Old 01-01-2013, 01:12 PM   #16
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,328
I see expensive repairs in your New Year. Careful with welding and chisels. JVB only viable safe option. You have been warned.
Normal is just a setting on the dryer.
2009 R1200GS A, 2008 K1200GT
lhendrik is offline   Reply With Quote
Old 01-01-2013, 01:18 PM   #17
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Similar approach to Larryboy here, but a reuseable part.
After you have exhausted the other suggestions like dilling 3 screws thru your filter wrench.....after all else fails, I would used a die grinder and cut the end cap of the filter off and gut out the filter element until you can see up inside the filter.
You should then see the other side of the filter mounting plate. It will have the threaded center post that the filter spins onto and then the outer cirlce of smaller holes. Measure the distance accross the holes...lets say they are 1.5" accross center to center. I would get a 1.5" nut at the hardware store then 2 bolts maybe 3/4" long by 1/4" thread and weld them on the nut. You can grind down the threads of the bolt until they fit in 2 of the holes in the plate.
I would then put a socket on the 1.5" nut and an extension on a 1/2" ratchet and turn it out....If you make the 1/4" bolts too long they may break if it is that tight so keeping them as short as possible would be good.
I hope that makes sense.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 01-01-2013, 01:40 PM   #18
fastgpfred
Oddometer: 42
@ Kellymac530....clever idea. No chance of running screws in too far. Then buy K&N KN-164 replacements.Anyone interested in a used BMW filter wrench?
fastgpfred is offline   Reply With Quote
Old 01-01-2013, 03:31 PM   #19
johnny80s
johnny80s's Avatar
Oddometer: 250
Works every time on every bike I have owned.
johnny80s is offline   Reply With Quote
Old 01-01-2013, 03:57 PM   #20
qman8 OP
GS09
qman8's Avatar
Oddometer: 519
Originally Posted by Britome View Post
Go to autozone and the the wrench adapter that has 3 fingers that hand down and gets progressively tighter on any oil filter as you tighten/loosen.
That's EXACTLY what I did.....and that's EXACTLY the filter wrench that broke!
Bent and snapped one of the fingers off like an old twig!
qman8 is offline   Reply With Quote
Old 01-01-2013, 04:03 PM   #21
qman8 OP
GS09
qman8's Avatar
Oddometer: 519
That wont fit a 1200 GS!...hell you can barely get anything between the filter skin and the surrounding heat sink fins.
Also, If i cant twist it with a 2 foot long, 1/2 inch ratchet, then I doubt these would help anyhow! (which is how I broke the filter wrench!)
Old 01-01-2013, 04:06 PM   #22
qman8 OP
GS09
qman8's Avatar
Oddometer: 519
Thanks for the input..but if it takes that kind of time and money to remove a filter...I'll take it to my dealer first!!!..let them deal with it (UNDER WARRANTY!)
I wonder if the extreme heat the bike saw this summer had anything to do with the "welding" the gaske to the engine case. ?
Old 01-01-2013, 04:10 PM   #23
qman8 OP
GS09
qman8's Avatar
Oddometer: 519
Originally Posted by Twempie View Post
Would an overnight soak in a releasing agent help?
You mean spray around the filter seal? I think its sealed enough that the soak woulndt penetrate...besides, its been soaked with motor oil on the opposite side for 5 months now!
Old 01-01-2013, 04:13 PM   #24
holckster
dougholck
Oddometer: 827
Originally Posted by kimokk View Post
Maybe heat up the filter with mini butane torch.
NO !!!
Oil is flamable.
Heat gun maybe.
Have fire extinguisher handy.
Good Luck
Doug Holck
Lodi, CA
3 Continents - 7 Countries - 50 States
04 BMW 1150GS Adventure
08 DR650
02 BMW K1200LTe
05 Yamaha TW200
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
holckster is offline   Reply With Quote
Old 01-01-2013, 04:17 PM   #25
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,566
I clearly see enough room to get a chisel on the filter mounting flange, get to work and take it off already.
larryboy is online now   Reply With Quote
Old 01-01-2013, 04:21 PM   #26
RTCHIEF
Oddometer: 313
Just curious, how tight was the drain plug? Jon
RTCHIEF is offline   Reply With Quote
Old 01-01-2013, 04:24 PM   #27
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,354
I can't figure it out, but some bikes just do this filter-sucking thing.
On the last bike I owned I, and every owner on its own sub-forum, found that by 3,000 miles the filters we had been carefull to not overtighten became stuck on the bikes. These were fully exposed filters we could grab with an entire hand (or gloved hand, or what-ever to get extra grip on the filters), yet filters we could test-remove with one hand when newly installed were nearly impossible to remove when used.
Is it some type of vacuum-lock? Hard to believe since the crankcase is open the minute we drain the oil out or take off the filelr cap.
Are modern filter gaskets either swelling too much (don't look like it) or glueing the filter to the case?
Mambo Dave is online now   Reply With Quote
Old 01-01-2013, 04:25 PM   #28
qman8 OP
GS09
qman8's Avatar
Oddometer: 519
Can you give more detail as to what you mean by "the filter mounting flange"??
I assume you mean to remove the filter skin and start beating on the main frame part with the holes and threads???
Old 01-01-2013, 04:26 PM   #29
qman8 OP
GS09
qman8's Avatar
Oddometer: 519
Drain plug came out without much effort!
Old 01-01-2013, 04:28 PM   #30
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,566
Leave the filter alone, the flange/lip of the filter closest to the engine, a little different color in that picture...chisel on that, trying to twist the filter once it crumples is wasted energy. If you just barely move it, it will come out.
Times are GMT -7.   It's 04:16 PM.
