Old 02-02-2013, 03:28 AM   #91
zipper421 OP
Oddometer: 205
thanks
thanks i was wondering if it was heavy enough
I love it when they say, "Where did you buy that ?"
zipper421 is offline   Reply With Quote
Old 02-02-2013, 08:18 AM   #92
kshansen
kshansen
Oddometer: 197
Zipper,
I'm probably way off but I was looking at the rocker arrangement and was wondering if moving the lower mount for the front adjuster tube towards the left so t he upper end of the adjuster was on the left of the rocker would result in more balanced load on the pivot bearing? This would also position the lower mount closer to the main frame tube so there would be less flex in the mount.
I'd post pictures of the first stages of my project but I'd be embarrassed to see them next to your work.
Ken
kshansen is offline   Reply With Quote
Old 02-02-2013, 02:32 PM   #93
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,885
Plagurist are us
Mines a big chair that could haul allot of stuff, your will probably be lighter and maybe could do with a smaller swaybar setup, this really works though and one can crank preload into the bar and it acts like a spring making the suspension much stiffer.
End of bar sidecar not mounted.
Final drive side
Sidecar swing arm side.
Above sidecar swing arm.
You've got allot to do this winter, building a body and making this all work,good luck.DB
Patience: A minor form of despair disguised as a virture.
Ambrose Bierce
davebig is online now   Reply With Quote
Old 02-02-2013, 02:41 PM   #94
zipper421 OP
Oddometer: 205
preload
thanks Dave
how do you adjust the preload
Old 02-02-2013, 03:21 PM   #95
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,885
preload
Simple and it gets stiff very fast disconnect one end of sway bar (take aluminum arm splined onto bar off) jack up either the bike or the chair reconnect sway bar, I settled on neutral but will try raising chair side just a little next year.DB
Ambrose Bierce
Old 02-09-2013, 03:05 PM   #96
zipper421 OP
Oddometer: 205
well
its starting to come together
whatcha think
Old 02-09-2013, 03:46 PM   #97
MILLENNIUM FALCON
Oddometer: 250
I think I like it! Looks like you got a new shock... what is it?
MILLENNIUM FALCON is offline   Reply With Quote
Old 02-09-2013, 03:53 PM   #98
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,885
You keep busy
Looks wide what's the track now ? Since its a giant Ural will the body be extra wide ? Your already the most accomplished home builder on the site.Don't get snowed into the garage.DB
Ambrose Bierce
Old 02-09-2013, 06:06 PM   #99
zipper421 OP
Oddometer: 205
build
spare harley shock not sure which one im running yet
the track is at 56 center to center what is yours
Old 02-09-2013, 07:29 PM   #100
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,885
I'm not Claude but mines only 52" c-c, your wheel base is only a about 58.5 I would be asking someone with more experience what track should be.DB
Ambrose Bierce
Old 02-09-2013, 07:35 PM   #101
zipper421 OP
Oddometer: 205
track
i was just wondering what it was 56 is fine
i have talked to claude
was just wondering
Old 02-09-2013, 07:38 PM   #102
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,885
was just wondering
Ok
Ambrose Bierce
Old 02-10-2013, 06:07 AM   #103
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,348
I have a question on the swaybar, perhaps better directed to Claude.
Are the arm lengths equal, and the attachment points equidistant from the axle center on each wheel, or can the preload be adjusted to create a 'balance' in the actual travel?
Additionally, will camber adjustment affect the swaybar settings?
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 02-10-2013, 06:21 AM   #104
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,885
Yes Claude has the real handle, but arms are equal length, they are attached buy multiple hiem joints so I don't believe they affect camber.Since you have a Hannigan chair I don't believe theirs has equal length arms, I don't know as mine is equal length to wheel centerlines, Good reading here http://www.hpsidecar.com/sidecararti...rarticles.html DB
Ambrose Bierce
Old 02-10-2013, 08:54 AM   #105
zipper421 OP
Oddometer: 205
Dave
i have drawn up a body but im not sure what im doing yet
i started with a 24 inch wide car
im down to 22 inches
the length is stock ural 70 something
Times are GMT -7.   It's 07:22 PM.
