002
Fairings
454, 526, 2271, 2340, 2351, 2373-74, 2417, 3731 & 3744-50, 3756, 4583-85
RESTORE / REFURBISH
922, 3728, 4723-30, 5172
RIDES
74, 184-5, 641, 744, 1009, 1124, 1182, 1245, 1431, 2302, 2474, 2500, 2639, 3334, 3415, 4040, 4171, 4581, 4621, 5371, 5448, TAT, Russia & Mongolia, Isle Of Man, Dirt Dawg Chronicles
XR400 RIDE REPORT & PICTURE THREAD: http://advrider.com/forums/showthread.php?t=954996
SEAT MODS
632-6, 789, 1501-08, 1511, 1514, 2203-05 & 08, 2210-11, 3345-47, 5455-56
SHOP MANUALS
3126, 3144, 3865
SHOP TOOLS
3459, 3767, 5091, 5107, 5190
SKIDPLATES
1188, 2249, 2982-83, 3971-76, 3981-82, (4147, 4149), 4710
SPARK PLUG CAP RESISTOR MOD
Link
STATOR
54-60, 235, 239, 313, 319, 911, 923, 1247-48, 1882, 2078, 3018-19, 3043, 4081, 4089, 4473-74, 4479, 4991-94, 5183-84, 5323-25, Link, 6247, 6599, 7470
Stators De-Mystified
Link
SUBFRAME BREAKAGE
1682, 1691-98, 1713, 1768, 2326, Link
SUPERMOTARD MODS
125, 679, 4419
SUSPENSION
495-6, 664, 667, 906-7, 976, 1087-89, 1257, 1375, 1378, 1381, 1471-72, 1486, 1509-10, 1551, 1553, 1606, 1610-30, 1634-36, 1646, 1915-16, 2396, 2406, 2538, 2578-80, 2658-63, 3027, 3031, 3131-32, 3272, 3433, 3535, 3559, 3594, 3596, 3647-52, 3763-67, 3798-3802, 3889-97, 6753-6771
Fork Disassembly Tool
5386, Link
Fork Spring Swap
4489, 5387-88
Fork Seal Replacement
Link to Illustrated How-To
Fork Oil Discussion
Link
Fork Oil Change
4176, 6552-59
Rear Shock Rebuild
4239, 4241, 4244, 5461-65
Rear Spring Pre-Load (Sag)
Link, 8229
Shim Stack Mod, Front Forks
Link, 4159-64, 4180-82, 5374, 5467
Steering Stabilizers
931-2, 2823, 2844, 5013, 5070, 5073, 5075
Spring Rates
Link
SWINGARM BOLT. And may the Lord have Mercy on your soul.
Link, 141-43, 201, 1706-12, 1737, 1768, 1773-81, 1976, 2521, 3158, 3277, 3282, 3423-24, 3428, 3442, 4208, 4268, 4503, 4713, 5149, 5155, 5167, Link
T-VENT MOD
428-9, 463-5, 467, 539-40, 543
TIRES
203-5, 207-8, 316, 321, 324-5, 346-9, 529-35, (1032 & 1036), 1252, 1254, 1338, 1393-94, 1481, 1490, 1493, 2138, 2142, 2147, 2151, 2303-04, 3035, 3405, 3644, 4028-31, 4033, 4082, 4543, 4546-47, (4555-59, 4561-62), 4570-71, 4853, 5364-70 & 78
TROUBLESHOOTING
(3710 & 18), (3840-48), (3940-46 & 52), 4588, 4731-32, (4792, 4820-23), 4874, (4914-16)
Engine Dies When Clutch Lever Pulled In
4179
Shifting Issue
2361
TOOL KIT
519, 697, 944, 946-53, 2672, 2787, 2796-98, 3519, 5122, 5126
VALVE ADJUSTMENT
Link
WHEELS
Bearings
6716, 7564
Axles
Specs, 752-3
Front Wheel Removal
4360-8
Rim Repair
1271-8, 3304-09
Spokes
2191-5 & 2207, 4292-5
Wheel Swaps & Compatibility
CRF 450 / XR400
2674, 2985-6
XR250 / XR400
876
XR400 / XR600 & 650
2402, 4687, 7173
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 screwed with this post 02-28-2015 at 09:25 PM
Stretch67 is online now   Reply With Quote
Old 12-31-2012, 07:40 AM   #2
mark1150
mark1150's Avatar
Oddometer: 187
Thank you for taking the time and effort in producing this thread.
