12-31-2012, 10:10 AM
#1 |
W. F. O.
Oddometer: 556
Painting the Beast
the paint on my 990 tanks has seen better days and I had planned on painting them. I wanted to get some feedback from those who have successfully painted their tanks first though. What specific paints did you use? Prep work? Ect.
Thank you for you help in advance!
The love of the road is not something you can explain to someone who does not understand it.
2008 KTM 990 ADVENTURE ![]() |
12-31-2012, 01:05 PM
#2 |
World Wide Inmate
Oddometer: 2,112
This ain't no KTM, but....
I grew tired of a mystery dent that my tank bag hid from me and one day I pulled the bike apart to take care of it. Unless you have done it before, the end result might not be what you were hoping for... but... couple things. De-wax the tank with appropriate de-wax or prep from an automotive paint store. Do this BEFORE and after you SAND or GRIND. After the prep work is done, de-wax before it's primed or sealed. Wet sand out scratches, or re prime and wet sand till they are gone. Hint; anything you can "feel" as far as imperfections, will most certainly also be "SEEN". Consider just having it done by a chum in a body shop, or find a guy on your local Craigs that can do it right, you might have to stare at that tank for awhile, would be nice if the end result came out of a PAINT GUN and not a spray can, had some clear on it, and you would be proud of the project. Real automotive quality paint is around $28-$40 bucks a pint, plus the clear and specific sealer. ![]() ![]()
´¯`·.¸¸.·´¯`·.¸ ><((((((º> `·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> ´¯`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((((º> Everything happens for a reason. "Still seeking the reason" |
01-01-2013, 10:22 PM
#3 |
High Plains Drifter
Oddometer: 733
Hmmm
Not sure if that will work on the adventure tanks
01-01-2013, 10:50 PM
#4 |
Oddometer: 3,718
Should. The stock tanks are sealed.
"Civilize the mind, but make savage the body." To the house of a friend the way is never long. "Show respect to all, but grovel to none." '12 690 Enduro |
01-02-2013, 11:36 AM
#5 |
W. F. O.
Oddometer: 556
Thank you for the replies. I had not planned on sanding my tanks completely to the plastic. I was just going to get the decals off and all and get it good and uniform and go through the proper prepping steps. I'll be honest I use it rather hard so I was going to do the bottom front of the tanks that catches rocks in a hearty coat of rubberized coating and then do the rear of them in a satin black. On top I was just planning on a sand tan color in krylon rattle cans and I think if I get the prep work right it'll turn out wonderful. I used to work at a body shot and pulled dents on cages but I didn't know if I would have to do anything different. Of course I'll clear it but I want a flat finish so I was thinking that two coats on the properly sprayed ultra flat tan camo paint would give me a simi effect. If not on well haha!
I'll probably do a write up on it and if it turns out well ill post what I did You see I'm a college student and this bike is really the only thing of value I own so I'm going to do it on a budget and see what happens
01-03-2013, 08:39 AM
#6 | |
Oddometer: 910
I would recommend using an automotive catalyzed paint. I like basecoat/clear coat systems. My choice is PPG but thats just a brand. Talk with your local automotive paint supplier for a system that works well in your environment and that will stand up not abuse and gasoline. Prep is everything in a paint job.You will find that if you want to do a great job you will also need a filler primer and sealer and a lot of elbow grease. heres my latest.
When Quality matters,Its all about choices. Performance LED Vendors thread http://advrider.com/forums/showthread.php?t=839163 www.cyclopsadventuresports.com http://youtu.be/1fmEJO3ftFI |
01-03-2013, 08:54 AM
#7 | |
Oddometer: 687
Might be just me.
You must be the change you wish to see in this world. |
01-03-2013, 09:42 AM
#8 |
W. F. O.
Oddometer: 556
Well I'm a broke @$$ college student and I'm going to rattle can it. I also work full time at an autoparts store so that will help with the cost if supplies.
2008 KTM 990 ADVENTURE ![]() Pistolero screwed with this post 01-03-2013 at 09:48 AM |
01-03-2013, 09:47 AM
#9 | |
W. F. O.
Oddometer: 556
2008 KTM 990 ADVENTURE ![]() Pistolero screwed with this post 01-03-2013 at 10:01 AM |
01-03-2013, 10:40 AM
#10 | |
Oddometer: 910
01-03-2013, 06:39 PM
#11 |
Thumper
Oddometer: 354
Screw that paint crap, vinyl wrap it. Cheap, way easier and if it doesn't turn out, you pull it up and re-lay it.
You tube it...it's super simple. Only tools needed, hot hair dryer or heat gun and a good knife. I'm considering wrapping mine rather than painting it. Sent from my iPad using Tapatalk |
01-03-2013, 07:42 PM
#12 | |
Oddometer: 146
Excited to see how it turns out.
2010 KTM 990 Adventure 1978 Harley FX cut down |
01-07-2013, 06:56 AM
#13 | |
Oddometer: 146
Are you just getting the wrap and cutting it yourself or are you talking about a wrap decal kit? links?
01-07-2013, 07:20 AM
#14 |
Thumper
Oddometer: 354
I'm not really talking about a 'kit' per-sa but vinyl is pretty easy to come by.
http://www.metrorestyling.com is a great resource...a few people on other forums have used them with great success. This guy, I found on this site has awesome graphics for the adventure: http://crispydesigns.co.uk/ Make sure the surface is clean, lay the vinyl, pull it, use a little heat, cut it, have fun it with it. Its pretty hard to screw up and if you do, you pull it up and lay a new sheet. I believe you could do an entire bike for less than $100. When you scratch it, you just simple either cut it out and put new vinyl down or put a piece over it. |
01-10-2013, 10:06 PM
#15 | |
W. F. O.
Oddometer: 556
