Old 01-02-2013, 05:50 AM   #16
ANKOF OP
Oddometer: 124
oh. sorry. you pulled your "in". then did you loose something or was it all better.
ANKOF is offline   Reply With Quote
Old 01-02-2013, 07:06 PM   #17
Leaf
Leaf's Avatar
Oddometer: 398
Originally Posted by ANKOF View Post
"the amount of throttle/brake skew was very noticeable" was it all bad or did you win something? can you widen the rig insted of adding ballast? narrow with heavy hack or wider with lightweight hack will that be the same? dont think I have read something about that?
I have thought about sc wheel led, weight and wide enough to be reasonable comfortable.
It was a tradeoff. The chair flies much easier now. With a heavy load, it acts pretty much the same as it did with the wider stance, except it doesn't seem to struggle as much once up to speed (but that may also be a function of having the lean and toe-in adjusted better now, too).
I like mine where it is at the moment, with the lesser skew (less arm fatigue), despite the chair flying a little too easily. I think you might just have to experiment a little and figure out what works for you.
Leaf is offline   Reply With Quote
Old 01-09-2013, 08:57 PM   #18
RAGBrian
jonesing for a ride
RAGBrian's Avatar
Oddometer: 1,020
In.
RAGBrian :: NC700X ::1978 CX500 Standard :: 1976 CB360T ::
"Going where you don't belong, I decided a long time ago, is the root of all misery and the soul of all adventure." - Peter Egan
RAGBrian is offline   Reply With Quote
Old 01-09-2013, 10:13 PM   #19
boxertwin
Oddometer: 1,022
Ewwwww, a build to watch! In.
boxertwin is offline   Reply With Quote
Old 01-10-2013, 02:05 AM   #20
FR700
Heckler™©®
FR700's Avatar
Oddometer: 7,672
I have had much help learning stuff from others on this forum during the last months, so I would like to contribute some my self about my ongoing build. see if this works, trying to submit a picture.
Beautiful workmanship on the body
I'm diagonally parked in a parallel universe.
FR700 is offline   Reply With Quote
Old 01-10-2013, 10:39 AM   #21
ANKOF OP
Oddometer: 124
thanks.
FR700. wasent it yours? that bare metal one with flames on a bmw? cant find it now, really liked that body.
picked up some more material yesterday so I can fix the suspension and fasten everything to the bike.
this is so much fun.
Old 01-10-2013, 01:42 PM   #22
FR700
Heckler™©®
FR700's Avatar
Oddometer: 7,672
Yes , that would be mine.
Have fun.
Old 01-14-2013, 10:50 AM   #23
ANKOF OP
Oddometer: 124
it was cold this weekend, it was very easy to just stay inside and drink coffee. cant fit the bike with the sidecar in my heated shop. didn`t get much work done.
copied the swing arrangement from the donator bike in CAD and welded everything that was only spot welded before
started with the stuff that will connect it to the bike.( not sure what all the parts are called.) I will use the clamps on the bike and the bars from the velorex and make new ones on the hack frame. the arc that you can see on the drawing below will double as handle for the passanger and atachment for the top bracket and shock
Iì appreciate comments on this, if it looks ok or not. just to make sure I havent missed anything.
you can allso see my new home made muffler. wanted some small supertrapp but they must be made out of gold, this one cost me 40$, and they sound good
Old 01-14-2013, 01:57 PM   #24
FR700
Heckler™©®
FR700's Avatar
Oddometer: 7,672
To my eye it looks like the bottom of the front one needs to go forward 100 - 150 mm ( adjustable one from near radiator ).
Pretend the back one is not there and what would happen if all the weight of the bike leaned on the sidecar.
If it was mine , I would try to run the rear adjustable from near where the chrome bracket is in front of the side cover and move the bottom forward to just in front of the weld.
Have fun.
FR700 screwed with this post 01-14-2013 at 02:02 PM
Old 01-16-2013, 12:38 PM   #25
ANKOF OP
Oddometer: 124
yes I see what you mean about the front one. thanks. to move the rear ones, at least the bottom one I need a subframe, think I stick with these for now so I can get the bike running as fast as posible. its much work left and with some luck the roads here will be clear from snow in the end of march.
Old 02-16-2013, 11:26 AM   #26
ANKOF OP
Oddometer: 124
took it for a spin today. hard to tell how it handles, there was zero traction. the shock is way to soft. the weight fellt ok.
feels really nice to have come this far, now I just have to finish it
Old 02-16-2013, 11:28 AM   #27
AceRph
Affluenza Free!
AceRph's Avatar
Location: Where the stupidest people on earth run things
Oddometer: 24,657
Looks good.
Equal to all of you of roads and good luck! - krokodil al-kashi
“We are turning into a nation of whimpering slaves to Fear—fear of war, fear of poverty, fear of random terrorism, fear of getting down-sized or fired because of the plunging economy, fear of getting evicted for bad debts or suddenly getting locked up in a military detention camp on vague charges of being a Terrorist sympathizer.” —”Extreme Behavior in Aspen,” February 3, 2003
"The State sees the spectre looming ahead of terrorism and anarchy, and this increases the risk of its over-reaction and a reduction in our freedom." - Stanley Kubrick
AceRph is offline   Reply With Quote
Old 02-16-2013, 11:40 AM   #28
zipper421
Oddometer: 204
i like it looks good
I love it when they say, "Where did you buy that ?"
zipper421 is offline   Reply With Quote
Old 02-16-2013, 02:54 PM   #29
Leaf
Leaf's Avatar
Oddometer: 398
Nice. Real nice! I dig it!
Old 02-16-2013, 09:38 PM   #30
DJ1
Chopper Jockey
DJ1's Avatar
Oddometer: 227
Looks great..
and will be lots of fun.
DJ1 is offline   Reply With Quote
Times are GMT -7.   It's 05:40 PM.
