Old 12-25-2012, 11:11 AM   #1
2712 OP
Oddometer: 374
2012 adv case locking meganism replacement
Hello,
Because of numerous drops the locking meganisms that lock the adv case onto the adv case rack on my 2009 gs adv have some play. The boxes rattle on the rack and im scared that it will get worse over time.
Ive 50K miles on my bike at the moment and i am considering to replace the locks of possibel.
Now i already got one of to check it out and i was browsing the web to find the locking meganisms (i know i can just swap the inner lock from a how to here on adv rider) but i cant find them.
Does any of the inmates know where i can buy the locks online or do ive to contact my dealer?
Thank you in advance and happy hollydays.
2712 is offline   Reply With Quote
Old 12-25-2012, 11:17 AM   #2
2712 OP
Oddometer: 374
Looked onto the web everywhere, could not find it.
Start a thread on advrider.com and googled one more time...
And i found it
Awesome site that sells every last bit you need. Is 50 dollars for such a hinge lock expencive?
http://www.bmwmcchattanooga.com/show...ssembly=188602
Old 12-25-2012, 02:05 PM   #3
LaurelPerryOnLand
Oddometer: 3,482
And...your ALTERNATIVE source is what? (none) BMW makes it. (exclusively) You need it.
Welcome to the 'BMW' game. Open thy wallet.
Some dealers offer discounts to local BMW club members.
Some dealers offer discounts.
There are threads here.. SEARCH ...discount internet IIRC.
here it is...
http://advrider.com/forums/showthread.php?t=840077
Thanks again for supporting WORLD WIDE COMMERCE.
"Awesome site that sells every last bit you need."
Your LOCAL Belgium dealer should carry, as well.
LaurelPerryOnLand screwed with this post 12-25-2012 at 02:16 PM
LaurelPerryOnLand is offline   Reply With Quote
Old 12-26-2012, 07:01 AM   #4
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,433
Here's one a few dollars less expensive, but still a lot of money: http://www.2wheelpros.com/oem-parts/...4183-part.html
Also, are we sure these locks are the same as the one that secures the case to the frame. I see these are for securing the top of case, not to the frame.....please check.
Normal is just a setting on the dryer.
2009 R1200GS A, 2008 K1200GT
lhendrik is offline   Reply With Quote
Old 12-27-2012, 04:37 PM   #5
seniorasi
Oddometer: 816
New locks??
Can't tell for certain without seeing the bike but is the play in the lock or is it in the pannier rack.. If the bike has been dropped numerous times the rack may be bent a bit...just bend it back if the play is between the rack and the lock.
seniorasi is offline   Reply With Quote
Old 12-28-2012, 01:37 AM   #6
2712 OP
Oddometer: 374
Its in the lock, when locked, it has like 1 mm play, i can wiggle the meganism... if you add the leverage over a foot of pannier, if i rock the panniers, that 1mm result in a 5 mm play
I guess he has been napping a few times to much... dents you can bash out, scratches you can repaint but that lockingmeganism has to be replaced.
Old 12-28-2012, 07:30 AM   #7
seniorasi
Oddometer: 816
Sorry mate...
Old 12-28-2012, 07:58 AM   #8
2712 OP
Oddometer: 374
Sorry mate...
ive to ask, if you have the panniers of your bike and you lock the lock that grips to the pannier rack. and then you take the metal part and try to wiggle with it.
If you do so with an ok pair of panniers, the lock should not wiggle for like 1 mm, it should be lockt firmly with no play right?
Old 12-28-2012, 01:54 PM   #9
seniorasi
Oddometer: 816
I have a 2012 GSA with BMW Aluminum panniers and top box. Mine are rock solid, now that I've tightened the hardware that attaches the racks to the bike anyway. Long story short: It takes some effort to cause the latch to go over center. When reinstalling the luggage I slide it all the way forward and then close the latch so the hook seats in it's resting place, there is a definite "over center" feel when the latch closes. It you so desire: remove the luggage, close and latch on the locking mechanism and test it for security. If it still has the 1 mm play you describe it is obviously the latch. I would think Parts should be available for repair but maybe a new latch is your best bet. I assume you can purchase new ones from the dealer and have them keyed to your ignition in one shot. Best of luck!
Old 12-31-2012, 08:14 PM   #10
PackRat
Huey Guns
PackRat's Avatar
Oddometer: 1,455
Before you buy a new latch, try loooking at the pin that the lock engages and see if you can adjust it with a drift pin and tap it with a hammer. On the one I have, it was knocked off a little with a zero airspeed fall-over that made it loose.
"Packrat" IBA# 11205, AARP, ATP, CFI, A&P, USMC
__________________________________________
Rigor Mortis will be the first indication that I've grown up!!
Yungas Rd.-Bolivia, Alaska '08 - Labrador '10 -
PackRat is offline   Reply With Quote
Times are GMT -7.   It's 08:23 PM.