mark1150 is offline   Reply With Quote
Old 12-31-2012, 08:37 AM   #3
XR4EVER
919 excuses to ride!
XR4EVER's Avatar
Oddometer: 1,087
"Mad Scientist" doesn't even begin to describe the workings of your mind to want to tackle that!
I hate bear grass.
XR4EVER is offline   Reply With Quote
Old 12-31-2012, 09:44 AM   #4
Ace100
Expert Tomfoolerist
Ace100's Avatar
Oddometer: 424
Ace100 is offline   Reply With Quote
Old 12-31-2012, 10:43 AM   #5
Rman237
Ride Rural Texas
Rman237's Avatar
Oddometer: 799
Very impressive! Quite an undertaking to say the least. Much appreciated.
'06 TW200 Mountain Goat '06 XR650L Sumo
'98 XR440R trick and plated '98 KDX220 plated '84 RZ350 '83 XR350R '83 XR200R
'84 ATC125 '71 CL175
Rman237 is offline   Reply With Quote
Old 12-31-2012, 02:12 PM   #6
cirell
Oddometer: 119
Thanks and Happy New Year
cirell is offline   Reply With Quote
Old 12-31-2012, 09:39 PM   #7
mookybird
Gramps
mookybird's Avatar
Oddometer: 213
Wow, what an undertaking it's bookmarked and Thank you
mookybird is offline   Reply With Quote
Old 01-01-2013, 12:44 AM   #8
Whistling Weasel
Oddometer: 14
Great work, that must have taken some time. Will be of great help in the future.
Whistling Weasel is offline   Reply With Quote
Old 01-01-2013, 12:39 PM   #9
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,439
If any of you cats know of XR400-related ADV threads outside of Hayduke's XR4 Thread, please post links here. We'll build a max-radoo XR4 online Liberry.
IBA # 33113
Alaska
XR400 Index
Old 01-01-2013, 08:26 PM   #10
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,176
XR400 Swingarm Pivot Bolt
my personal fave
DrLewall is offline   Reply With Quote
Old 01-01-2013, 10:07 PM   #11
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,439
A simple ADV site search using 'XR400' as the key words for the Thumpers Forum resulted in the following threads:
XR400R Adventure Bike: http://advrider.com/forums/showthread.php?t=215070
XR400 No Spark: http://advrider.com/forums/showthread.php?t=1007214
XR400 Rectifier Installation: http://advrider.com/forums/showthread.php?t=1003522
XR400 Kick-Start Problem: http://advrider.com/forums/showthread.php?t=974974
XR400 Brake Problem: http://advrider.com/forums/showthread.php?t=971485
XR400 To A SuperMoto: http://advrider.com/forums/showthread.php?t=968268
XR400 Question: http://advrider.com/forums/showthread.php?t=965668
My $200 '99 XR400: http://advrider.com/forums/showthread.php?t=957470
Looking at an XR400: http://advrider.com/forums/showthread.php?t=965206
Dual Sporting an XR400... Rectifier Voltage Concerns: http://advrider.com/forums/showthread.php?t=952107
Straightening Bent Footpegs (Feetpegs?): http://advrider.com/forums/showthread.php?t=948668
Dual-Filament Headlight Conversion: http://advrider.com/forums/showthread.php?t=944022
XR400 For L.A.-Barstow-Vegas: http://advrider.com/forums/showthread.php?t=941382
Burning Oil At Speed: http://advrider.com/forums/showthread.php?t=927648
Space Behind Number Plate For a Computer?: http://advrider.com/forums/showthread.php?t=847571
Voyager Mounting on XR400: http://advrider.com/forums/showthread.php?t=844764
XR400 vs. CRF450X: http://advrider.com/forums/showthread.php?t=836423
