Old 12-31-2012, 01:26 PM   #1
kanur OP
cu new er
kanur's Avatar
Oddometer: 753
Super Enduro Fuel Pump, Help out an Idiot
Dear Orange Crush,
OK, so I had the tank off my SE to put in a new air filter and put the stock tank on for awhile. After getting it together and putting the fuel back in I was ready to take a little spin. It would start and die, start and die...............
At first I would hear the fuel pump and then not........and then Doh! I hadn't turned the fuel on. Now the fuel is on but will not start and no fuel pump sound. I check the fuse first and it is good, check the fuel pump connection and I am not getting current to the pump. Checked the fuse again and even put in a new one, nothing at the pump.
What am I missing? Is there another fuse or relay?
Signed,
Dumb Dumb
Just cause I don't run my mouth don't mean I got nuth'n to say. Mike Cooley DBT
kanur is offline   Reply With Quote
Old 12-31-2012, 02:25 PM   #2
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 1,001
I would pull the pump and check to see if the points are stuck together. Happened to mine and was able to take a finger nail file to them to get going again. Then ordered a Dr Bean kit.
dogsslober is offline   Reply With Quote
Old 12-31-2012, 02:47 PM   #3
kanur OP
cu new er
kanur's Avatar
Oddometer: 753
Thanks for the reply dogsslobber, turns out I'm an idiot X2
I was going to pull the lines off the pump to see if maybe it had hyrdo locked from pumping dry. When I looked up at it not only had I not turned the fuel on but in my hurry to get a short ride in before the snow and ice started again i hadn't connected the quick connect going to the carbs. Plugged that in and it fired right up.
I do find it odd that the connection going to the pump will not show current with my tester. The horn wire lights it bright and the fuel sensor makes it glow dim but nothing for the pump
To late to go for a ride, getting a rain,sleet,and snow mix
Old 12-31-2012, 03:19 PM   #4
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 4,003
There is only current to the pump when it need fuel which trigger the points. Think of it as a momentary switch within the pump and not a constant on like an EFI pump.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 12-31-2012, 05:05 PM   #5
kanur OP
cu new er
kanur's Avatar
Oddometer: 753
Ahh, that makes perfect sense.
Old 12-31-2012, 08:07 PM   #6
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,602
the correct answer is there is voltage applied to the pump PRE start for about 5 seconds, then it gets turned off by the ECU if no ignition pulse sensed (engine running). If you were checking after that time, then there will be no power to the pump circuit.... On a dry carb prime I will cycle the key on then off several times, listening for the pump (OEM Mitzu pump BTW, the Facet does not stop clicking when it meets set pressure.) to stop clacking, cycle key one more time, then begin normal start sequence.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 12-31-2012, 08:15 PM   #7
Iflylo
Iflylo's Avatar
Oddometer: 22
Connect yr tester to the positive wire on the fuel pump and then switch the ignition on.I think you should get an ignition supply to the pump.I lost ignition on mine when there was an open circuit on the multi-plug from the ignition switch behind the dash.
If your pump is playing up maybe you should use the opportunity to fit a Facet.
Happy New Year
Iflylo is offline   Reply With Quote
Old 01-02-2013, 02:12 AM   #8
markie_wales
Oddometer: 938
Surely not?? Who'd do something like that and spend 15 mins trying to diagnose it?? Surely no one on here??
Walks away, hands in pockets, looking down, whistling......
cheers
Markie
- "Dad, when I grow up I want to ride motorbikes like you do." -------- "Son, you can't do both."
markie_wales is offline   Reply With Quote
Old 01-02-2013, 04:15 PM   #9
Phil in K.C.
Oddometer: 520
Happy New Year Kanur!
Sounds like you should have just gone to the cabin!
'06 950 Adventure
Communism doesn't work because people like to own stuff......Frank Zappa
Phil in K.C. is offline   Reply With Quote
Times are GMT -7.   It's 05:04 AM.
