Old 01-01-2013, 09:24 AM   #1
qman8 OP
GS09
qman8's Avatar
Oddometer: 519
Bluhduh Help with oill filter removal!!!
A quick forum search revealed no related items.....
I just cant seem to get the damn oil filter off my 09 1200GS. I've tried the old screwdriver poked thru it method ...just ripped it up and it did not budge. I broke TWO filter wrenches...One while trying to torque it off with a 1/2 inch ratchet! I was using all the muscle I had at that time when it snapped! I had let the bike cool for several days after the oil drain before I was able to get back at trying to remove the filter. Would a cold (winter) engine and filter prevent me from turning this damn thing??? Cant run the engine to heat things up now with a broken filter !
The dealer put the last filter on...maybe he used a friggin impact driver!!!????
One person suggested buying the cup type wrench and drilling several holes thru it and thru the bottom of the filter, then run sheet metal screws thru both, and then try wrenching it!
That might be my next try!
Any help is appreciated!
qman8 is offline   Reply With Quote
Old 01-01-2013, 09:28 AM   #2
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 16,773
Ive used the 3 screws method before, straight up into the filter, and outside of the center 1" or so to avoid the mounting boss
just be careful down there.
I recall reading where someguy used the screwdriver through the filter method and cracked the engine case down there.
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 01-01-2013, 09:28 AM   #3
LaurelPerryOnLand
Oddometer: 3,478
I dare not ask...but I will...
With all that effort....are you sure:
You're TURNING in the correct direction?
Left to loosey...Right to tightee?
Otherwise...never mind.
LaurelPerryOnLand is offline   Reply With Quote
Old 01-01-2013, 09:40 AM   #4
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,570
I've had one fight me on my 1150, before I tore up the filter too much I welded a nut on the filter and got that thing out of there, put it on myself and can't explain why it wouldn't come off.
Old 01-01-2013, 09:59 AM   #5
qman8 OP
GS09
qman8's Avatar
Oddometer: 519
Unless BMW has left-hand threads on the filter....I wouldnt put such a thing past those Teutonic geniuses. These are the same guys who designed the 3 different fasteners to secure the bash plate!
Looking at the new filter's threads, NO, I was turning (or trying to turn) in the proper direction.
Old 01-01-2013, 10:21 AM   #6
kimokk
kimokk's Avatar
Oddometer: 103
Did you try a strap wrench? It might be tight but worth a try. Maybe heat up the filter with mini butane torch.
'09 BMW R1200GSA Adventure! (gone)
IBA #49426
kimokk is offline   Reply With Quote
Old 01-01-2013, 10:44 AM   #7
Happy BMW
Litter Box
Happy BMW's Avatar
Oddometer: 50
can you post a picture that would help a little. when yu put new filters on are you lubeing the filter first?
Happy BMW is offline   Reply With Quote
Old 01-01-2013, 11:34 AM   #8
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,796
Read his post:
"The dealer put the last filter on...maybe he used a friggin impact driver!!!???"
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 01-01-2013, 11:37 AM   #9
Britome
Get Free
Oddometer: 1,132
Go to autozone and the the wrench adapter that has 3 fingers that hand down and gets progressively tighter on any oil filter as you tighten/loosen.
Britome is offline   Reply With Quote
Old 01-01-2013, 11:38 AM   #10
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,570
Won't fit.
Weld nut on end of filter, take off, done.
Old 01-01-2013, 11:43 AM   #11
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,796
Originally Posted by larryboy View Post
Won't fit.
Gas weld or electric?
If electric I'd be real careful where the ground is placed. Lots of possible issues with the bikes electronics.
Old 01-01-2013, 11:45 AM   #12
Twempie
Oddometer: 202
Tri-Flow or WD40?
Would an overnight soak in a releasing agent help?
Twempie is offline   Reply With Quote
Old 01-01-2013, 11:55 AM   #13
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,768
At this point your rubber seal is "welded" for lack of a better term, to your motor case.
By your description I assume the filter is now somewhat shredded? If so, remove what is left of the can and expose the baseplate. Use a couple screws through a steel filter tool into the baseplate. Make sure they are short and thick. Then you can twist it off. I suggest turning it tighter slightly if possibe first. Heat might help as well.
Jim
Old 01-01-2013, 12:04 PM   #14
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,537
a pair of these and some heat as Jim suggests
2014 Ducati MTS1200S
2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well.
oalvarez is offline   Reply With Quote
Old 01-01-2013, 12:22 PM   #15
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,570
MIG, clamp ground to nut, weld on, no issue.
Don't think those pliers will fit on the 1200, better than the 1150, don't think they'll grab.
Chisel and hammer on the filter base plate.
Times are GMT -7.   It's 02:09 AM.
