Old 12-31-2012, 10:03 AM   #1
spddmn OP
spddmn's Avatar
Oddometer: 315
CB160 Front Axle???
I have a 1966 CB160. The forks that were on the bike when I got it had a lot of pitting on the tubes, so I got another set of forks, but the new ones are a little later year (I'm guessing 1968. The forks fit on the bike just fine, but the problem is that the old 1966 front axle I'm using is not working on the newer 1968 forks. The right (when on the bike) fork leg has a bigger axle hole on the bottom than the 1966 forks do. My question is... Is a 1968 front axle bigger on the threaded end than a 1966 front axle? If it is different, than I'll just find a 68 front axle and everything will go together just fine, but if its the same as 1966, then I don't understand why the axle hole on the lower fork leg is bigger,and I'll have to have a spacer made. Any help would be great. Thanks
2001 ZX6R Ninja
2008 KLR 650 (Sold)
1966 Honda CB160 vintage racer (In progress)
1975 Kawi KS125
1970 Honda CL100
spddmn is offline   Reply With Quote
Old 12-31-2012, 04:19 PM   #2
mike in idaho
mike in idaho's Avatar
Oddometer: 117
Are the fork legs alloy or steel? The later alloy lower fork legs have a removable cap on each side and use a spacer on the threaded end of the axle(looks kind of like a spool).
'68 TR6R
'69 T100R
'69 T120R
'72 Commando 750
My company car is a Kenworth
mike in idaho is offline   Reply With Quote
Old 01-02-2013, 05:10 PM   #3
spddmn OP
spddmn's Avatar
Oddometer: 315
They are alloy fork legs, and exactly as you describe them. Where can I get that spacer that I need? Is that a Honda part??? Thanks
2001 ZX6R Ninja
2008 KLR 650 (Sold)
1975 Kawi KS125
1970 Honda CL100
Old 01-05-2013, 10:16 AM   #4
mike in idaho
Oddometer: 117
Took mine apart and measured: diameter on the ends is 1.026 inches, center diameter is .825 inches, axle hole is .591. Overall length is 1.263 inches and the length of the center diameter is 1.140 inches. Hope this helps.
'68 TR6R
'69 T100R
'69 T120R
'72 Commando 750
Times are GMT -7.   It's 10:17 AM.