XR400 Best Mods: http://advrider.com/forums/showthread.php?t=837089
1998 XR400 Build: http://advrider.com/forums/showthread.php?t=650272
XT600 or XR400?: http://advrider.com/forums/showthread.php?t=826570
XR400 or WR250R?: http://advrider.com/forums/showthread.php?t=812331
Does Anyone Know What Part This Is?: http://advrider.com/forums/showthread.php?t=811170
Top End Rebuild On A Cheap XR400: http://advrider.com/forums/showthread.php?t=351360
XR400 Electrix Issues: http://advrider.com/forums/showthread.php?t=766728
Pic Of XR400 And XR650L Together?: http://advrider.com/forums/showthread.php?t=759493
What's Your Mileage?: http://advrider.com/forums/showthread.php?t=751535
Is This A Good Price For An XR400? Help!: http://advrider.com/forums/showthread.php?t=740349
Sold My Trusty XR4, Now What TE630: http://advrider.com/forums/showthread.php?t=736181
Help Decide... XR400 or RDZ400?: http://advrider.com/forums/showthread.php?t=731618
XR400 or DRZ400 For Off-Road: http://advrider.com/forums/showthread.php?t=724234
XR400 Carb: http://advrider.com/forums/showthread.php?t=720978
KTM 350 XC-f = XR400 For Today? http://advrider.com/forums/showthread.php?t=715499
DR350 Or XR400?: http://advrider.com/forums/showthread.php?t=703537
KLR650 or XR400?: http://advrider.com/forums/showthread.php?t=397585
Throttle Cable Issues on CRF450 Throttle: http://advrider.com/forums/showthread.php?t=693939
XR400 or XR250R For Singletrack - Which One?: http://advrider.com/forums/showthread.php?t=689172
What To Buy? Opinions Please... XR400 - DRZ400E: http://advrider.com/forums/showthread.php?t=659081
XR400 Pumper Carb And Electric Start: http://advrider.com/forums/showthread.php?t=389693
XR400 Big-Bore Conversion?: http://advrider.com/forums/showthread.php?t=640794
XR400 Blues: http://advrider.com/forums/showthread.php?t=634997
What Bike For Overland Morrocco - XR400 or WR450?: http://advrider.com/forums/showthread.php?t=626091
Noisy XR400: http://advrider.com/forums/showthread.php?t=557392
Dual-Sport Kit on XR400 Running Off Stator?: http://advrider.com/forums/showthread.php?t=602537
XR400 Sidestand: http://advrider.com/forums/showthread.php?t=578880
XR400 Questions????: http://advrider.com/forums/showthread.php?t=565281
Thinking Of Changing From XR400 To XR650L: http://advrider.com/forums/showthread.php?t=564172
XR400 Not Starting: http://advrider.com/forums/showthread.php?t=538637
XR400 vs. WR250R: http://advrider.com/forums/showthread.php?t=539766
Larger Fuel Tank And Pannier Racks For An XR400: http://advrider.com/forums/showthread.php?t=534309
Larger Brake Pedal? http://advrider.com/forums/showthread.php?t=888879
Holy Hot Damn... XR400: http://advrider.com/forums/showthread.php?t=523969
Talk Me Out Of An XR400 If You Can: http://advrider.com/forums/showthread.php?t=516795
New Love Affair: http://advrider.com/forums/showthread.php?t=893422
IBA # 33113
Alaska
XR400 Index
Stretch67 screwed with this post 09-26-2014 at 04:22 PM
Old 01-01-2013, 10:47 PM   #12
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,439
XR400 Pic Thread: http://advrider.com/forums/showthread.php?t=936936
XR400 Carb Issues Over Whoops: http://advrider.com/forums/showthread.php?t=936120
