Old 02-08-2013, 09:08 PM   #211
NDEBT
NDEBT's Avatar
Oddometer: 5,219
Bueller. Remember putting A/C kits in those mitsus It was cheaper to ship the cars over without it for some reason. I do.
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. -Mark Twain
NDEBT is offline   Reply With Quote
Old 02-08-2013, 09:14 PM   #212
Bueller OP
Cashin?
Bueller's Avatar
Oddometer: 17,266
I installed more of them than I could count over the course of a decade or so. Ultimately MMSA figured out they could make/keep more of the profits by installing A/C at the port and keeping the labor revenue for themselves. Greedy bastards!
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 02-08-2013, 09:59 PM   #213
Motornoggin
Two-Bit Throttle Bum
Motornoggin's Avatar
Oddometer: 21,100
Originally Posted by HOT DAMN! View Post
Love those old 240/260Z, what are the plans, original or custom?
First of all, oit's worth a repost...
Second, is that a factory color?
There is one here in town, exactly the same color, with the same attention to detail, tyhe same wheels, etc...
Stunning...
Wow.
Really.
O.K. Joke's over. You can bring back the constitution now. Please.
My Wyoming has an East infection.
http://motornoggin.smugmug.com
Motornoggin is offline   Reply With Quote
Old 02-08-2013, 10:32 PM   #214
JonU
Oddometer: 816
Iirc ir is a factory color although I can't remember what it is called at the moment.
Sent from my SCH-I605 using Tapatalk 2
JonU is offline   Reply With Quote
Old 02-08-2013, 10:36 PM   #215
Motornoggin
Oddometer: 21,100
Maybe I can snap a pic this spring when he gets it out of hibernation.
Beautiful!
Old 02-08-2013, 10:49 PM   #216
wyowillys46
F=mA
wyowillys46's Avatar
Oddometer: 2,095
112 Lime or 919 Sunshine Yellow. Mine is 918 "Mexican Orange". Unfortunately it's been beaten down by Wyoming winters and a careless drive backing into the drivers' door.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." -Roscowgo
wyowillys46 is offline   Reply With Quote
Old 02-08-2013, 11:08 PM   #217
NDEBT
NDEBT's Avatar
Oddometer: 5,219
My hands still have scars from those.
Old 02-09-2013, 07:41 AM   #218
ducnut
Oddometer: 3,306
I bought my '90 Civic, new, without A/C (then, it was a dealer-installed option). I used their 20% off parts and accessories coupon to buy the kit and installed it myself. I saved quite a bit of money, doing that.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 02-09-2013, 07:49 AM   #219
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,390
When I worked for Mitsubishi we used to do it all the time. I watched the factory pay for a set of heads and valves on a Diamante after the owner admitted he ran the car for 130,000 miles on the original timing belt before it broke. It was supposed to be changed at 60k.
I also watched Mitsubishi pay for a short block, head, injectors, radiator, transmission, and half shafts on a Mirage after the owner left it in first gear and towed it across British Columbia behind a Class A Diesel Pusher. It picture-windowed the block and got so hot it melted every piece of plastic attached to the engine. Apparently the little 1.5 wasn't certified for continuous duty at 10,000 RPM But he kept going until the transmission disintegrated and seized. It was only when a front wheel locked that someone finally got his attention to pull over. He had what was left of the car towed to the dealer I worked at, where we spent $10,000 in 1995 money rebuilding a car under warranty that cost less than $10,000 brand new.
By the way, he was some kind of high level scientist for NASA
We had a cheapskate for a rep at our dealer. He did fold for one guy that wrecked his transfer case on his VR4 because he got an oil change and drained it instead of his engine oil.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is online now   Reply With Quote
Old 02-09-2013, 07:52 AM   #220
vtwin
vtwin's Avatar
Oddometer: 7,390
+1.
Remember the automatic gear "upgrade" on the early Tredias/Cordias? We got down to one guy dropping the transaxle and the other guy putting in the kit and then right back in. Maybe three hours tops.
Monroe.
unknown
Old 02-09-2013, 08:05 AM   #221
RedRocket
Yeah! I want Cheesy Poofs
RedRocket's Avatar
Oddometer: 19,869
Hondas were easy to do that on.
RedRocket is online now   Reply With Quote
Old 02-09-2013, 08:59 AM   #222
Bueller OP
Cashin?
Bueller's Avatar
Oddometer: 17,266
Originally Posted by vtwin View Post
+1.
Throughout the '90's I held shop foreman positions at two different dealerships - one in WA and the other in OH. In both cases I did most of the heavy engine/transmission work. I got so well versed in Mitsu F5M Series manual transmissions with their shitty fiber lined synchronizer issues that I could R&I and completely overhaul a front wheel drive version in 3 hours, or an AWD version in just over 4 hours. I actually did a front wheel drive transmission overhaul once for a female customer while she waited up front in the lounge
Old 02-09-2013, 10:05 AM   #223
vtwin
vtwin's Avatar
Oddometer: 7,390
We LOVED doing p/u timing belts! And 2wd p/u clutches, 45 minutes was my best. I ended up buying a customer's '83 4wd diesel p/u. We almost dropped that trans/transfer when we replaced clutch on it. Guy with little girlie hands on the transfer side said it got too heavy, I was on the other back side and tail shaft pushing, foreman was on the front guiding it. John (girlie hands) dropped his side, rolled to that side and out of my hands, foreman caught it before it hit the ground!
Monroe.
unknown
Old 02-09-2013, 12:03 PM   #224
Jurgen
Trolljegeren
Jurgen's Avatar
Oddometer: 41,800
I really like that car, and that pic. Something raw about it.
They're nihilists, Donny, nothing to be afraid of.
Originally Posted by nskitts View Post
I'm sorry your dog died before you got to beat it with a dead chicken.
Moderator:CSM/JoMomma/ShinyThings/Sports
Jurgen is offline   Reply With Quote
Old 02-09-2013, 10:33 PM   #225
NDEBT
NDEBT's Avatar
Oddometer: 5,219
I bet Bueller can work on these. I cant. I get it but everytime I try to fix one these it kicks my ass.
Thread Tools
Times are GMT -7.   It's 01:56 PM.
