Old 02-27-2014, 04:37 PM   #1156
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,681
Originally Posted by bonox View Post
You can have all sorts of hard parts on the ground before the tyres start sliding. You are 100% on having a go though. Nothing to lose by trying, deverything to lose by bailing
I had the luggage on the ground in this pic....
... But moving my torso left after the pic was snapped allowed me to maintain my line and pick the bag up off the ground.
Old 02-27-2014, 06:01 PM   #1157
joexr
Oddometer: 3,773
Originally Posted by Skidding650 View Post
Ok I got as far as page 12 and got a headache. I thought I was in the WTF thread
My question is if I am in a paved corner going to the right, I am leaned over as far as I can, my rear tire is not sliding, but i am going to fast and will cross the center line which I do not want to do.
Do I push with my right hand and pull with my left hand causing my front tire to start turning to the left and keep looking to were I want to go? Or just say fuck it and bail
Hang off the inside more.
Old 02-27-2014, 06:06 PM   #1158
tkent02
Oddometer: 2,517
A lot more.
tkent02 is offline   Reply With Quote
Old 02-27-2014, 06:27 PM   #1159
LoachDriver
LoachDriver's Avatar
Oddometer: 21
Some of you may be aware of Google's research into automonous vehicles. I recently read a very interesting and informative article in The New Yorker about the beginnings of that research and their progress.
Article here: http://www.newyorker.com/reporting/2...urrentPage=all
In relation to this counter steering thread, I recently recalled the following paraphraph from that article:
"Finally, a year into the project, a Russian engineer named Alex Krasnov cracked the code. They’d thought that stability was a complex, nonlinear problem, but it turned out to be fairly simple. When the bike tipped to one side, Krasnov had it steer ever so slightly in the same direction. This created centrifugal acceleration that pulled the bike upright again. By doing this over and over, tracing tiny S-curves as it went, the motorcycle could hold to a straight line. On the video clip from that day, the bike wobbles a little at first, like a baby giraffe finding its legs, then suddenly, confidently circles the field—as if guided by an invisible hand. They called it the Ghost Rider."
This sentence in particular: "When the bike tipped to one side, Krasnov had it steer ever so slightly in the same direction."
My attempt at rephrasing: If a leaning bike steers in in the direction of the lean, it stands up. To me the inverse would then be true, if a leaning bike steers in the opposite direction of the lean (counter steer), it leans further.
I would suggest that this is engineering evidence of the effect of counter steering.
Thanks, LoachDriver.
2013 KLR650
2003 750 Nighthawk
1975 CB750K (restoring)
LoachDriver is offline   Reply With Quote
Old 02-27-2014, 06:45 PM   #1160
mfgc2310
Oddometer: 137
Forgive me if somebody said this in the 7 pages but there is so much confusion about this.
Countersteering does not make the bike turn! Countersteering makes the bike fall or lean which is required for the bike to turn at speed unless you have a side car
Once the bike is leaning you actually turn the bars in the direction of the turn, which also stops the bike from falling over completely.
At high speed the lean is great but the turn is small. In fact at very high speed even the largest radius turn requires max lean. With exception of racing conditions traction will give up before reaching this limit.
At lower speed and sharp turns you can achieve full steering lock at full lean.
At low speed, slight turn you can use body position instead of lean to balance.
Also, you can slide the rear out so power at the back tire will push you around the corner. Ussually done on low traction surfaces but low traction will also get the front tire sliding too.
mfgc2310 is offline   Reply With Quote
Old 06-26-2014, 02:50 PM   #1161
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,603
Did we ever get to the bottom of this?
Old 06-26-2014, 02:58 PM   #1162
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,681
Yes, stand up to lower the center of gravity.
Old 06-26-2014, 05:21 PM   #1163
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Location: Western NY, further from NYC than 6 entire states
Oddometer: 2,757
No, staying on top of the thing is the goal
PFFOG is online now   Reply With Quote
Old 06-26-2014, 05:22 PM   #1164
pretbek
pretbek's Avatar
Oddometer: 1,106
And when you sit down again the earth's axis is off by another 0.1 degrees.
pretbek is offline   Reply With Quote
Old 06-27-2014, 08:54 AM   #1165
McAninch35
McAninch35's Avatar
Oddometer: 101
We all gave up, sold our bikes, and found less mysterious hobbies
McAninch35 is offline   Reply With Quote
Old 06-27-2014, 11:30 PM   #1166
FlySniper
Bleh...
FlySniper's Avatar
Oddometer: 1,662
No, not yet. Check back sometime in the next year and a half or 1,164 posts.
For some reason, this thread reminds me of trench warfare in WWI. The line never really moves, yet the casualties keep accumulating.
A feeling of having made the same mistake before: Deja Foobar.
"Think about how stupid the average person is. Now, realise that half of them are dumber than that." - George Carlin
FlySniper is offline   Reply With Quote
Old 06-27-2014, 11:44 PM   #1167
FlySniper
Bleh...
FlySniper's Avatar
Oddometer: 1,662
Might as well sell them since apparently they never ride them. 30 seconds in and countersteering looses any hint of mystery it may have held.
Old 06-27-2014, 11:47 PM   #1168
catweasel67
Oddometer: 8,856
Is that active or passive?
catweasel67 is offline   Reply With Quote
Old 06-28-2014, 01:50 AM   #1169
JohnCW
Oddometer: 1,320
Bottom of what? What's the topic of this thread, o that's right counter-steering, seems to have run out puff. Doesn't matter, I never actively counter steered going around a corner in my life.
JohnCW is offline   Reply With Quote
Old 06-28-2014, 06:59 AM   #1170
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,681
I'm not sure counter steering even works when you're upside down.
Times are GMT -7.   It's 03:50 AM.