XR400 vs. KTM 400 EXC?: http://advrider.com/forums/showthread.php?t=500706
XR600 and XR400 Parts Interchange?: http://advrider.com/forums/showthread.php?t=500650
Help! Strange XR400 problem In Chile: http://advrider.com/forums/showthread.php?t=495438
Motor Life For XR400 Before Rebuild Needed: http://advrider.com/forums/showthread.php?t=490304
Boring Out a XR400 Engine: http://advrider.com/forums/showthread.php?t=488298
XR400 vs. DRZ400: http://advrider.com/forums/showthread.php?t=482781
What's The Best Exhaust System For XR400?: http://advrider.com/forums/showthread.php?t=483572
How Do I Find TDC On A XR400?: http://advrider.com/forums/showthread.php?t=464919
Edelbrock On A XR400 - Sticking Throttle Linkage: http://advrider.com/forums/showthread.php?t=452679
Plastics From XR400 & XR650R - Question: http://advrider.com/forums/showthread.php?t=426177
XR400 Replacement: http://advrider.com/forums/showthread.php?t=411588
XR400 Spoke Wrench Size: http://advrider.com/forums/showthread.php?t=395840
XR400 In A 250 Frame?: http://advrider.com/forums/showthread.php?t=392473
XR400 Spark Plug Cross-Threaded. Help!: http://advrider.com/forums/showthread.php?t=385366
Buying A Used XR400. What Do I Need To Look AT?: http://advrider.com/forums/showthread.php?t=373640
XR400 Found, Is It Worth It?: http://advrider.com/forums/showthread.php?t=371927
XR400 Or 640SM TAT?: http://advrider.com/forums/showthread.php?t=369205
XR400 vs. CRF450X vs. CRF250X: http://advrider.com/forums/showthread.php?t=362055
1998 XR400 Good Year?: http://advrider.com/forums/showthread.php?t=362049
Dirt-Bagz Pannier Rack For XR400?: http://advrider.com/forums/showthread.php?t=309174
XR400 Petcock Repair?: http://advrider.com/forums/showthread.php?t=343070
XR400 Fork Flex Or A Bigger Problem?: http://advrider.com/forums/showthread.php?t=338596
XR400, Red Weapon: http://advrider.com/forums/showthread.php?t=336873
Dunlop 908RR On A XR400?: http://advrider.com/forums/showthread.php?t=335664
Making An XR400 'Quiet'!: http://advrider.com/forums/showthread.php?t=300210
XR400 Questions: http://advrider.com/forums/showthread.php?t=319845 and http://advrider.com/forums/showthread.php?t=319334
1999 XR400: http://advrider.com/forums/showthread.php?t=317119
Will XR600 Engine Fit XR400 Chassis?: http://advrider.com/forums/showthread.php?t=299764
Honda XR400 Supermotard 2007 Model: http://advrider.com/forums/showthread.php?t=316622
XR400 Wheel Offset In Forks?: http://advrider.com/forums/showthread.php?t=307661
XR400 Taller Handlebar: http://advrider.com/forums/showthread.php?t=309132
XR400 Hard To Start, Poor Idle: http://advrider.com/forums/showthread.php?t=281120
XR400 Dirt-Bagz: http://advrider.com/forums/showthread.php?t=278334
XR400: http://advrider.com/forums/showthread.php?t=277432
XR650 vs. XR400: http://advrider.com/forums/showthread.php?t=263260
Quest For My Own PostApokolypto XR400: http://advrider.com/forums/showthread.php?t=256970
IBA # 33113
Alaska
XR400 Index
Stretch67 screwed with this post 11-25-2013 at 08:04 PM
Old 01-01-2013, 11:18 PM   #13
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,439
XR400 Choke Plate?: http://advrider.com/forums/showthread.php?t=254754
