Old 01-04-2013, 12:52 AM   #106
4bikes
Oddometer: 226
It's all here folks:
http://www.fema-online.eu/index.php?...t01returnid=15
OK, so it's not perfect english everywhere. But try to look beyond that.
4bikes is offline   Reply With Quote
Old 01-04-2013, 07:25 AM   #107
IrishJohn OP
Oddometer: 71
I honestly did not mean to start such an apparently contentious thread - but it does reinforce my feeling that this is such a confusing thing that it has yet to be truly broken down into 'real world' easily understood terms.
While I genuinely appreciate all the thought and efforts put into the posts I found the one from 'David' most helpful in dispelling some of my mental fog about how something with a wheel can 'turn left to go right'
Again my apologies for starting a bit of bother so soon after arrival.
Originally Posted by David R View Post
Just a thought.
Going around a sharp right curve Bike is leaned WAAAY over.
To right the bike (stop turning and go straight) do you turn the wheel to the left?
It seems this would put the bike less under you and go deeper into the turn.
Turn the bars to the right and the bike will go back under your body towards an upright and straight position.
David
Enjoying the conversation.
Irish John
IrishJohn is offline   Reply With Quote
Old 01-04-2013, 08:16 AM   #108
pretbek
pretbek's Avatar
Oddometer: 1,079
I'm glad that imagining "putting the bike more/less under yourself" helps clear up the mental fog for you.
For quick reactions when you need them though, train yourself to have muscle memory to lean in the correct direction. Having just entered an oh-shit moment when riding is not the time to start reasoning which way to turn the wheel again to get the desired result. It should be visceral, which is much more immediate.
pretbek is offline   Reply With Quote
Old 01-04-2013, 09:03 AM   #109
dwoodward
dwoodward's Avatar
Oddometer: 5,570
Originally Posted by RVDan View Post
Please, somebody build a steering deflection gauge, hang a GoPro over it, mount another camera in a chase car, go for a ride. Time synch the videos and play them split screen so once and for all it can be seen what is really going on.
Again? This was done in the '70s- long before GoPros, when men were men and video (film, likely) cameras weighed LOTS. When I first became an MSF instructor I got a hand-out that showed pictures of the rig.
Might be fun to re-create, though. Hm...
Could do it with one GoPro. Stick it on the tank, aimed forward- the steering deflector is a wire attached to the steering stem, bent up 90 degrees, with a cardboard background behind it to show steering angle.
Hm.
dwoodward is offline   Reply With Quote
Old 01-04-2013, 11:29 AM   #110
duck
duck's Avatar
Oddometer: 10,403
If I take this thread off on a tangent will it go the other way?
duck is offline   Reply With Quote
Old 01-04-2013, 04:01 PM   #111
pretbek
pretbek's Avatar
Oddometer: 1,079
A tangent? Sorry, no, approaching 90 degrees (but never actually reaching) is the maximum. The other way as in back where it came from is not possible with a tangent.
Old 01-04-2013, 08:07 PM   #112
Fajita Dave
Fajita Dave's Avatar
Oddometer: 717
Hm.
Keith Code did in the Twist of the Wrist II DVD. Has a gauge on the fuel tank with an arrow attached to the steering stem. Its extremely subtle but they have even better examples in the video.
The easiest way I found to explain counter-steering to people is by comparing it to what they feel in a car. The majority of what makes counter-steering work is simple inertia. While driving a car, when you turn left which direction does your weight shift to? To the right of course! Now think of what would happen on a motorcycle that's balanced on two round wheels. Turn the handlebars left.... the weight goes right (so you lean right).
COG has some effect since when you turn the handlebars the front wheel's contact patch moves slightly out from under the motorcycle which helps it lean. At higher speeds even gyroscopic precession has some effect from the research I've done (precession has about a 12% effect on a motorcycle changing lean angle at 60mph depending on how much the front wheel weighs... but I didn't do the testing to come up with that number). The vast majority of what makes counter steering work is the basic laws of motion. This happens at ANY speed but is more noticeable the faster you go.
2008 GSXR 600
2001 CR250R
Fajita Dave is offline   Reply With Quote
Old 01-04-2013, 09:33 PM   #113
khager
Oddometer: 971
No, but it will create an alternate thread! Alternate to you and me, but reality for everyone else of course.
khager is offline   Reply With Quote
Old 01-04-2013, 11:22 PM   #114
Dream Rider
Servant
Dream Rider's Avatar
Oddometer: 192
counter steer
Originally Posted by DAKEZ View Post
This is not to be until Tuesday.
You are already countersteering if you are turning a bike or motorcycle. (they do not turn otherwise)
It is nice to know the mechanics of it however... And to practice those mechanics.
