Old 01-30-2013, 04:12 AM   #76
zipper421 OP
Oddometer: 204
pusher
im not sure yet
i would like to do a LL first
I love it when they say, "Where did you buy that ?"
zipper421 is offline   Reply With Quote
Old 01-30-2013, 07:48 AM   #77
villageidiot
Oddometer: 1,620
What's the purpose of the rocker? The end with the heim joint for adjusting ride height? I'm just not seein it yet unless its for that purpose, the way it's hooked up it can't be for a cantilever suspension because of the shock placement.
Spill beans please, and great work btw
villageidiot is offline   Reply With Quote
Old 01-30-2013, 01:17 PM   #78
zipper421 OP
Oddometer: 204
rocker
yes to adjust ride hight
Old 01-30-2013, 03:50 PM   #79
zipper421 OP
Oddometer: 204
rework
redid the suspension rocker
must have proper angles works better now
Old 01-30-2013, 04:10 PM   #80
MILLENNIUM FALCON
Oddometer: 245
It looks very functional & strong....How is the fender mounting coming? have you worked on the body much?
MILLENNIUM FALCON is offline   Reply With Quote
Old 01-30-2013, 05:46 PM   #81
zipper421 OP
Oddometer: 204
fender
i have to figure out how much travel is in the shock
so i can get the right hight
how much travel is in that air shock i gave you i have no way to compress mine
thanks
Old 02-01-2013, 04:18 PM   #82
zipper421 OP
Oddometer: 204
sway bar
looking for info on sway bars
any pics and info would be appreciated
and yes i looked up everything i could find on here
thanks in advanced
Old 02-01-2013, 05:53 PM   #83
dholaday
dholaday's Avatar
Oddometer: 340
PM sent
It is better to have ridden and crashed, than to have never ridden at all.
dholaday is offline   Reply With Quote
Old 02-01-2013, 06:27 PM   #84
zipper421 OP
Oddometer: 204
thanks
thanks for the pm
got it
Old 02-01-2013, 06:50 PM   #85
MILLENNIUM FALCON
Oddometer: 245
It seems to be right around 4" I will try to get a better measurement.
Old 02-01-2013, 06:53 PM   #86
zipper421 OP
Oddometer: 204
shock
thats cool im going to leave 5 inches of clearance
Old 02-01-2013, 07:59 PM   #87
MILLENNIUM FALCON
Oddometer: 245
You should be good with 5 or so.
Old 02-01-2013, 09:49 PM   #88
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,551
An international forum for people interested in modern high performance road going sidecars.
Quote of the Day
It is what we know already that often prevents us from learning.
Claude Bernard
FAQSearchMemberlistUsergroupsRegister
ProfileLog in to check your private messagesLog in
swaybar questions
An international forum for people interested in modern high performance road going sidecars. Forum Index -> HPSidecar Technical Discussion
View previous topic :: View next topic
AuthorMessage
irondad01
Posted: Thu Dec 22, 2005 11:50 pm Post subject: swaybar questions
I need to put a swaybar on my Triumph Tiger/Sputnik rig. I've riden it two summers now without one but with the long travel suspension I know it would make a huge difference. When I turn right the bike leans left. First question, if I use 5/8 4130 and bend it cold how important is heat treating? Without treating would it just twist out of shape after a few bumps? Second, I can run the bar over the sidecar frame under the body. The normal way puts the brackets under the frame. Will they work on top or are they too thin? Is there a lot of upward pressure? I can make something heavier or fab. a loop to use the regular brackets the way they normally go. If I'm talking like a madman don't be shy, let me know where I'm going wrong. Thanks guys. Carl
Back to top
bmcsheehy
Posted: Fri Dec 23, 2005 2:24 am Post subject:
Hi Carl,
Did you check out this topic on this forum?
http://hpsidecars.com/forum/viewtopic.php?t=12&highlight=swaybar
_________________
Bill
High Performance Sidecaring... ...There is nothing "HACKED" about it.
