Old 01-01-2013, 03:29 PM   #1
ibeme1 OP
Oddometer: 72
Cry XR400 - I think it is an offspring of Satan
I need someone to come and sprinkle holy water on my '04 XR400. I am ready to throw a match on her and watch her burn.
ibeme1 is offline   Reply With Quote
Old 01-01-2013, 03:45 PM   #2
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,694
Plenty of talented mechanics here how about a description of problems?
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 01-01-2013, 03:48 PM   #3
ibeme1 OP
Oddometer: 72
Old 01-01-2013, 03:52 PM   #4
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,977
Let's torch it!!
Old 01-01-2013, 04:00 PM   #5
ibeme1 OP
Oddometer: 72
Bluhduh
The owner is a wuss and did not have any luck starting her. I kicked and kicked aaannnd kicked and she wont start. This is my first (last?) and I am 99.9% certain its operator error. =)
Old 01-01-2013, 04:05 PM   #6
dirtybike
Oddometer: 130
First start of day, I push mine up small hill and bump start it. Kind of weird, maybe due to the automatic compression release, but I can never get a good feeling if it is going to catch or not when kicking. Maybe insure for fire and theft so I can buy a bike with an electric leg.
dirtybike is offline   Reply With Quote
Old 01-01-2013, 04:21 PM   #7
ibeme1 OP
Oddometer: 72
Laugh
[QUOTE=larryboy;20373354]Let's torch it!!
[/QUOTE
Fire Fiiiiiire!!!
Old 01-01-2013, 05:38 PM   #8
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 956
My '98 XR400R was the hardest starting bike I ever owned. I started the bike when cold by turning the fuel petcock on, leaning the bike over to the left until fuel ran out of the carb overflow tube, then kicked when just past top center on the compression stroke...............it usually started. Then, I would fall and it was a bitch to start when hot/flooded.
whisperquiet is offline   Reply With Quote
Old 01-01-2013, 05:55 PM   #9
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 524
Just saying, I had a XR 400 that was a beast to kick over when hot. When I decided to sell it, I tuned it up. Found out that the honda guy at the counter had given me the wrong plugs! After changing plugs it started like a dream. Still sold it cause I bought a KTM!
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 01-01-2013, 06:27 PM   #10
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,689
A quick Google search turned up this thread...
http://www.advrider.com/forums/showthread.php?t=281120
Lean carb from the factory means hard cold starts. That thread has a good technique for kicking it over.
...and don't touch the throttle while kicking it.
Assuming you've gone through the carbs or are confident they are clean and flowing well. Valves in spec and good spark.
Boon Booni is online now   Reply With Quote
Old 01-02-2013, 05:46 AM   #11
Switchblade315
Switchblade315's Avatar
Oddometer: 5,704
you need to find someone one that can ajust the valves the right way. this will fix 99% of the cranking problems. I fought a 96 for years when i raced. I fixed it the week i sold it because I learned this trick on that same motor on the quads. you want to know it PM me. I cant type how to do it good enough for it to be easy to understand but I can give you my cell number and tell you how. it's quite easy.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 01-02-2013, 06:34 AM   #12
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,345
Put gas in it.
Or on it and light it on fire.
I have a big single kicker too that won't start well in cold weather. Starts fine in warm hot weather. I tried modifying the choke circuit and richened up the pilot circuit which helped.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 01-02-2013, 12:14 PM   #13
ibeme1 OP
Oddometer: 72
Thumb
Thanks everyone. I thought for sure I was going to catch soooo much grief about how terrible a bike owner I am.
I will some more reading (using the link on this thread). I did some research before I bought the XR but I figured it couldnt be that hard to start.
Old 01-02-2013, 01:55 PM   #14
freetors
Oddometer: 947
Ship it out to me. I'll dispose of it properly
freetors is online now   Reply With Quote
Old 01-02-2013, 04:07 PM   #15
Switchblade315
Oddometer: 5,704
Nope yours in not the first XR400 to have this problem, but before you throw money at it trying to fix a carb problem adjust the valves the right way. on 400EX quads if they are right they crank as soon as the starter button is touched, if they are wrong they have to turn over 3 to 5 times before they crank.
Times are GMT -7.   It's 10:51 AM.
