Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 02-07-2013, 06:30 AM   #316
bh321
Oddometer: 32
Originally Posted by DAKEZ View Post
OK so try this. When you are balancing and need the bike to tip to the right, turn the bars to the right and see what happens. You either fall over or you put your foot down to keep from falling over. Your gyro angle has already been shot down (for the most part) in this very thread.
You are mistaken (wrong) be it through ignorance, willful or otherwise it doesn't matter... You are still wrong.
Now go fetch some beer.
this site cracks me up.
you seem to get the inverted pendulum principle, but discount the difference between the static and dynamic scenario. check out some of Tony Foale's stuff on his website. he explains it very well, even for the layperson.
bh321 is offline   Reply With Quote
Old 02-07-2013, 07:01 AM   #317
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
The fact remains that to turn a motorcycle at ANY speed a counter steer is initiated in some way EVERY time.
That should be clear enough for anyone.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 02-07-2013, 08:31 AM   #318
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,916
Originally Posted by ianbh View Post
Jeezuz guys, give it up! Ian, Iowa
Why do people get bent out of shape when discussing an issue like counter steering beyond push right to turn right? You might not be interested, but you can also choose to "read" TB all day long.
I've read through Tony's articles before and I don't remember him mentioning that at higher speeds it's the gyroscopic effect of turning the wheel instead of the "leans primarily due to the torque about the longitudinal axis produced by the slip angle, which was introduced by the countersteer" that causes the bike to lean over.
Got a link to that one about the gyroscopes?
Old 02-07-2013, 10:14 AM   #319
bh321
Oddometer: 32
the gyro effect is an additional torque that causes the bike to lean, it increases proportionally with wheel rotational speed, and acts in conjuction with lean torque from the "slip angle effect".
Foale has a chapter in his book regarding steering and balance where he covers it in detail.
Edit: looks like you can preview the book thru google: http://books.google.com/books?id=84h...page&q&f=false
check out chapter 4.
bh321 screwed with this post 02-07-2013 at 10:21 AM
Old 02-07-2013, 11:41 AM   #320
thistle66
Oddometer: 373
[QUOTE=sloweddy;20668251]
Originally Posted by Klay View Post
effect
I'm pretty sure it would be "affect".
You want to "affect" the action to bring about the desired "effect".
Here is an example from the interweb:
"Gender may affect the action of garlic oil on plasma cholesterol and glucose levels of normal subjects."
http://www.ncbi.nlm.nih.gov/pubmed/11340102
Klay's use of effect, as a verb, is correct.
ef·fect
/iˈfekt/
Noun
A change that is a result or consequence of an action or other cause.
Verb
Cause (something) to happen; bring about.
thistle66 is offline   Reply With Quote
Old 02-07-2013, 12:43 PM   #321
sloweddy
Tree Hugger
sloweddy's Avatar
Oddometer: 93
[QUOTE=thistle66;20671431]
ef·fect
/iˈfekt/
Noun
Verb
After reading some English usage guides I can see why effect might be used in this case...
Usually affect is a verb & effect is a noun - but there are rare exceptions...
http://web.ku.edu/~edit/affect.html
“Effect” as a verb. (Not common, but acceptable in rare cases.) To produce a result; to cause something to occur; to bring about an outcome. Example: Smith said the cutbacks were designed to effect basic economies for the company. "
http://grammar.quickanddirtytips.com...us-effect.aspx
"Rare Uses of Affect and Effect -So what about those rare meanings that don't follow the rules I just gave you? Well, affect can be used as a noun when you're talking about psychology--it means the mood that someone appears to have. For example, "She displayed a happy affect." Psychologists find it useful because they know that you can never really understand what someone else is feeling. You can only know how they appear to be feeling."
And, effect can be used as a verb that essentially means "to bring about," or "to accomplish." For example, you could say, "Aardvark hoped to effect change within the burrow."
http://www.grammar-monster.com/easil...ect_effect.htm
"There is a verb 'to effect'. It is quite rare, but useful in business writing. It means 'to bring into being'.
Read more at http://www.grammar-monster.com/easil...TPhosfIsjt6.99
Klaatu barada nikto
sloweddy screwed with this post 02-07-2013 at 12:52 PM
sloweddy is offline   Reply With Quote
Old 02-07-2013, 04:54 PM   #322
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 103,017
ef·fect
/iˈfekt/
Noun
Verb
Of course.
Old 02-07-2013, 05:43 PM   #323
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 103,017
In conclusion, a rider must lean a bike into a turn.
Counter-steering and hip thrusts are two common ways of
creating the lean, but other ways exist. The rider can take
advantage of an uneven road surface, push harder on one
pedal than the other, lean the bike over by the handlebars,
accelerate with the wheel turned, or employ the growing oscillations
shown in Fig. 5. In any event, gyroscopic forces
play little role in leaning the bike over, through they do help
set the steering angle. The appealing notion that gyroscopic
forces are central to bike behavior, often repeated in
papers3,13 and textbooks,14 is incorrect.
http://socrates.berkeley.edu/~fajans...eerBikeAJP.PDF
Old 02-07-2013, 05:59 PM   #324
bonox
Tryin Hard
Oddometer: 2,998
if the rider leans out of the turn enough, then you don't counter steer, you just steer.
that is, if you can keep the bike vertical (on a flat road), then you'll never need to countersteer it.
This after all is the principal of the hack, which 'steers' and does not 'countersteer'. If you use your weight to provide the same reaction as the third wheel, then countersteering doesn't work.
This balancing, imo, is why you can change the steering of a bike at low speed betweeen 'steer' and 'countersteer'. At higher speeds (or lower ones with very tight turn radii), your weight and lever arm aren't enough to balance the bike, so it must always countersteer.
He immediately paid me the one of the highest compliments an Advrider can receive: "You're nuts!" (Alcan Rider)
bonox is offline   Reply With Quote
Old 02-07-2013, 07:20 PM   #325
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
Bib
Old 02-07-2013, 07:30 PM   #326
rbrsddn
3banger
rbrsddn's Avatar
Oddometer: 2,838
I was going to say something, but it's all so confusing! ( Unless you just go out and ride, then even the Anti Albert Einstein will figure it out!!!!!!!!!!!!!!!!!!!!!!!!!)
rbrsddn is offline   Reply With Quote
Old 02-07-2013, 07:31 PM   #327
bonox
Tryin Hard
Oddometer: 2,998
yeah, I know i'm an arsehole
Old 02-07-2013, 07:39 PM   #328
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
If that be the case or no... I'd still buy you a beer.
Bib
Old 02-07-2013, 07:48 PM   #329
Valker
Valker's Avatar
Oddometer: 357
Bwaahaaahaahaa.... whew, thanks, this discussion needed that!
"Though no one can go back and make a brand new start, anyone can start from now and make a brand new ending." -Carl Bard
Valker is online now   Reply With Quote
Old 02-08-2013, 07:52 AM   #330
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,916
I really hate it when I have to take the bike back to the dealer because my countersteering is broken.
Times are GMT -7.   It's 07:11 AM.