2006 KAWASAKI ZX-14 / HANNIGAN HP.
1971 Olds Cutlass
1936 Ford Fordoor Humpback
www.Yankee-Engineering.com
Back to top
irondad01
Posted: Fri Dec 23, 2005 11:20 am Post subject:
Bill, Yes I saw your post. It was very helpful and is where I got the idea about bending cold. My main question is about heat treating. Why is it needed? Isn't the chrome moly springy enough without it? I never messed that material before. Thanks, Carl
Back to top
bmcsheehy
Posted: Fri Dec 23, 2005 11:50 am Post subject:
Heat treating made a huge difference. When I got mine back from heat treating, it had distorted slightly.
I tried to straighten it out. Need less to say it is still distorted and works great.
If you were going to try to use one with out heat treating, I would use a larger diameter.
I don’t think that 5/8 diameter would be springy enough.
Not sure how large you would need to go to achieve the same results.
Trial and error method.
If it was my dollar, I would use the 5/8 and have it heat treated.
_________________
Bill
1971 Olds Cutlass
Back to top
docmike
Posted: Fri Dec 23, 2005 1:54 pm Post subject:
Mainly just want to agree with what Bill said. I cold bent my bar and had it heat treated. It did distort a little when treated and afterwards I could not bend it. If its not treated I think it would just bend.
My original plan was to run the bar between the sidecar body and frame, but ended up going underneath, just wasn't quite enough room. Functionally I don't see where it would matter top or bottom.
It took a little calling around to find a shop with a big enough oven to do the swaybar.
all caveats apply, to paraphrase Ralph, what do I know,,,,,I work for the governement,,,,,,,,,,,,,,,,,,,,
Mike
_________________
Mike Currin
93 BMW K1100RS / EML Speed 2000
89 Honda GB 500 (6,700 miles, all original except tires)
67 Triumph 650 chopper
92 Suzuki GS500 (eldest son)
Back to top
Bandit Bill
Posted: Fri Dec 23, 2005 4:43 pm Post subject:
My swaybar is using 3/4" 4130, with 1/4"x1 1 1/4"x15" arms welded in place and heat treated as per Bill Ballou's suggested instructions on the AOL sidebike99 website. Once heat treated, it appears to hold tensile strength quite well - I don't think my swaybar would have survived the suspension hit it took otherwise in my early summer accident, which bent up the sidecar suspension itself quite badly.
I've underslung the swaybar itself under the sidecar frame using bearing block ends, rather than the more common eurethane bushing method.. i subscribed firmly to the 'when in doubt build it stout' school of design when it went together.
I've got more photo's up of the swaybar buildup on
http://home.cogeco.ca/~wstrong/index7.html if you are interested.
I hope to be able to recycle most if not all of my swaybar setup for the new suspension design -- it's going to be tight and tough to adapt to a totally different system.
_________________
Homebrew '99 Suzuki Bandit 1200 / '88 Hannigan Comet
'78 Honda CT70 playbike
http://www.chairintheair.ca
Back to top
irondad01
Posted: Fri Dec 23, 2005 8:39 pm Post subject:
Thanks guys . I'll go with the heat treatment. I was totally dumb on the subject so I thought I'd ask someone who's been there done that.Carl
Back to top
irondad01
Posted: Fri Dec 30, 2005 11:24 pm Post subject:
I ordered my 5/8 4130,rod ends,and split collars from McMaster Carr yesterday 12-29-05 at about 10:50 am and when I got home at 6:00 pm today 12-30-05 the order was on my doorstep! Now I need my bushings and I can get busy building. Carl
Back to top
bmcsheehy
Posted: Sat Dec 31, 2005 1:04 am Post subject:
Excellent.
_________________
Bill
1971 Olds Cutlass
Back to top
Display posts from previous:
An international forum for people interested in modern high performance road going sidecars. Forum Index -> HPSidecar Technical DiscussionAll times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Old 02-01-2013, 09:59 PM   #89
zipper421 OP
Oddometer: 204
thanks
lots of good info
Old 02-02-2013, 02:42 AM   #90
Sidecarjohn
Sidecarjohn's Avatar
Oddometer: 717
Not only is this thread interesting, it's maybe one of the most informative for some time. Better than a book and thanks to all concerned.
SidecarJohn
http://www.sidecarjohn.co.uk/
Sidecarjohn is offline   Reply With Quote
Times are GMT -7.   It's 02:17 PM.