XR400 Ricky Stator Install With Dakar DS Kit: http://advrider.com/forums/showthread.php?t=254140
XR400 Jetting For Colorado?: http://advrider.com/forums/showthread.php?t=243725
Advice Needed... XR400 To What Next?: http://advrider.com/forums/showthread.php?t=241647
XR400 Specs: http://advrider.com/forums/showthread.php?t=237025
Oversprung XR400 Question: http://advrider.com/forums/showthread.php?t=231155
XR400 vs. DRZ: http://advrider.com/forums/showthread.php?t=225142
Looking At A Used '01 XR400: http://advrider.com/forums/showthread.php?t=229033
I Need An XR400 Engine: http://advrider.com/forums/showthread.php?t=217437
XR400 & Trailtech Vapor Compatibility: http://advrider.com/forums/showthread.php?t=212979
XR400 Spark Plug Change: http://advrider.com/forums/showthread.php?t=207108
Mid-Size Bike Comparisons?: http://advrider.com/forums/showthread.php?t=201886
XR400 2001 Suspension Recommendations?: http://advrider.com/forums/showthread.php?t=205049
XR400 Valve Adjustment Question: http://advrider.com/forums/showthread.php?t=204267
Honda XR400 Starting, Or Lack Of!: http://advrider.com/forums/showthread.php?t=200588
XR400 Questions: http://advrider.com/forums/showthread.php?t=198531
XR400 Idler Gear Question: http://advrider.com/forums/showthread.php?t=195303
XR400 / XR600 Tank Confusion: http://advrider.com/forums/showthread.php?t=188434
1996 XR400: http://advrider.com/forums/showthread.php?t=182454
XR400 2 Up?: http://advrider.com/forums/showthread.php?t=179963
XR400 A Bit Smokey At Startup: http://advrider.com/forums/showthread.php?t=169807
XR400 and XR650R Same Stator?: http://advrider.com/forums/showthread.php?t=162691
XR400 vs. DRZ400E: http://advrider.com/forums/showthread.php?t=157126
XR400 Upgrade To ProTapers: http://advrider.com/forums/showthread.php?t=151340
Street Tagged XR400: http://advrider.com/forums/showthread.php?t=125077
XR400 Query - Who Rides One For Tails / Enduros: http://advrider.com/forums/showthread.php?t=117808
XR400: http://advrider.com/forums/showthread.php?t=93418 and http://advrider.com/forums/showthread.php?t=93419
What Happened To The XR400?: http://advrider.com/forums/showthread.php?t=84855
Need Suggestions - XR400 Tank: http://advrider.com/forums/showthread.php?t=73881
Honda's XR400 Based Motard: http://advrider.com/forums/showthread.php?t=73103
XR400 Or Similar - Cheapo Quest: http://advrider.com/forums/showthread.php?t=64510
XR400 - The Freshening: http://advrider.com/forums/showthread.php?t=58652
Just Bought A 2001 XR400 - Advice Wanted: http://advrider.com/forums/showthread.php?t=52400
IBA # 33113
Alaska
XR400 Index
Stretch67 screwed with this post 01-01-2013 at 11:39 PM
Old 01-07-2013, 03:44 PM   #14
Ed@Ford
Oddometer: 1,584
Stretch67....holy crap....this is an incredible maximum opus on XR400R!! Thanks
Ed@Ford is offline   Reply With Quote
Old 01-07-2013, 05:59 PM   #15
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,439
Thanks, Brother! I had some free time during the holidays, and was waiting on back-ordered XR4 parts... reading ADV instead of tinkering, and it seemed like a good idea at the time...
IBA # 33113
Alaska
XR400 Index
Stretch67 screwed with this post 01-07-2013 at 06:16 PM
Times are GMT -7.   It's 09:37 PM.