Look Left Push left Go Left
Look Right Push Right Go Right
Look through the turn. Look through the turn. LOOK THROUGH THE TURN.
The end.
Dakez has it right. This is all you need to know. push left go left push right, go right. I know a lot of good pilots that can't bleed acft brakes but they do know push down slow down. Have fun.
Dream Rider is offline   Reply With Quote
Old 01-05-2013, 07:15 AM   #115
BanjoBoy
BanjoBoy's Avatar
Oddometer: 878
Kieth Code debunked this lame argument back in the '80s, can't believe y'all are still debate'in it?
Kieth has a no BS bike to debunk this lame BS. It haz two sets of handle bars; a normal set and a rigid set that don't turn. He lets chumps who think changing body weight steers a bike use the rigid bars and try to ride 'round the track. Needless to say, the ones use'in the rigid bars don't get very far.
Here ya go newbs
2007 FJR1300
2007 FZ6 (Dirt bike)
BanjoBoy is offline   Reply With Quote
Old 01-05-2013, 07:44 AM   #116
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 3,971
Another way to understand counter steering on a motorcycle:
Get a broom, put the broom side up and with the end of the handle on your palm, try to balance it. You need space, it is better to do it outside.
Now "drive" the broom as you walk, balancing it. If you want to go right, you will find your self moving your hand left and the broom will lean right. When you want to stop going right, you will move your hand to the right. When you want to go left, you will move your hand right. The broom pivots on your palm.
Now imagine your motorcycle's handlebar is the broom, the wheel is the handle (the front wheel pivots on the ground). When you get to a curve to the right, you will want to "push" your "broom handle", the front wheel of your motorcycle, to the left and the handle bars, the broom, will "fall" to the right. You and the motorcycle will go right. That's why you turn the wheel to the right to lean left and go left. And to do that you turn the wheel to the right by pushing it on the left (or pulling on the right) side of the handlebar. Counter steering!
If you "drive" a broom like I explained, I bet you will understand the basic counter steering principle.
Leaning, gyroscope, rake, trail, tire profile (the changing wheel diameter due to lean angles) are all "accessories" to the main basic principle of balance that explains counter steering. That is, they may attenuate the effect of counter steering or will cause to require more counter steering for same turning.
Of course, I may be wrong in some explanations here, which if it is the case, one of you will point it out and I will edit my text accordingly.
Lion
edit: of course, at very very low speeds you will turn the wheel into the turn, like when you are moving the bike in the garage, or when making a tight u-turn. There is a speed though, perhaps 5mph or a little more, where the counter steering principle "starts".
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR screwed with this post 01-05-2013 at 08:03 AM
Lion BR is offline   Reply With Quote
Old 01-05-2013, 08:05 AM   #117
WFO#1
Oddometer: 45
On a VSTROM forum once, after reading 10 pages of opinions on low speed turnarounds, I couldn't take it any more and sarcastically offered the advise of, " stop the bike, back pedal with feet on ground while turning handle bars, turn handle bars back the way you want to go and take off". This led to me being chastised as a unsafe practice. Hey Irishjohn, forget you ever heard the term " counter steering" and go have fun on your bike.
ps: what if I said you steer a dirt bike with the rear end, how many minds would I blow
WFO#1 screwed with this post 01-05-2013 at 08:56 AM
WFO#1 is offline   Reply With Quote
Old 01-05-2013, 08:27 AM   #118
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,616
Originally Posted by WFO#1 View Post
ps: what if said you steer a dirt bike with the rear end, how many minds would I blow
How do you control which way the rear moves?
Old 01-05-2013, 08:36 AM   #119
Racer111v
Racer111v's Avatar
Oddometer: 760
[QUOTE=WFO#1;20401573
ps: what if said you steer a dirt bike with the rear end, how many minds would I blow[/QUOTE]
Or if you want to see a true "rear steer" bike created with our tax dollars, just Google "Joan Claybrook backward bike"
Racer111v is offline   Reply With Quote
Old 01-05-2013, 08:46 AM   #120
farmerstu
Oddometer: 485
Lion
don't you people read the theads you post in?
can't believe i'm gettting sucked ito this again. a good demo is to take a piece of rope around the bar ends and try steering with them.(can't push ,only pull) it will quickly become apparent.
i compare a good mc. rider to a good horse rider. i.e. i can ride a horse,i know the mechanics of how to ride, however i have no confidence that the horse is going to do what i want it to do. when i ride a mc. i know,just like a good horseback rider knows the horse, that the bike is going to do what i want it to do. riding horse is unsafe for me, if you can't make your mc. do what you want it to do under any conditions mc.riding is unsafe for you.
farmerstu is offline   Reply With Quote
Times are GMT -7.   It's 02:47 AM.
