Old 01-28-2013, 09:11 PM   #31
norschweger OP
norschweger's Avatar
Oddometer: 242
forgot to mention
when they tried the engine without the airfilter there was quite some gas (air with gas?) streaming out of the carbs, at least the rear one...they had forgotten to put the triangel onto the airbox and the screw that you have to take out to turn over the engine...
norschweger is offline   Reply With Quote
Old 01-29-2013, 12:27 PM   #32
Katoom72
Katoom72's Avatar
Oddometer: 911
The triangle ain't that big of a deal but forgetting the plug in the ignitioncover is quite terrible.... Are KTM certifications on the Spanish Ebay or something?
Katoom72 is offline   Reply With Quote
Old 01-29-2013, 12:41 PM   #33
norschweger OP
Oddometer: 242
I do not want to talk in a bad way about this particular mechanic even though he seems to have difficulties in adjusting valves! But in general it seems that everyone who can wear a KTM t-shirt is allowed to wrench on these bikes officially....I could write a book about the last weeks. It is horrible, not to imagine, a nightmare!
What happens if you do forget this screw and let the engine run for a while, using throttle? Could that be the reason why I could see an air/gas-stream spraying out of the carb?
Old 01-29-2013, 12:45 PM   #34
norschweger OP
Oddometer: 242
If I remember correctly, they had even forgotten the screw to lock the engine...
Old 01-29-2013, 01:00 PM   #35
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Oil will come out of the there, that is about it as long it hasn't been run dry they will be no issue.
No - that won't be the problem.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema screwed with this post 01-29-2013 at 01:08 PM
ciedema is offline   Reply With Quote
Old 01-29-2013, 01:12 PM   #36
norschweger OP
Oddometer: 242
then I guess the carbs have not been synced properly...
I think they used shims for the valve adjustment that do not really belong to zhat bike: they treated them with sandpaper!?
Old 01-29-2013, 01:22 PM   #37
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
As long as they are the right diameter (10mm) then that shouldn't be a problem, many KTM owners buy Harley shims as they are cheaper and even sanding them to size is okay, provided it has been done correctly.
Leaving the locking bolt in is not good!
Old 01-29-2013, 01:30 PM   #38
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
after weeks of waiting, wrenching, being lied to, writing to KTM Austria...I am in Leon now.
The carbs have been cleaned, the valves adjusted (intake on the rear was less than 0.08mm, new oil (filter), air filter...engine seems louder to me (maybe because there is no gear on the bike), does not perform the way it should, is week in the beginning (first gear) and hesitates when accelerating immediately. Seems not to get air or gas...They say it is the timing, maybe something with the airstream...want to check tomorrow...Sounds familiar?
Is the bike actually rideable? Why not take it back to the US and get a proper mechanic to look at it? There is great guy in Phoenix. Dillion at Zen Motoworks.
I think I met you at the HU meet in Cambria, are you riding to South America, had some battery problems? Clearly you don't trust the current mechanic and you need to, if you are going to keep going.
Old 01-29-2013, 02:28 PM   #39
norschweger OP
Oddometer: 242
Yes, I was in cambria and yes, I am heading towards the tip, but I might have to change my plans! I lost so much time, incredible. Help me to give your name a face, please!
The bike is rideable, yes but I am not sure if I mess up something by doing so. The whole thing started with a leaking water pump and now weeks have passed...
To return to the US is not really an option and might even be problematic cause of the visa waiver.
The mechanic is the third one. The first mistreated the bike, the second was "imported"to reassemble it, he was good but did not have more time to wait for shims...thge third made a good impression but does not seem to have so much experience with valves, at least when it comes to this model.
I think he is a little stressed now cause I was kinda put in between and they thought it would be solved in a day. It will soon be a week!
Old 01-29-2013, 02:38 PM   #40
norschweger OP
Oddometer: 242
shims
I have just measured the shims that are not used (guess the ones used are about the same) and the maximum diameter is 8mm! at least two of them are magnetic?!
Old 01-29-2013, 02:44 PM   #41
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Magnetic is okay - that is probably just some left over from removing the buckets.
Old 01-29-2013, 03:19 PM   #42
norschweger OP
Oddometer: 242
what if they are 8mm in diameter?
Old 01-29-2013, 04:23 PM   #43
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
The old or new ones?
Old 01-29-2013, 05:05 PM   #44
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Oh yeah - I am the plump Aussie on a 990ADV
Old 01-29-2013, 05:12 PM   #45
norschweger OP
Oddometer: 242
the only ones I found are 8mm or less, they tell me that these are the old ones. Now i do not care any more cause i just met a nice guy who has worked for KTM Mexico and he will supply me with the right ones...
Times are GMT -7.   It's 10:09 PM.
