Old 12-31-2012, 02:08 PM   #1
bikepharmer OP
Baja is on the way
bikepharmer's Avatar
Oddometer: 151
In middle of valve adjust, need help!
I am taking advantage of some time off by doing some maintenance on my 2008 990 ADV, and ran across this little problem I can't figure out. There is a little brass barb coming off the front intake (one on the back too), but the one on the front looks like there hasn't been a hose attached to it (dusty, muddy, bits of rubber on the barb. I don't recall removing a hose, so I am at a loss to what should attach here.
Can some help out and tell me what hose goes here?
Photo below
2012 KTM 990 ADV R.
2007 KLX 250S
The man who starts alone can start today.
bikepharmer is online now   Reply With Quote
Old 12-31-2012, 02:19 PM   #2
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
hmmmmmm.... don't have a 990 here right now, however that should be either capped (if emissions stuff removed), or it should have the MAP sensor attached to it.....
If emissions removed, then I suggest placing a bolt/screw rather than capping the hose nipple off, otherwise will experience the same problem in the future.
allen head 6mmx1.0x10mm will work, or if you have extras from other stuff, the bolts that hold the vacu-valve to the bottom of the airbox will work as well.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 12-31-2012, 02:25 PM   #3
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,800
IIRC that was part of the emissions (maybe SAS) when I dealt with it on my bike. Yes a hose should run to it.
Might want to look at the vacuum line diagram for the motor (don't know where to find one though)
Correction: Those go to the pressure sensor according to the microfiche
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 12-31-2012, 02:32 PM   #4
K6KTM
Oddometer: 32
Doing the valve check on my 08 990 on mine the front cylinder has a blanking screw, the back cylinder has the brass connector in question, connects to the unit above via a black pipe to a electrical unit. I'll get a photo
K6KTM is offline   Reply With Quote
Old 12-31-2012, 02:33 PM   #5
Peanuts
Peanuts's Avatar
Oddometer: 1,607
On European bikes there is only one barb per inlet used on the 990, one for each MAP sensor, right front and left rear.
The left front and right rear are stopped up with a normal 8mm hex headed M6 screw.
Photo shows left front.Do US spec bikes have something the Euro bikes dont?
Unless someone has installed a chain oiler that requires vacuum?
Peanuts screwed with this post 12-31-2012 at 02:50 PM
Peanuts is offline   Reply With Quote
Old 12-31-2012, 02:33 PM   #6
K6KTM
Oddometer: 32
Nothing to do with SAS IMO
Old 12-31-2012, 02:36 PM   #7
Peanuts
Peanuts's Avatar
Oddometer: 1,607
There are two tapped holes per inlet, look on the other side ;)
Old 12-31-2012, 02:57 PM   #8
K6KTM
Oddometer: 32
Old 12-31-2012, 03:02 PM   #9
DSM8
DSM8's Avatar
Oddometer: 3,800
Your correct they are to the pressure sensors if there is one from each intake to the electrical device.
Old 12-31-2012, 03:08 PM   #10
K6KTM
Oddometer: 32
What you can't see in the photo is the front brass connector, basically a mirror image of the rear cylinder, blanking screw, black pipe to electrical "pressure sensor" cheers DSM8
Old 12-31-2012, 03:17 PM   #11
K6KTM
Oddometer: 32
Right front :)
Old 12-31-2012, 03:42 PM   #12
RoundOz
Plenty of seasoning
Oddometer: 1,004
From what I have seen...
One barb each TB go to the pressure sensors, the other two barbs are sometimes joined by a piece of hose as a quick and dirty method of blocking them off when the emissions stuff is removed. I used plugs/screws as previously mentioned - any unecessary hose is a point of failure, though keeping the barbs is a convenient method of syncing multi cylinder engines (rather than trusting the sensors and the software to do it) and I was tempted to run two plugged hoses to a convenient accessible location...but didnt. There is mention is some threads that the pressure sensors are not accurate or consistent, and that they should be swapped and checked againts the TuneEcu (or the KTM shop software) readings to see if an offset needs to be applied. To be fair, if using vacuum gauges you should probably test them against each other to see if they agree. Can't say I have done any of these (possibly) anal things...but have been tempted. One man's anal is another man's standard operating procedure...oh, did I really just say that?
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 12-31-2012, 03:45 PM   #13
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Air Leak in Manifold
That cylinder was certainly drawing air thru the opening which would make the all air/fuel mixtures lean on the carb'd 950's- I'm wondering what the ECU/EFI computer was doing with that cylinder (if anything) to compensate for the extra (unfiltered) air. Was the bike popping or backfiring? Ever seem to warmup quickly or get hot? Liquid cooling can hide so much & take away loads of heat that would have killed air-cooled engines...
If you aren't going to use the air port(s) it's better to put a screw/bolt in the opening than plug the hose stuck over the barb fitting- all 'rubber' plugs will eventually crack or enlarge from fuel vapor/engine heat & not give a tight fit. I have a pair of 8-10" hoses which are left in place & plugged on the ends until I synch. I can connect my synch gauges without digging around in tonto the barb fittings.
Good thing you found out now & not in the middle of a deep water crossing!
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is online now   Reply With Quote
Old 12-31-2012, 06:08 PM   #14
bikepharmer OP
Baja is on the way
Oddometer: 151
I discovered during the routine valve check (9000 mi on bike). I am the second owner, and at this point don't believe the valves had ever been checked. The bike was running fine, maybe a touch hot (5 bars) in slow traffic, but 4 bars under steady movement. No weird backfiring or anything, but some very mild surging around 3K rpm. Also, there was some fuel smell I was noticing.
There is a tiny hole in the brass barb. Should I just put a short piece of hose and plug it with a bolt?
Bike is stock, and still has all the emissions stuff on it. I would prefer to keep it stock. The rear barb goes to a hose that runs to a sensor, but also T's off, Maybe that hose was supposed to go to the brass barb?
2012 KTM 990 ADV R.
2007 KLX 250S
Old 12-31-2012, 08:59 PM   #15
crofrog
Oddometer: 1,455
Man, I wonder how much wear was done to the top end with all the dust that had to make it in there.
I'd consider pulling the cylinder head, and inspecting it and maybe plan on having the cylinder replated and do piston, rings and valves.
crofrog is offline   Reply With Quote
Times are GMT -7.   It's 05:54 PM.
