01-08-2013, 08:46 AM
#151 |
Oddometer: 10,319
I don't want to read it unless it agrees with me.
Jim Moore "Marines good. Press bad" -Turkish |
01-08-2013, 12:09 PM
#152 | |
I'd rather be riding
Oddometer: 2,567
When at speed, when I enter a corner, from the time of the turn in, to the apex and to the exit, when on a smooth arc with no need for corrections, the *impression* that I get is that I'm counter-steering the whole way through. That is, my from wheel, at best, is moving straight, if not to the outside of the curve during lean. (Normal riding here, body straight or upper body slightly turned towards the inside of the curve, with normal tire pressures and NOT power steering - or steering with the rear tire). The impression I have is that if I'm turning the front wheel to the curve (after initial counter steer), I'm riding too slow (u-turn example). Lion |
01-08-2013, 03:11 PM
#153 | |
Oddometer: 586
I think the car explanation posted was the best. If you turn left in a car your weight shifts to the right. If you slow down to 10mph your weight doesn't start shifting to the left. I hope that paints clearly how absurd a magical line where countersteering starts really is. |
01-08-2013, 04:31 PM
#154 | |
I been called a Nut Job..
Oddometer: 1,816
David
2012 R1200R ! 2000 R1100RT (retired), 1976 R75/6, 11 Versys ![]() There is a seat for everyone. |
01-08-2013, 07:16 PM
#155 | |
Oddometer: 663
Here's an example and we'll use a slow turn so you get lots of movement from the handlebars to make it work. Lets say your maintaining a left U-turn and the handlebars are halfway between straight, and full left to make the turn (so there's steering input available left to use). That handlebar position is basically the motorcycles current "center" to maintain that given lean angle and stability. If you turn the handlebars right of that "center" in the U-turn it will lean lower and tighten the turn. If you turn to the left of that "center" it will make the bike stand up and widen the turn. Mean while the front wheel is still always pointing left going through the left U-turn. That might be a little hard to follow after reading it but I suck at wording some things clearly. |
01-09-2013, 04:09 AM
#156 |
Just Beastly
Oddometer: 6,478
Lion BR and Fajita Dave are both correct. As Dave said, you are ALWAYS turning the front wheel in the direction of the turn - WHILE IN A TURN. You turn the wheel the opposite direction to INITIATE THE TURN via countersteering.
So in a turn, you may correct the radius of the turn/lean angle with additional countersteering inputs. So technically in a turn you are doing both... turning the wheel in the direction of the turn and countersteering to provide additional inputs as needed. Barry
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday. Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot. Barry screwed with this post 01-09-2013 at 04:15 AM |
01-09-2013, 05:08 AM
#157 |
Oddometer: 586
Sorry to complicate things but I was under the impression that the fact the tire is leaned over provides enough camber thrust to cause lateral acceleration of the front end without having any steering angle at all. Of course this only applies to wide angle turns, and at higher speeds 40mph+ you can actually have the wheel turned in the other direction.
01-09-2013, 09:45 AM
#158 | |
Oddometer: 3,670
(Which is neither here nor there, as far as countersteering is concerned...) |
01-09-2013, 10:45 AM
#159 | |
Oddometer: 17,983
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
01-09-2013, 05:09 PM
#160 | |
Oddometer: 2,567
01-09-2013, 06:12 PM
#161 |
Oddometer: 586
Yes it could be correct, but I believe the right term is the wheel is outtracking, this has nothing to do with countersteering so please do not confuse the two.
01-09-2013, 06:32 PM
#162 | |
Oddometer: 2,567
01-09-2013, 07:06 PM
#163 | |
Oddometer: 663
The only possible way for the front tire to not be following the line of travel is if it were sliding or off the ground. Camber thrust does have an effect on how far the handlebars are actually turned to make a given corner. However, its not a significant effect compared to the front wheel's direction deciding the radius of the turn. You could have a motorcycle with razor blades for tires (so no camber thrust what so ever) and it would corner just fine if not better than a rounded motorcycle tire. I'm pretty sure I remember reading something from a Moto GP mechanic about having razor sharp tires would be optimum for cornering. Of course they could never make a rubber tire handle that sort of load on a razor sharp point. |
01-09-2013, 08:25 PM
#164 | |
Oddometer: 586
01-10-2013, 12:12 AM
#165 |
Oddometer: 411
Pro tip: Don't stare at your front tire while you're riding.
Speaking of knife edge wheels, I feel the need to ride a razor scooter now. A few weeks ago I rode one for a little bit, and its bugging me. I don't remember consciously countersteering to initiate a turn. I was just trying not to run into a pebble. |
