Old 01-02-2013, 03:20 AM   #1
mike.l OP
mike.l's Avatar
Oddometer: 63
Clutch Assembly
After some amount of hassle with the clutch on my '05 950 Adv, I discovered that the previous owner hadn't lined up the dots on the clutch pressure booster when re-assembling the clutch... new parts have been ordered!
Q. Do I use a clutch basket locking tool when re-assembling the clutch or as someone suggested, a special pin
that goes into the crank?
mike.l is offline   Reply With Quote
Old 01-02-2013, 03:26 AM   #2
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,149
pin wont do you any good as the gears side will spin with the inner clutch cage. A strong foot on the rear brake works for me, or the clutch holder.
The pin only works with a ktm special tool holding the inner and outer basket together.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 01-02-2013, 11:52 AM   #3
mike.l OP
mike.l's Avatar
Oddometer: 63
Is that the same Clutch holder that's in the workshop manual's 'special tools' drawing? Part no 600.29.003.000.
I want to be able to tighten all the clutch up again once it's re-assembled. I'm a beginner here, there are no KTM dealers/workshops where I live, so I'll have a go. Anything else I need to know about?
Old 01-02-2013, 04:30 PM   #4
HellsAlien
a has-been that never-was
HellsAlien's Avatar
Location: Baja Sur winter. PDX summer (that's like 6 wks!)
Oddometer: 2,444
Regarding the clutch basket nut....
Check your hex socket chamfer on the inside leading edge. If its too big you will have minimal engagement with the thin nut, which can lead to slip/strip on the nut. One solution is to grind the socket back to get sufficient engagement.
"Hells AL is right."Zuber "Bad roads, good people. Good roads, bad people." Mama Espinoza
“Ride first, tart second. Sorry bro but that’s the way it has to be.” Cbrit, 2008
“You gas it where I brake!” trackday passenger, Thunderhill, 2005 "Especially since he's one of the fastest riders on the planet, on any surface!" Earwig, 2014
HellsAlien is offline   Reply With Quote
Old 01-02-2013, 11:06 PM   #5
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,101
I had trouble getting the clutch inner nut off. Even with the air impact driver. Didnt do it for too long as I thought it would have just come right off.
What am I doing wrong?
rossguzzi is online now   Reply With Quote
Times are GMT -7.   It's 07:34 AM.
